root/radiance/ray/src/util/wrapBSDF.c
Tue Feb 14 19:58:37 2017 UTC (7 years, 1 month ago) by greg
CVS Tags: rad5R1, rad5R2
Diff to previous 2.21 , to selected 2.13
Added "d" nickname for device type
Fri Oct 14 00:54:22 2016 UTC (7 years, 5 months ago) by greg
Changes since 2.20: +3 -12 lines
Diff to previous 2.20 , to selected 2.13
Sun Mar 6 01:13:18 2016 UTC (8 years ago) by schorsch
Changes since 2.19: +4 -2 lines
Diff to previous 2.19 , to selected 2.13
Wed Feb 3 00:22:55 2016 UTC (8 years, 1 month ago) by greg
Changes since 2.18: +6 -2 lines
Diff to previous 2.18 , to selected 2.13
Added -UU option to wrapBSDF to remove geometry file as well
Tue Feb 2 22:34:00 2016 UTC (8 years, 1 month ago) by greg
Changes since 2.17: +14 -2 lines
Diff to previous 2.17 , to selected 2.13
Refactored bsdf2ttree for Yuv representation
Tue Feb 2 18:02:32 2016 UTC (8 years, 1 month ago) by greg
Diff to previous 2.16 , to selected 2.13
Fri May 29 07:45:48 2015 UTC (8 years, 10 months ago) by greg
Changes since 2.15: +21 -3 lines
Diff to previous 2.15 , to selected 2.13
Fri May 29 07:16:49 2015 UTC (8 years, 10 months ago) by greg
Added required character type information.
Thu Apr 2 16:40:32 2015 UTC (8 years, 11 months ago) by greg
Changes since 2.13: +8 -10 lines
Diff to previous 2.13
Support for color BSDF rendering using Klems representation
Revision 2.13 - (view) (download) (annotate) - [selected]
Wed Mar 25 22:50:48 2015 UTC (9 years ago) by greg
Diff to previous 2.12
Fixed bug in CIE (u',v') BSDF output
Wed Mar 4 17:42:54 2015 UTC (9 years ago) by greg
Changes since 2.11: +3 -1 lines
Fixes for Windows
Fri Feb 20 18:07:10 2015 UTC (9 years, 1 month ago) by greg
Changes since 2.10: +18 -3 lines
Added -s CIE-u and -s CIE-v support
Fri Feb 20 17:05:40 2015 UTC (9 years, 1 month ago) by greg
Changes since 2.9: +4 -6 lines
Turned missing WINDOW6 parameters into warning
Wed Feb 18 06:18:38 2015 UTC (9 years, 1 month ago) by greg
Fixed return code
Tue Feb 17 02:44:54 2015 UTC (9 years, 1 month ago) by greg
Changes since 2.7: +3 -4 lines
Removed default -a setting with -W
Mon Feb 16 19:11:28 2015 UTC (9 years, 1 month ago) by greg
Changes since 2.6: +35 -25 lines
Added -c option to correct solid angle factor and other fixes
Sun Feb 15 17:23:06 2015 UTC (9 years, 1 month ago) by greg
Changes since 2.5: +71 -3 lines
Added solid angle correction for Klems matrix input
Sat Feb 14 18:33:07 2015 UTC (9 years, 1 month ago) by greg
Changes since 2.4: +8 -2 lines
Further tidying up of output
Sat Feb 14 00:39:21 2015 UTC (9 years, 1 month ago) by greg
Changes since 2.3: +37 -19 lines
More fixes and indentation/alignment of XML tags
Fri Feb 13 20:49:59 2015 UTC (9 years, 1 month ago) by greg
Changes since 2.2: +58 -48 lines
Added XML templates and fixed bugs for first running version
Wed Feb 11 19:38:18 2015 UTC (9 years, 1 month ago) by greg
Changes since 2.1: +48 -28 lines
Numerous bug fixes, but still untested
Wed Feb 11 18:08:10 2015 UTC (9 years, 1 month ago) by greg
Diff to selected 2.13
Checking in first compilable version of new program
