root/radiance/ray/src/util/xglaresrc.c
Fri Mar 26 23:34:24 2004 UTC (21 years ago) by schorsch
Changes since 2.8: +34 -15 lines
Continued ANSIfication.
Tue Nov 11 16:24:06 2003 UTC (21 years, 4 months ago) by greg
Mon Nov 10 16:52:24 2003 UTC (21 years, 4 months ago) by greg
Sat Feb 22 02:07:30 2003 UTC (22 years, 1 month ago) by greg
Thu Apr 29 12:58:20 1993 UTC (31 years, 11 months ago) by greg
Changes since 2.4: +12 -4 lines
changed window name in ximage, so had to change it here, too
Fri Dec 11 18:23:17 1992 UTC (32 years, 3 months ago) by greg
bug fixes for 24-bit display under 4D (SGI)
Thu Mar 19 09:38:14 1992 UTC (33 years ago) by greg
Changes since 2.2: +1 -4 lines
added vfork.h include
Thu Dec 19 14:56:36 1991 UTC (33 years, 3 months ago) by greg
eliminated atof declaration for NeXT
Tue Nov 12 17:19:29 1991 UTC (33 years, 4 months ago) by greg
Diff to previous 1.10 , to selected 2.9
Mon Nov 11 15:09:45 1991 UTC (33 years, 4 months ago) by greg
Changes since 1.9: +24 -15 lines
Diff to previous 1.9 , to selected 2.9
Wed Jul 31 15:28:03 1991 UTC (33 years, 8 months ago) by greg
Changes since 1.8: +77 -23 lines
Diff to previous 1.8 , to selected 2.9
added -c option for color and writing of luminance values to image
Fri May 3 13:43:08 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.7 , to selected 2.9
changed how we wait for the window to come up
Fri May 3 12:50:45 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.6: +43 -12 lines
Diff to previous 1.6 , to selected 2.9
added call to ximage if xglaresrc can't find window
Fri May 3 10:06:04 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.5 , to selected 2.9
made xglaresrc work better with glare
Mon Apr 22 13:41:50 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.4: +6 -14 lines
Diff to previous 1.4 , to selected 2.9
fixed window finding under twm and other obnoxious window managers
Wed Apr 17 12:14:52 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.3 , to selected 2.9
changed pointer cursor
Wed Mar 20 12:59:27 1991 UTC (34 years ago) by greg
Diff to previous 1.2 , to selected 2.9
minor change in message
Tue Mar 19 16:59:46 1991 UTC (34 years ago) by greg
Diff to previous 1.1 , to selected 2.9
fixed bug in y calculation
Tue Mar 19 14:12:11 1991 UTC (34 years ago) by greg
Diff to selected 2.9
