root/radiance/ray/src/util/vwrays.c
Thu Jan 20 23:52:02 2005 UTC (19 years, 10 months ago) by greg
Changes since 3.10: +2 -1 lines
Diff to previous 3.10 , to selected 3.1
Corrected center of pixels when given on input
Fri Mar 26 23:34:23 2004 UTC (20 years, 8 months ago) by schorsch
Changes since 3.9: +35 -15 lines
Diff to previous 3.9 , to selected 3.1
Continued ANSIfication.
Wed Oct 22 02:06:35 2003 UTC (21 years, 1 month ago) by greg
Changes since 3.8: +2 -4 lines
Diff to previous 3.8 , to selected 3.1
Mon Oct 20 16:01:55 2003 UTC (21 years, 1 month ago) by greg
Changes since 3.7: +4 -4 lines
Diff to previous 3.7 , to selected 3.1
Sun Jul 27 22:12:04 2003 UTC (21 years, 4 months ago) by schorsch
Diff to previous 3.6 , to selected 3.1
Thu Jul 3 22:41:45 2003 UTC (21 years, 5 months ago) by schorsch
Changes since 3.5: +2 -1 lines
Diff to previous 3.5 , to selected 3.1
Thu Jun 26 00:58:11 2003 UTC (21 years, 5 months ago) by schorsch
Changes since 3.4: +2 -2 lines
Diff to previous 3.4 , to selected 3.1
Sat Feb 22 02:07:30 2003 UTC (21 years, 9 months ago) by greg
Changes since 3.3: +62 -9 lines
Diff to previous 3.3 , to selected 3.1
Fri Oct 17 10:42:45 1997 UTC (27 years, 1 month ago) by gregl
Changes since 3.2: +2 -1 lines
Diff to previous 3.2 , to selected 3.1
added -ld option to output of -d
Fri Oct 17 10:13:56 1997 UTC (27 years, 1 month ago) by gregl
Changes since 3.1: +8 -3 lines
added aft view distance to ray output
Revision 3.1 - (view) (download) (annotate) - [selected]
Wed Jul 9 12:18:03 1997 UTC (27 years, 5 months ago) by gregl
