Added -c option to repeat pixels
Added -u option to vwrays for unbuffered output with -i
Minor fix
Removed unnecessary and problematic error check
Made missing calls to SET_FILE_BINARY() for Windows
Corrected center of pixels when given on input
Continued ANSIfication.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added -ld option to output of -d
added aft view distance to ray output
