--- ray/src/util/trad.wsh 1994/11/28 12:15:18 2.8 +++ ray/src/util/trad.wsh 1994/12/05 09:50:43 2.9 @@ -27,18 +27,18 @@ proc modified {} { # check for radvar modification proc chksave {} { # check if RIF is saved and accost user if not global readonly rifname oldradvar curmess - if $readonly { - set warnmess "You have modified variables, but the file\ -\"[file tail $rifname]\" was opened read-only. + if [modified] { + if $readonly { + set warnmess "You have modified variables, but the\ +file \"[file tail $rifname]\" was opened read-only. Do you wish to save this information somehow?" - set yesmess {Go to File Screen} - } else { - set warnmess "The file \"[file tail $rifname]\" has been\ -modified since it was last saved. +set yesmess {Go to File Screen} + } else { + set warnmess "The file \"[file tail $rifname]\" has\ +been modified since it was last saved. Do you wish to save it now?" - set yesmess {Save File} - } - if [modified] { + set yesmess {Save File} + } switch [tk_dialog .dlg {File Modified} $warnmess \ warning 0 $yesmess {Discard Changes} \ {Cancel Operation}] { @@ -52,8 +52,10 @@ Do you wish to save it now?" } elseif {[save_vars $rifname]} { gotfile 1 return 1 - } else { return 0 } - } else { return 1 } + } + return 0 + } + return 1 } # Set global variable default values
