--- ray/src/util/wrapBSDF.c 2015/02/16 19:11:28 2.7 +++ ray/src/util/wrapBSDF.c 2015/02/18 06:18:38 2.9 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: wrapBSDF.c,v 2.7 2015/02/16 19:11:28 greg Exp $"; +static const char RCSid[] = "$Id: wrapBSDF.c,v 2.9 2015/02/18 06:18:38 greg Exp $"; #endif /* * Wrap BSDF data in valid WINDOW XML file @@ -775,7 +775,7 @@ main(int argc, char *argv[]) UsageExit(argv[0]); continue; case 'c': /* correct solid angle */ - correct_solid_angle ^= 1; + correct_solid_angle = 1; continue; case 't': /* transmission */ if (i >= argc-1) @@ -818,7 +818,8 @@ main(int argc, char *argv[]) argv[i] = (char *)stdin_name; } data_file[ndataf].fname = argv[i]; - data_file[ndataf++].spectrum = cur_spectrum; + data_file[ndataf].spectrum = cur_spectrum; + ndataf++; continue; case 's': /* spectrum name or input file */ if (++i >= argc) @@ -880,8 +881,6 @@ doneOptions: /* get XML input */ } else { xml_input = argv[i]; } - if ((xml_input == win6_template) & (angle_basis == ABdefault)) - angle_basis = ABklemsFull; /* wrap it! */ return !wrapBSDF(argv[0]); }
