root/radiance/ray/src/util/trad.wsh
Revision: 2.2
Committed: Fri Oct 28 10:43:38 1994 UTC (30 years, 7 months ago) by greg
fixed size defaults for smaller dispaly
1 #!/usr/local/bin/wish -f
2 # SCCSid "$SunId$ LBL"
3 #
4 # TCL/TK-based Rad Input File Editor
5 #
6
7 # Insert our autoload directory (may require local system modification)
8
9 set radlib /usr/local/lib/ray/tcl
10 set helplib $radlib
11
12 set auto_path [linsert $auto_path 0 $radlib]
13
14 # Create required procedures
15
16 proc modified {} { # check for radvar modification
17 global radvar oldradvar
18 if {! [info exists oldradvar]} {return 0}
19 foreach n [array names oldradvar] {
20 if {! [info exists radvar($n)] ||
21 "$radvar($n)" != "$oldradvar($n)"} {
22 return 1
23 }
24 }
25 return 0
26 }
27
28 proc chksave {} { # check if RIF is saved and accost user if not
29 global readonly rifname oldradvar curmess
30 if $readonly {
31 set warnmess "You have modified variables, but the file\
32 \"[file tail $rifname]\" was opened read-only.
33 Do you wish to save this information somehow?"
34 set yesmess {Go to File Screen}
35 } else {
36 set warnmess "The file \"[file tail $rifname]\" has been\
37 modified since it was last saved.
38 Do you wish to save it now?"
39 set yesmess {Save File}
40 }
41 if [modified] {
42 switch [tk_dialog .dlg {File Modified} $warnmess \
43 warning 0 $yesmess {Discard Changes} \
44 {Cancel Operation}] {
45 1 { return 1 }
46 2 { return 0 }
47 }
48 if $readonly {
49 .file invoke
50 set curmess {Rename file or uncheck read-only to save.}
51 return 0
52 } else {
53 catch {unset oldradvar}
54 save_vars $rifname
55 }
56 } else { return 1 }
57 }
58
59 # Set global variable default values
60
61 set readonly 0
62 set alldone 0
63 set rifname [pwd]/
64
65 # Propogate essential variables
66
67 proc setrname {name elem op} {
68 global rifname
69 wm title . $rifname
70 wm iconname . [file tail $rifname]
71 }
72 trace variable rifname w setrname
73
74 # Make main window frames
75
76 frame .upper -geometry 640x410
77 pack .upper -side top
78 frame .upper.right -geometry 120x410
79 place .upper.right -relx .98 -rely 0 -anchor ne
80 message .mess -relief ridge -font fixed -textvariable curmess \
81 -anchor nw -width 620
82 pack .mess -side top -expand yes -fill both
83 helplink .mess trad trad messages
84
85 # Make mode buttons
86
87 proc changescreen {} { # switch screen according to curmode
88 global curscreen curmode curmess
89 if [info exists curscreen] {
90 if {"$curmode" == "$curscreen"} {return}
91 destroy .upper.left
92 do_$curscreen done
93 set curmess {}
94 }
95 set curscreen $curmode
96 do_$curscreen .upper.left
97 .upper.left configure -geometry 520x410
98 place .upper.left -x 0 -y 0
99 }
100
101 label .upper.right.title -text "- TRAD -"
102 pack .upper.right.title -side top -pady 10
103
104 proc setbutt v {
105 radiobutton .$v -text [string toupper $v] \
106 -variable curmode -value $v \
107 -width 9 -relief groove -anchor w \
108 -command changescreen
109 pack .$v -in .upper.right -side top -pady 5
110 helplink .$v trad $v intro
111 }
112
113 setbutt file
114 setbutt scene
115 setbutt zone
116 setbutt views
117 setbutt options
118 setbutt action
119 setbutt results
120 rename setbutt {}
121 button .upper.right.help -text HELP -width 9 \
122 -command "gethelp trad trad intro"
123 pack .upper.right.help -side top -pady 10 -anchor se
124 helplink .upper.right.help trad trad help
125 button .upper.right.quit -text QUIT \
126 -command {if [chksave] {destroy .}} -width 9
127 pack .upper.right.quit -side top -pady 10 -anchor se
128 helplink .upper.right.quit trad trad quit
129
130 wm minsize . 640 460
131 wm iconbitmap . @$radlib/trad.icon
132
133 proc gotfile {{o 1}} { # set file possession state
134 global oldradvar radvar
135 catch {unset oldradvar}
136 if $o {
137 set mode normal
138 foreach n [array names radvar] {
139 set oldradvar($n) $radvar($n)
140 }
141 } else {
142 set mode disabled
143 }
144 foreach b {scene zone views options action results} {
145 .$b configure -state $mode
146 }
147 }
148
149 # Decide where to go and start
150
151 if {[llength $argv] == 0} {
152 gotfile 0
153 set curmess "Choose a Radiance project file."
154 .file invoke
155 } elseif {[llength $argv] == 1} {
156 cd [file dirname $argv]
157 set curfile [file tail $argv]
158 if {! [file exists $curfile]} {
159 newnew $argv
160 .scene invoke
161 } elseif {[newload $curfile]} {
162 if $alldone {
163 set curmess "All renderings are finished."
164 .results invoke
165 } else {
166 .action invoke
167 }
168 } else {
169 .file invoke
170 }
171 } else {
172 puts stderr {Usage: trad [rifname]}
173 exit 1
174 }
