--- ray/src/util/wrapBSDF.c 2016/10/14 00:54:22 2.21 +++ ray/src/util/wrapBSDF.c 2022/09/07 18:55:39 2.27 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: wrapBSDF.c,v 2.21 2016/10/14 00:54:22 greg Exp $"; +static const char RCSid[] = "$Id: wrapBSDF.c,v 2.27 2022/09/07 18:55:39 greg Exp $"; #endif /* * Wrap BSDF data in valid WINDOW XML file @@ -27,7 +27,7 @@ const char legal_units[] = "meter|foot|inch|centimeter /* system materials & geometry */ const char *mgf_geometry = NULL; /* comment list */ -#define MAXCOMM 30 +#define MAXCOMM 80 const char *commlist[MAXCOMM]; int ncomm = 0; /* angle bases */ @@ -52,6 +52,7 @@ struct s_fieldID { } XMLfieldID[] = { {"m", 0, 1, "Manufacturer"}, {"n", 0, 1, "Name"}, + {"d", 0, 0, "DeviceType"}, {"c", 0, 0, "ThermalConductivity"}, {"ef", 0, 0, "EmissivityFront"}, {"eb", 0, 0, "EmissivityBack"}, @@ -63,13 +64,20 @@ struct s_fieldID { {"\0", 0, 0, NULL} /* terminator */ }; /* field assignments */ -#define MAXASSIGN 12 +#define MAXASSIGN 16 const char *field_assignment[MAXASSIGN]; int nfield_assign = 0; #define FASEP ';' /* data file(s) & spectra */ -enum { DTtransForward, DTtransBackward, DTreflForward, DTreflBackward }; +enum { DTransFront, DTransBack, DTreflFront, DTreflBack }; +static const char component_name[4][20] = { + "Transmission Front", + "Transmission Back", + "Reflection Front", + "Reflection Back" +}; + enum { DSsolar=-1, DSnir=-2, DSxbar31=-3, DSvisible=-4, DSzbar31=-5, DSuprime=-6, DSvprime=-7 }; @@ -121,6 +129,24 @@ static char basis_definition[][256] = { "\t\n", }; +/* Check that the last-added data file is unique */ +static int +check_new_data_file() +{ + int i = ndataf; + + while (i-- > 0) + if ((data_file[i].spectrum == data_file[ndataf].spectrum) & + (data_file[i].type == data_file[ndataf].type)) { + fprintf(stderr, + "%s: warning - ignoring duplicate component %s\n", + data_file[ndataf].fname, + component_name[data_file[i].type]); + return 0; + } + return 1; +} + /* Copy data from file descriptor to stdout and close */ static int copy_and_close(int fd) @@ -391,12 +417,12 @@ determine_angle_basis(const char *fn, ezxml_t wtl) return -1; } -/* Filter Klems angle basis, factoring out incident projected solid angle */ +/* Filter Klems angle data, factoring out incident projected solid angle */ static int filter_klems_matrix(FILE *fp) { const char *bn = klems_basis_name[angle_basis]; - int i, j, n = nabases; + int i, j, c, n = nabases; /* get angle basis */ while (n-- > 0) if (!strcasecmp(bn, abase_list[n].name)) @@ -408,8 +434,10 @@ filter_klems_matrix(FILE *fp) const double corr = 1./io_getohm(i, &abase_list[n]); for (j = 0; j < abase_list[n].nangles; j++) { double d; - if (fscanf(fp, "%lf", &d) != 1) + if (fscanf(fp, "%lf ", &d) != 1) return 0; + if ((c = getc(fp)) != ',') + ungetc(c, fp); if (d < -1e-3) { fputs("Negative BSDF data!\n", stderr); return 0; @@ -418,8 +446,8 @@ filter_klems_matrix(FILE *fp) } fputc('\n', stdout); } - while ((i = getc(fp)) != EOF) - if (!isspace(i)) { + while ((c = getc(fp)) != EOF) + if (!isspace(c)) { fputs("Unexpected data past EOF\n", stderr); return 0; } @@ -484,23 +512,7 @@ writeBSDFblock(const char *caller, struct s_dfile *df) } puts("\t\t"); fputs("\t\t\t", stdout); - switch (df->type) { - case DTtransForward: - fputs("Transmission Front", stdout); - break; - case DTtransBackward: - fputs("Transmission Back", stdout); - break; - case DTreflForward: - fputs("Reflection Front", stdout); - break; - case DTreflBackward: - fputs("Reflection Back", stdout); - break; - default: - fprintf(stderr, "%s: internal - bad BSDF type (%d)\n", caller, df->type); - return 0; - } + fputs(component_name[df->type], stdout); puts(""); switch (angle_basis) { case ABklemsFull: @@ -807,7 +819,7 @@ main(int argc, char *argv[]) argv[0]); return 1; } - if (strchr(argv[++i], '>') != NULL) { + if (strstr(argv[++i], "-->") != NULL) { fprintf(stderr, "%s: illegal character in comment\n", argv[0]); return 1; @@ -823,9 +835,9 @@ main(int argc, char *argv[]) return 1; } if (!strcmp(argv[i], "-tf")) - data_file[ndataf].type = DTtransForward; + data_file[ndataf].type = DTransFront; else if (!strcmp(argv[i], "-tb")) - data_file[ndataf].type = DTtransBackward; + data_file[ndataf].type = DTransBack; else UsageExit(argv[0]); if (!strcmp(argv[++i], "-")) { @@ -834,7 +846,7 @@ main(int argc, char *argv[]) } data_file[ndataf].fname = argv[i]; data_file[ndataf].spectrum = cur_spectrum; - ndataf++; + ndataf += check_new_data_file(); continue; case 'r': /* reflection */ if (i >= argc-1) @@ -845,9 +857,9 @@ main(int argc, char *argv[]) return 1; } if (!strcmp(argv[i], "-rf")) - data_file[ndataf].type = DTreflForward; + data_file[ndataf].type = DTreflFront; else if (!strcmp(argv[i], "-rb")) - data_file[ndataf].type = DTreflBackward; + data_file[ndataf].type = DTreflBack; else UsageExit(argv[0]); if (!strcmp(argv[++i], "-")) { @@ -856,7 +868,7 @@ main(int argc, char *argv[]) } data_file[ndataf].fname = argv[i]; data_file[ndataf].spectrum = cur_spectrum; - ndataf++; + ndataf += check_new_data_file(); continue; case 's': /* spectrum name or input file */ if (++i >= argc) @@ -909,7 +921,7 @@ main(int argc, char *argv[]) } break; } -doneOptions: /* get XML input */ + /* get XML input */ if (i >= argc) { if (xml_input == NULL) xml_input = def_template;
