root/radiance/ray/src/util/vwrays.c
Tue Jun 3 21:31:51 2025 UTC (23 hours, 43 minutes ago) by greg
Changes since 3.25: +2 -4 lines
Diff to previous 3.25 , to selected 3.9
Fri Jan 12 17:29:10 2024 UTC (16 months, 3 weeks ago) by greg
Changes since 3.24: +18 -5 lines
Diff to previous 3.24 , to selected 3.9
perf(vwrays): Stratified samples when -pj > 0 and -c > 1
Sat Apr 9 17:18:08 2022 UTC (3 years, 1 month ago) by greg
Changes since 3.23: +12 -12 lines
Diff to previous 3.23 , to selected 3.9
fix(vwrays): No longer spits out -ld- with -d option, only -ld+
Sat Dec 4 16:29:29 2021 UTC (3 years, 6 months ago) by greg
Changes since 3.22: +7 -3 lines
Diff to previous 3.22 , to selected 3.9
feat(vwrays,rtpict): Added support for -pd option to sample depth-of-field
Fri Dec 3 17:22:28 2021 UTC (3 years, 6 months ago) by greg
Changes since 3.21: +19 -14 lines
Diff to previous 3.21 , to selected 3.9
feat(vwrays): added support for -c combined with -i option
Fri Jun 12 22:45:20 2020 UTC (4 years, 11 months ago) by greg
Changes since 3.20: +5 -5 lines
Diff to previous 3.20 , to selected 3.9
Changed behavior slightly when given a depth buffer
Thu Nov 7 23:20:29 2019 UTC (5 years, 6 months ago) by greg
Changes since 3.19: +3 -7 lines
Diff to previous 3.19 , to selected 3.9
Mon Mar 4 22:41:20 2019 UTC (6 years, 3 months ago) by greg
Changes since 3.18: +7 -1 lines
Diff to previous 3.18 , to selected 3.9
Added check for out-of-range input pixels when reading from depth buffer
Thu Aug 18 00:52:48 2016 UTC (8 years, 9 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 3.17: +3 -3 lines
Diff to previous 3.17 , to selected 3.9
Thu Jun 14 05:19:05 2012 UTC (12 years, 11 months ago) by greg
Changes since 3.16: +12 -5 lines
Diff to previous 3.16 , to selected 3.9
Added -c option to repeat pixels
Sat Aug 20 20:57:52 2011 UTC (13 years, 9 months ago) by greg
Changes since 3.15: +9 -2 lines
Diff to previous 3.15 , to selected 3.9
Added -u option to vwrays for unbuffered output with -i
Tue Aug 16 02:22:50 2011 UTC (13 years, 9 months ago) by greg
Diff to previous 3.14 , to selected 3.9
Minor fix
Mon Jun 22 00:12:04 2009 UTC (15 years, 11 months ago) by greg
Changes since 3.13: +1 -8 lines
Diff to previous 3.13 , to selected 3.9
Removed unnecessary and problematic error check
Sun May 7 15:44:28 2006 UTC (19 years, 1 month ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 3.12: +3 -1 lines
Diff to previous 3.12 , to selected 3.9
Made missing calls to SET_FILE_BINARY() for Windows
Mon Sep 19 04:26:09 2005 UTC (19 years, 8 months ago) by greg
Changes since 3.11: +31 -7 lines
Diff to previous 3.11 , to selected 3.9
Thu Jan 20 23:52:02 2005 UTC (20 years, 4 months ago) by greg
Changes since 3.10: +2 -1 lines
Diff to previous 3.10 , to selected 3.9
Corrected center of pixels when given on input
Fri Mar 26 23:34:23 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 3.9: +35 -15 lines
Diff to previous 3.9
Continued ANSIfication.
Revision 3.9 - (view) (download) (annotate) - [selected]
Wed Oct 22 02:06:35 2003 UTC (21 years, 7 months ago) by greg
Changes since 3.8: +2 -4 lines
Diff to previous 3.8
Mon Oct 20 16:01:55 2003 UTC (21 years, 7 months ago) by greg
Changes since 3.7: +4 -4 lines
Diff to previous 3.7 , to selected 3.9
Sun Jul 27 22:12:04 2003 UTC (21 years, 10 months ago) by schorsch
Diff to previous 3.6 , to selected 3.9
Thu Jul 3 22:41:45 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.5: +2 -1 lines
Diff to previous 3.5 , to selected 3.9
Thu Jun 26 00:58:11 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.4: +2 -2 lines
Diff to previous 3.4 , to selected 3.9
Sat Feb 22 02:07:30 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.3: +62 -9 lines
Diff to previous 3.3 , to selected 3.9
Fri Oct 17 10:42:45 1997 UTC (27 years, 7 months ago) by gregl
Changes since 3.2: +2 -1 lines
Diff to previous 3.2 , to selected 3.9
added -ld option to output of -d
Fri Oct 17 10:13:56 1997 UTC (27 years, 7 months ago) by gregl
Changes since 3.1: +8 -3 lines
Diff to previous 3.1 , to selected 3.9
added aft view distance to ray output
Wed Jul 9 12:18:03 1997 UTC (27 years, 11 months ago) by gregl
Diff to selected 3.9
