root/radiance/ray/src/util/trad.wsh
Wed Oct 26 20:06:17 2011 UTC (12 years, 7 months ago) by greg
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2
Changes since 2.15: +4 -2 lines
Diff to previous 2.15 , to selected 2.14
Made a few updates to trad
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0
Diff to previous 2.14
Fri May 17 13:53:09 1996 UTC (28 years ago) by greg
Changes since 2.13: +8 -0 lines
Diff to previous 2.13
moved globbing patterns to trad.wsh main file
Tue Oct 17 21:28:21 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.12: +6 -3 lines
Thu Oct 5 13:16:22 1995 UTC (28 years, 7 months ago) by greg
made sure to set gotfile 0 before going to hopeful load
Wed Sep 20 12:56:00 1995 UTC (28 years, 8 months ago) by greg
Mon Jul 24 13:31:26 1995 UTC (28 years, 10 months ago) by greg
Changes since 2.9: +6 -6 lines
changed -geometry specification to -width -height
Mon Dec 5 09:50:43 1994 UTC (29 years, 5 months ago) by greg
Changes since 2.8: +14 -12 lines
minor optimization in chksave
Mon Nov 28 12:15:18 1994 UTC (29 years, 6 months ago) by greg
minor change
Sun Nov 6 11:45:08 1994 UTC (29 years, 6 months ago) by greg
fixed bug in chksave that failed for second modified check
Sat Nov 5 09:43:29 1994 UTC (29 years, 6 months ago) by greg
fixed minor bug in opening new file from command line
Mon Oct 31 11:35:28 1994 UTC (29 years, 7 months ago) by greg
Changes since 2.4: +5 -2 lines
fixed sizing of message window
Fri Oct 28 19:35:02 1994 UTC (29 years, 7 months ago) by greg
Changes since 2.3: +1 -0 lines
added explicit cursor assignment for main window
Fri Oct 28 17:55:06 1994 UTC (29 years, 7 months ago) by greg
Changes since 2.2: +20 -5 lines
made windows compatible with large AND small screens
Fri Oct 28 10:43:38 1994 UTC (29 years, 7 months ago) by greg
fixed size defaults for smaller dispaly
Thu Oct 27 15:56:13 1994 UTC (29 years, 7 months ago) by greg
Diff to selected 2.14
