fix(wrapBSDF): Allow for commas in Klems matrix data
feat(bsdf2klems, bsdf2ttree): added XML header comments copying useful information from SIR inputs
style(wrapBSDF): removed unused label
Fixed check for duplicate component
Added check for duplicate component input
Added "d" nickname for device type
Added -UU option to wrapBSDF to remove geometry file as well
Refactored bsdf2ttree for Yuv representation
Added required character type information.
Support for color BSDF rendering using Klems representation
Fixed bug in CIE (u',v') BSDF output
Fixes for Windows
Added -s CIE-u and -s CIE-v support
Turned missing WINDOW6 parameters into warning
Fixed return code
Removed default -a setting with -W
Added -c option to correct solid angle factor and other fixes
Added solid angle correction for Klems matrix input
Further tidying up of output
More fixes and indentation/alignment of XML tags
Added XML templates and fixed bugs for first running version
Numerous bug fixes, but still untested
