1 |
#!/usr/local/bin/wish4.0 |
2 |
# RCSid: $Id: trad.wsh,v 2.15 2003/02/22 02:07:30 greg Exp $ |
3 |
# the next line restarts using wish in case of shell execution \ |
4 |
exec wish "$0" "$@" |
5 |
6 |
# TCL/TK-based Rad Input File Editor |
7 |
8 |
9 |
# Insert our autoload directory (may require local system modification) |
10 |
11 |
set radlib /usr/local/lib/ray/tcl |
12 |
set helplib $radlib |
13 |
14 |
set auto_path [linsert $auto_path 0 $radlib] |
15 |
16 |
# Assign global globbing variables |
17 |
18 |
set myglob(rif) *.rif |
19 |
set myglob(materials) *.mat |
20 |
set myglob(illum) *.rad |
21 |
set myglob(scene) *.rad |
22 |
set myglob(objects) * |
23 |
24 |
# Create required procedures |
25 |
26 |
proc modified {} { # check for radvar modification |
27 |
global radvar oldradvar |
28 |
if {! [info exists oldradvar]} {return 0} |
29 |
foreach n [array names oldradvar] { |
30 |
if {! [info exists radvar($n)] || |
31 |
"$radvar($n)" != "$oldradvar($n)"} { |
32 |
return 1 |
33 |
34 |
35 |
return 0 |
36 |
37 |
38 |
proc chksave {} { # check if RIF is saved and accost user if not |
39 |
global readonly rifname oldradvar curmess |
40 |
if [modified] { |
41 |
if $readonly { |
42 |
set warnmess "You have modified variables, but the\ |
43 |
file \"[file tail $rifname]\" was opened read-only. |
44 |
Do you wish to save this information somehow?" |
45 |
set yesmess {Go to File Screen} |
46 |
} else { |
47 |
set warnmess "The file \"[file tail $rifname]\" has\ |
48 |
been modified since it was last saved. |
49 |
Do you wish to save it now?" |
50 |
set yesmess {Save File} |
51 |
52 |
switch [tk_dialog .dlg {File Modified} $warnmess \ |
53 |
warning 0 $yesmess {Discard Changes} \ |
54 |
{Cancel Operation}] { |
55 |
1 { return 1 } |
56 |
2 { return 0 } |
57 |
58 |
if $readonly { |
59 |
set curmess {Rename file or uncheck read-only to save.} |
60 |
.file invoke |
61 |
return 0 |
62 |
} elseif {[save_vars $rifname]} { |
63 |
gotfile 1 |
64 |
return 1 |
65 |
66 |
return 0 |
67 |
68 |
return 1 |
69 |
70 |
71 |
# Set global variable default values |
72 |
73 |
set readonly 0 |
74 |
set alldone 0 |
75 |
set rifname [pwd]/ |
76 |
77 |
# Propogate essential variables |
78 |
79 |
proc setrname {name elem op} { |
80 |
global rifname |
81 |
wm title . $rifname |
82 |
wm iconname . [file tail $rifname] |
83 |
84 |
trace variable rifname w setrname |
85 |
86 |
# Make main window frames |
87 |
88 |
set smallscrn [expr [winfo screenwidth .] < 830] |
89 |
90 |
message .mess -relief ridge -font fixed -textvariable curmess -anchor nw |
91 |
if $smallscrn { |
92 |
frame .upper -width 640 -height 410 |
93 |
frame .upper.right -width 120 -height 410 |
94 |
.mess configure -width 640 |
95 |
} else { |
96 |
frame .upper -width 830 -height 410 |
97 |
frame .upper.right -width 130 -height 410 |
98 |
.mess configure -width 830 |
99 |
100 |
pack .upper -side top |
101 |
place .upper.right -relx .98 -rely 0 -anchor ne |
102 |
pack .mess -side top -expand yes -fill both |
103 |
helplink .mess trad trad messages |
104 |
. configure -cursor top_left_arrow |
105 |
106 |
# Make mode buttons |
107 |
108 |
proc changescreen {} { # switch screen according to curmode |
109 |
global curscreen curmode curmess smallscrn |
110 |
if [info exists curscreen] { |
111 |
if {"$curmode" == "$curscreen"} {return} |
112 |
destroy .upper.left |
113 |
do_$curscreen done |
114 |
set curmess {} |
115 |
116 |
set curscreen $curmode |
117 |
do_$curscreen .upper.left |
118 |
if $smallscrn { |
119 |
.upper.left configure -width 520 -height 410 |
120 |
} else { |
121 |
.upper.left configure -width 700 -height 410 |
122 |
123 |
place .upper.left -x 0 -y 0 |
124 |
125 |
126 |
label .upper.right.title -text "- TRAD -" |
127 |
pack .upper.right.title -side top -pady 10 |
128 |
129 |
proc setbutt v { |
130 |
radiobutton .$v -text [string toupper $v] \ |
131 |
-variable curmode -value $v \ |
132 |
-width 10 -relief groove -anchor w \ |
133 |
-command changescreen |
134 |
pack .$v -in .upper.right -side top -pady 5 |
135 |
helplink .$v trad $v intro |
136 |
137 |
138 |
setbutt file |
139 |
setbutt scene |
140 |
setbutt zone |
141 |
setbutt views |
142 |
setbutt options |
143 |
setbutt action |
144 |
setbutt results |
145 |
rename setbutt {} |
146 |
button .upper.right.help -text HELP -width 9 \ |
147 |
-command "gethelp trad trad intro" |
148 |
pack .upper.right.help -side top -pady 5 -anchor se |
149 |
helplink .upper.right.help trad trad help |
150 |
button .upper.right.quit -text QUIT \ |
151 |
-command {if [chksave] {destroy .}} -width 9 |
152 |
pack .upper.right.quit -side top -pady 5 -anchor se |
153 |
helplink .upper.right.quit trad trad quit |
154 |
155 |
if $smallscrn { |
156 |
wm minsize . 640 460 |
157 |
wm maxsize . 640 512 |
158 |
} else { |
159 |
wm minsize . 830 460 |
160 |
wm maxsize . 830 512 |
161 |
162 |
wm iconbitmap . @$radlib/trad.icon |
163 |
164 |
proc gotfile o { # set file possession state |
165 |
global oldradvar radvar |
166 |
catch {unset oldradvar} |
167 |
if $o { |
168 |
set mode normal |
169 |
foreach n [array names radvar] { |
170 |
set oldradvar($n) $radvar($n) |
171 |
172 |
} else { |
173 |
set mode disabled |
174 |
175 |
foreach b {scene zone views options action results} { |
176 |
.$b configure -state $mode |
177 |
178 |
179 |
180 |
# Decide where to go and start |
181 |
182 |
gotfile 0 |
183 |
if {[llength $argv] == 0} { |
184 |
set curmess "Choose a Radiance project file." |
185 |
.file invoke |
186 |
} elseif {[llength $argv] == 1} { |
187 |
cd [file dirname $argv] |
188 |
set curfile [file tail $argv] |
189 |
if {! [file isfile $curfile]} { |
190 |
if [newnew $curfile] { |
191 |
.scene invoke |
192 |
} else { |
193 |
.file invoke |
194 |
195 |
} elseif {[newload $curfile]} { |
196 |
if $alldone { |
197 |
set curmess "All renderings are finished." |
198 |
.results invoke |
199 |
} else { |
200 |
.action invoke |
201 |
202 |
} else { |
203 |
.file invoke |
204 |
205 |
} else { |
206 |
puts stderr {Usage: trad [rifname]} |
207 |
exit 1 |
208 |
