1 |
#!/usr/local/bin/wish4.0 |
2 |
# SCCSid "$SunId$ LBL" |
3 |
4 |
# TCL/TK-based Rad Input File Editor |
5 |
6 |
7 |
# Insert our autoload directory (may require local system modification) |
8 |
9 |
set radlib /usr/local/lib/ray/tcl |
10 |
set helplib $radlib |
11 |
12 |
set auto_path [linsert $auto_path 0 $radlib] |
13 |
14 |
# Create required procedures |
15 |
16 |
proc modified {} { # check for radvar modification |
17 |
global radvar oldradvar |
18 |
if {! [info exists oldradvar]} {return 0} |
19 |
foreach n [array names oldradvar] { |
20 |
if {! [info exists radvar($n)] || |
21 |
"$radvar($n)" != "$oldradvar($n)"} { |
22 |
return 1 |
23 |
24 |
25 |
return 0 |
26 |
27 |
28 |
proc chksave {} { # check if RIF is saved and accost user if not |
29 |
global readonly rifname oldradvar curmess |
30 |
if [modified] { |
31 |
if $readonly { |
32 |
set warnmess "You have modified variables, but the\ |
33 |
file \"[file tail $rifname]\" was opened read-only. |
34 |
Do you wish to save this information somehow?" |
35 |
set yesmess {Go to File Screen} |
36 |
} else { |
37 |
set warnmess "The file \"[file tail $rifname]\" has\ |
38 |
been modified since it was last saved. |
39 |
Do you wish to save it now?" |
40 |
set yesmess {Save File} |
41 |
42 |
switch [tk_dialog .dlg {File Modified} $warnmess \ |
43 |
warning 0 $yesmess {Discard Changes} \ |
44 |
{Cancel Operation}] { |
45 |
1 { return 1 } |
46 |
2 { return 0 } |
47 |
48 |
if $readonly { |
49 |
set curmess {Rename file or uncheck read-only to save.} |
50 |
.file invoke |
51 |
return 0 |
52 |
} elseif {[save_vars $rifname]} { |
53 |
gotfile 1 |
54 |
return 1 |
55 |
56 |
return 0 |
57 |
58 |
return 1 |
59 |
60 |
61 |
# Set global variable default values |
62 |
63 |
set readonly 0 |
64 |
set alldone 0 |
65 |
set rifname [pwd]/ |
66 |
67 |
# Propogate essential variables |
68 |
69 |
proc setrname {name elem op} { |
70 |
global rifname |
71 |
wm title . $rifname |
72 |
wm iconname . [file tail $rifname] |
73 |
74 |
trace variable rifname w setrname |
75 |
76 |
# Make main window frames |
77 |
78 |
set smallscrn [expr [winfo screenwidth .] < 830] |
79 |
80 |
message .mess -relief ridge -font fixed -textvariable curmess -anchor nw |
81 |
if $smallscrn { |
82 |
frame .upper -width 640 -height 410 |
83 |
frame .upper.right -width 120 -height 410 |
84 |
.mess configure -width 640 |
85 |
} else { |
86 |
frame .upper -width 830 -height 410 |
87 |
frame .upper.right -width 130 -height 410 |
88 |
.mess configure -width 830 |
89 |
90 |
pack .upper -side top |
91 |
place .upper.right -relx .98 -rely 0 -anchor ne |
92 |
pack .mess -side top -expand yes -fill both |
93 |
helplink .mess trad trad messages |
94 |
. configure -cursor top_left_arrow |
95 |
96 |
# Make mode buttons |
97 |
98 |
proc changescreen {} { # switch screen according to curmode |
99 |
global curscreen curmode curmess smallscrn |
100 |
if [info exists curscreen] { |
101 |
if {"$curmode" == "$curscreen"} {return} |
102 |
destroy .upper.left |
103 |
do_$curscreen done |
104 |
set curmess {} |
105 |
106 |
set curscreen $curmode |
107 |
do_$curscreen .upper.left |
108 |
if $smallscrn { |
109 |
.upper.left configure -width 520 -height 410 |
110 |
} else { |
111 |
.upper.left configure -width 700 -height 410 |
112 |
113 |
place .upper.left -x 0 -y 0 |
114 |
115 |
116 |
label .upper.right.title -text "- TRAD -" |
117 |
pack .upper.right.title -side top -pady 10 |
118 |
119 |
proc setbutt v { |
120 |
radiobutton .$v -text [string toupper $v] \ |
121 |
-variable curmode -value $v \ |
122 |
-width 9 -relief groove -anchor w \ |
123 |
-command changescreen |
124 |
pack .$v -in .upper.right -side top -pady 5 |
125 |
helplink .$v trad $v intro |
126 |
127 |
128 |
setbutt file |
129 |
setbutt scene |
130 |
setbutt zone |
131 |
setbutt views |
132 |
setbutt options |
133 |
setbutt action |
134 |
setbutt results |
135 |
rename setbutt {} |
136 |
button .upper.right.help -text HELP -width 9 \ |
137 |
-command "gethelp trad trad intro" |
138 |
pack .upper.right.help -side top -pady 5 -anchor se |
139 |
helplink .upper.right.help trad trad help |
140 |
button .upper.right.quit -text QUIT \ |
141 |
-command {if [chksave] {destroy .}} -width 9 |
142 |
pack .upper.right.quit -side top -pady 5 -anchor se |
143 |
helplink .upper.right.quit trad trad quit |
144 |
145 |
if $smallscrn { |
146 |
wm minsize . 640 460 |
147 |
wm maxsize . 640 512 |
148 |
} else { |
149 |
wm minsize . 830 460 |
150 |
wm maxsize . 830 512 |
151 |
152 |
wm iconbitmap . @$radlib/trad.icon |
153 |
154 |
proc gotfile {{o 1}} { # set file possession state |
155 |
global oldradvar radvar |
156 |
catch {unset oldradvar} |
157 |
if $o { |
158 |
set mode normal |
159 |
foreach n [array names radvar] { |
160 |
set oldradvar($n) $radvar($n) |
161 |
162 |
} else { |
163 |
set mode disabled |
164 |
.file invoke |
165 |
166 |
foreach b {scene zone views options action results} { |
167 |
.$b configure -state $mode |
168 |
169 |
170 |
171 |
# Decide where to go and start |
172 |
173 |
if {[llength $argv] == 0} { |
174 |
set curmess "Choose a Radiance project file." |
175 |
gotfile 0 |
176 |
} elseif {[llength $argv] == 1} { |
177 |
cd [file dirname $argv] |
178 |
set curfile [file tail $argv] |
179 |
if {! [file exists $curfile]} { |
180 |
newnew $curfile |
181 |
.scene invoke |
182 |
} elseif {[newload $curfile]} { |
183 |
if $alldone { |
184 |
set curmess "All renderings are finished." |
185 |
.results invoke |
186 |
} else { |
187 |
.action invoke |
188 |
189 |
} else { |
190 |
.file invoke |
191 |
192 |
} else { |
193 |
puts stderr {Usage: trad [rifname]} |
194 |
exit 1 |
195 |
