--- ray/src/util/wrapBSDF.c 2015/02/17 02:44:54 2.8
+++ ray/src/util/wrapBSDF.c 2015/02/20 18:07:10 2.11
@@ -1,5 +1,5 @@
#ifndef lint
-static const char RCSid[] = "$Id: wrapBSDF.c,v 2.8 2015/02/17 02:44:54 greg Exp $";
+static const char RCSid[] = "$Id: wrapBSDF.c,v 2.11 2015/02/20 18:07:10 greg Exp $";
#endif
* Wrap BSDF data in valid WINDOW XML file
@@ -66,7 +66,8 @@ int nfield_assign = 0;
/* data file(s) & spectra */
enum { DTtransForward, DTtransBackward, DTreflForward, DTreflBackward };
-enum { DSsolar=-1, DSnir=-2, DSxbar31=-3, DSvisible=-4, DSzbar31=-5 };
+enum { DSsolar=-1, DSnir=-2, DSxbar31=-3, DSvisible=-4, DSzbar31=-5,
+ DSuprime=-6, DSvprime=-7 };
#define MAXFILES 20
@@ -294,14 +295,12 @@ mat_assignments(const char *caller, const char *fn, ez
if (xml_input == win6_template)
for (i = 0; XMLfieldID[i].nickName[0]; i++)
if (XMLfieldID[i].win_need &&
- !ezxml_txt(ezxml_child(wtl,XMLfieldID[i].fullName))[0]) {
+ !ezxml_txt(ezxml_child(wtl,XMLfieldID[i].fullName))[0])
fprintf(stderr,
- "%s: missing required '%s' assignment for WINDOW <%s>\n",
+ "%s: warning - missing '%s' assignment for WINDOW <%s>\n",
caller, XMLfieldID[i].nickName,
XMLfieldID[i].fullName);
- return 0;
- return 1; /* no errors */
+ return 1;
/* Complete angle basis specification */
@@ -452,6 +451,16 @@ writeBSDFblock(const char *caller, struct s_dfile *df)
puts("\t\tSourceSpectrum>CIE Illuminant D65 1nm.ssp");
puts("\t\tASTM E308 1931 Z.dsp");
break;
+ case DSuprime:
+ puts("\t\tCIE-Z");
+ puts("\t\tSourceSpectrum>CIE Illuminant D65 1nm.ssp");
+ puts("\t\tASTM E308 1931 u.dsp");
+ break;
+ case DSvprime:
+ puts("\t\tASTM E308 1931 v.dsp");
+ break;
case DSsolar:
puts("\t\tSolar");
@@ -707,7 +716,7 @@ UsageExit(const char *pname)
fputs("Usage: ", stderr);
fputs(pname, stderr);
- fputs(" [-W][-a {kf|kh|kq|t3|t4}][-u unit][-g geom][-f 'x=string;y=string']", stderr);
+ fputs(" [-W][-c][-a {kf|kh|kq|t3|t4}][-u unit][-g geom][-f 'x=string;y=string']", stderr);
fputs(" [-s spectr][-tb inp][-tf inp][-rb inp][-rf inp]", stderr);
fputs(" [input.xml]\n", stderr);
exit(1);
@@ -775,7 +784,7 @@ main(int argc, char *argv[])
UsageExit(argv[0]);
continue;
case 'c': /* correct solid angle */
- correct_solid_angle ^= 1;
+ correct_solid_angle = 1;
continue;
case 't': /* transmission */
if (i >= argc-1)
@@ -833,6 +842,10 @@ main(int argc, char *argv[])
cur_spectrum = DSxbar31;
else if (!strcasecmp(argv[i], "CIE-Z"))
cur_spectrum = DSzbar31;
+ else if (!strcasecmp(argv[i], "CIE-u"))
+ cur_spectrum = DSuprime;
+ else if (!strcasecmp(argv[i], "CIE-v"))
+ cur_spectrum = DSvprime;
else if (!strcasecmp(argv[i], "NIR"))
cur_spectrum = DSnir;
else {
