root/radiance/ray/src/util/vwrays.c
Thu Jun 14 05:19:05 2012 UTC (13 years, 2 months ago) by greg
Changes since 3.16: +12 -5 lines
Diff to previous 3.16
Added -c option to repeat pixels
Sat Aug 20 20:57:52 2011 UTC (13 years, 11 months ago) by greg
Changes since 3.15: +9 -2 lines
Diff to previous 3.15
Added -u option to vwrays for unbuffered output with -i
Tue Aug 16 02:22:50 2011 UTC (14 years ago) by greg
Diff to previous 3.14
Minor fix
Mon Jun 22 00:12:04 2009 UTC (16 years, 1 month ago) by greg
Changes since 3.13: +1 -8 lines
Diff to previous 3.13
Removed unnecessary and problematic error check
Sun May 7 15:44:28 2006 UTC (19 years, 3 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 3.12: +3 -1 lines
Diff to previous 3.12
Made missing calls to SET_FILE_BINARY() for Windows
Mon Sep 19 04:26:09 2005 UTC (19 years, 10 months ago) by greg
Changes since 3.11: +31 -7 lines
Diff to previous 3.11
Thu Jan 20 23:52:02 2005 UTC (20 years, 6 months ago) by greg
Changes since 3.10: +2 -1 lines
Diff to previous 3.10
Corrected center of pixels when given on input
Fri Mar 26 23:34:23 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 3.9: +35 -15 lines
Diff to previous 3.9
Continued ANSIfication.
Wed Oct 22 02:06:35 2003 UTC (21 years, 9 months ago) by greg
Changes since 3.8: +2 -4 lines
Diff to previous 3.8
Mon Oct 20 16:01:55 2003 UTC (21 years, 9 months ago) by greg
Changes since 3.7: +4 -4 lines
Diff to previous 3.7
Sun Jul 27 22:12:04 2003 UTC (22 years ago) by schorsch
Diff to previous 3.6
Thu Jul 3 22:41:45 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 3.5: +2 -1 lines
Diff to previous 3.5
Thu Jun 26 00:58:11 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 3.4: +2 -2 lines
Diff to previous 3.4
Sat Feb 22 02:07:30 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.3: +62 -9 lines
Diff to previous 3.3
Fri Oct 17 10:42:45 1997 UTC (27 years, 10 months ago) by gregl
Changes since 3.2: +2 -1 lines
Diff to previous 3.2
added -ld option to output of -d
Fri Oct 17 10:13:56 1997 UTC (27 years, 10 months ago) by gregl
Changes since 3.1: +8 -3 lines
added aft view distance to ray output
Wed Jul 9 12:18:03 1997 UTC (28 years, 1 month ago) by gregl
