root/radiance/ray/src/util/vwrays.c
Sun May 7 15:44:28 2006 UTC (19 years, 2 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 3.12: +3 -1 lines
Diff to previous 3.12 , to selected 3.5
Made missing calls to SET_FILE_BINARY() for Windows
Mon Sep 19 04:26:09 2005 UTC (19 years, 10 months ago) by greg
Changes since 3.11: +31 -7 lines
Diff to previous 3.11 , to selected 3.5
Thu Jan 20 23:52:02 2005 UTC (20 years, 6 months ago) by greg
Changes since 3.10: +2 -1 lines
Diff to previous 3.10 , to selected 3.5
Corrected center of pixels when given on input
Fri Mar 26 23:34:23 2004 UTC (21 years, 3 months ago) by schorsch
Changes since 3.9: +35 -15 lines
Diff to previous 3.9 , to selected 3.5
Continued ANSIfication.
Wed Oct 22 02:06:35 2003 UTC (21 years, 9 months ago) by greg
Changes since 3.8: +2 -4 lines
Diff to previous 3.8 , to selected 3.5
Mon Oct 20 16:01:55 2003 UTC (21 years, 9 months ago) by greg
Changes since 3.7: +4 -4 lines
Diff to previous 3.7 , to selected 3.5
Sun Jul 27 22:12:04 2003 UTC (21 years, 11 months ago) by schorsch
Diff to previous 3.6 , to selected 3.5
Thu Jul 3 22:41:45 2003 UTC (22 years ago) by schorsch
Changes since 3.5: +2 -1 lines
Diff to previous 3.5
Revision 3.5 - (view) (download) (annotate) - [selected]
Thu Jun 26 00:58:11 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 3.4: +2 -2 lines
Diff to previous 3.4
Sat Feb 22 02:07:30 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.3: +62 -9 lines
Diff to previous 3.3 , to selected 3.5
Fri Oct 17 10:42:45 1997 UTC (27 years, 9 months ago) by gregl
Changes since 3.2: +2 -1 lines
Diff to previous 3.2 , to selected 3.5
added -ld option to output of -d
Fri Oct 17 10:13:56 1997 UTC (27 years, 9 months ago) by gregl
Changes since 3.1: +8 -3 lines
Diff to previous 3.1 , to selected 3.5
added aft view distance to ray output
Wed Jul 9 12:18:03 1997 UTC (28 years ago) by gregl
Diff to selected 3.5
