root/radiance/ray/src/util/vwrays.c
Thu Jan 20 23:52:02 2005 UTC (19 years, 3 months ago) by greg
Changes since 3.10: +2 -1 lines
Diff to previous 3.10
Corrected center of pixels when given on input
Changes since 3.9: +35 -15 lines
Diff to previous 3.9
Continued ANSIfication.
Wed Oct 22 02:06:35 2003 UTC (20 years, 6 months ago) by greg
Changes since 3.8: +2 -4 lines
Diff to previous 3.8
Mon Oct 20 16:01:55 2003 UTC (20 years, 6 months ago) by greg
Changes since 3.7: +4 -4 lines
Diff to previous 3.7
Sun Jul 27 22:12:04 2003 UTC (20 years, 9 months ago) by schorsch
Diff to previous 3.6
Thu Jul 3 22:41:45 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 3.5: +2 -1 lines
Diff to previous 3.5
Changes since 3.4: +2 -2 lines
Diff to previous 3.4
Changes since 3.3: +62 -9 lines
Diff to previous 3.3
Fri Oct 17 10:42:45 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.2: +2 -1 lines
Diff to previous 3.2
added -ld option to output of -d
Fri Oct 17 10:13:56 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.1: +8 -3 lines
added aft view distance to ray output
Wed Jul 9 12:18:03 1997 UTC (26 years, 10 months ago) by gregl
