| Revision: | 3.2 |
| Committed: | Fri Nov 19 23:00:49 2004 UTC (20 years, 11 months ago) by greg |
| Content type: | application/x-csh |
| Branch: | MAIN |
| CVS Tags: | rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, HEAD |
| Changes since 3.1: | +4 -1 lines |
| Log Message: | Added check to vinfo to insure that header ends with empty line |
| # | Content |
| 1 | #!/bin/csh -f |
| 2 | # RCSid: $Id: vinfo.csh,v 3.1 2003/02/22 02:07:30 greg Exp $ |
| 3 | # |
| 4 | # Edit information header in Radiance file |
| 5 | # |
| 6 | set plist=() |
| 7 | set ilist=() |
| 8 | foreach f ($*) |
| 9 | if (! -f $f:q) then |
| 10 | echo "${f}: no such file or directory" |
| 11 | continue |
| 12 | endif |
| 13 | if (! -w $f:q) then |
| 14 | echo "$f is read-only" |
| 15 | sleep 1 |
| 16 | continue |
| 17 | endif |
| 18 | set info="$f.info" |
| 19 | getinfo < $f:q > $info:q |
| 20 | set plist=($plist:q $f:q) |
| 21 | set ilist=($ilist:q $info:q) |
| 22 | end |
| 23 | vi $ilist:q |
| 24 | set i=1 |
| 25 | while ( $i <= $#plist ) |
| 26 | set f=$plist[$i]:q |
| 27 | set info=$ilist[$i]:q |
| 28 | if ("`tail -1 $info:q`" != "") then |
| 29 | echo "" >> $info:q |
| 30 | endif |
| 31 | getinfo < $f:q | cmp -s - $info:q |
| 32 | if ($status != 0) then |
| 33 | getinfo - < $f:q >> $info:q |
| 34 | mv $info:q $f:q |
| 35 | else |
| 36 | rm $info:q |
| 37 | endif |
| 38 | @ i++ |
| 39 | end |
