root/radiance/ray/src/util/trad.wsh
Revision: 2.15
Committed: Sat Feb 22 02:07:30 2003 UTC (22 years, 3 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9
# User Rev Content
1 greg 2.11 #!/usr/local/bin/wish4.0
2 greg 2.15 # RCSid: $Id$
3 greg 2.1 #
4     # TCL/TK-based Rad Input File Editor
5     #
6
7     # Insert our autoload directory (may require local system modification)
8
9     set radlib /usr/local/lib/ray/tcl
10     set helplib $radlib
11
12     set auto_path [linsert $auto_path 0 $radlib]
13
14 greg 2.14 # Assign global globbing variables
15
16     set myglob(rif) *.rif
17     set myglob(materials) *.mat
18     set myglob(illum) *.rad
19     set myglob(scene) *.rad
20     set myglob(objects) *
21
22 greg 2.1 # Create required procedures
23
24     proc modified {} { # check for radvar modification
25     global radvar oldradvar
26     if {! [info exists oldradvar]} {return 0}
27     foreach n [array names oldradvar] {
28     if {! [info exists radvar($n)] ||
29     "$radvar($n)" != "$oldradvar($n)"} {
30     return 1
31     }
32     }
33     return 0
34     }
35
36     proc chksave {} { # check if RIF is saved and accost user if not
37     global readonly rifname oldradvar curmess
38 greg 2.9 if [modified] {
39     if $readonly {
40     set warnmess "You have modified variables, but the\
41     file \"[file tail $rifname]\" was opened read-only.
42 greg 2.1 Do you wish to save this information somehow?"
43 greg 2.9 set yesmess {Go to File Screen}
44     } else {
45     set warnmess "The file \"[file tail $rifname]\" has\
46     been modified since it was last saved.
47 greg 2.1 Do you wish to save it now?"
48 greg 2.9 set yesmess {Save File}
49     }
50 greg 2.1 switch [tk_dialog .dlg {File Modified} $warnmess \
51     warning 0 $yesmess {Discard Changes} \
52     {Cancel Operation}] {
53     1 { return 1 }
54     2 { return 0 }
55     }
56     if $readonly {
57 greg 2.8 set curmess {Rename file or uncheck read-only to save.}
58 greg 2.1 .file invoke
59     return 0
60 greg 2.7 } elseif {[save_vars $rifname]} {
61     gotfile 1
62     return 1
63 greg 2.9 }
64     return 0
65     }
66     return 1
67 greg 2.1 }
68
69     # Set global variable default values
70
71     set readonly 0
72     set alldone 0
73     set rifname [pwd]/
74
75     # Propogate essential variables
76
77     proc setrname {name elem op} {
78     global rifname
79     wm title . $rifname
80     wm iconname . [file tail $rifname]
81     }
82     trace variable rifname w setrname
83
84     # Make main window frames
85
86 greg 2.3 set smallscrn [expr [winfo screenwidth .] < 830]
87
88 greg 2.5 message .mess -relief ridge -font fixed -textvariable curmess -anchor nw
89 greg 2.3 if $smallscrn {
90 greg 2.10 frame .upper -width 640 -height 410
91     frame .upper.right -width 120 -height 410
92 greg 2.5 .mess configure -width 640
93 greg 2.3 } else {
94 greg 2.10 frame .upper -width 830 -height 410
95     frame .upper.right -width 130 -height 410
96 greg 2.5 .mess configure -width 830
97 greg 2.3 }
98 greg 2.1 pack .upper -side top
99 greg 2.2 place .upper.right -relx .98 -rely 0 -anchor ne
100 greg 2.1 pack .mess -side top -expand yes -fill both
101     helplink .mess trad trad messages
102 greg 2.4 . configure -cursor top_left_arrow
103 greg 2.1
104     # Make mode buttons
105
106     proc changescreen {} { # switch screen according to curmode
107 greg 2.3 global curscreen curmode curmess smallscrn
108 greg 2.1 if [info exists curscreen] {
109     if {"$curmode" == "$curscreen"} {return}
110     destroy .upper.left
111     do_$curscreen done
112     set curmess {}
113     }
114     set curscreen $curmode
115     do_$curscreen .upper.left
116 greg 2.3 if $smallscrn {
117 greg 2.10 .upper.left configure -width 520 -height 410
118 greg 2.3 } else {
119 greg 2.10 .upper.left configure -width 700 -height 410
120 greg 2.3 }
121 greg 2.1 place .upper.left -x 0 -y 0
122     }
123
124     label .upper.right.title -text "- TRAD -"
125     pack .upper.right.title -side top -pady 10
126
127     proc setbutt v {
128     radiobutton .$v -text [string toupper $v] \
129     -variable curmode -value $v \
130     -width 9 -relief groove -anchor w \
131     -command changescreen
132     pack .$v -in .upper.right -side top -pady 5
133     helplink .$v trad $v intro
134     }
135
136     setbutt file
137     setbutt scene
138     setbutt zone
139     setbutt views
140     setbutt options
141     setbutt action
142     setbutt results
143     rename setbutt {}
144     button .upper.right.help -text HELP -width 9 \
145     -command "gethelp trad trad intro"
146 greg 2.11 pack .upper.right.help -side top -pady 5 -anchor se
147 greg 2.1 helplink .upper.right.help trad trad help
148     button .upper.right.quit -text QUIT \
149     -command {if [chksave] {destroy .}} -width 9
150 greg 2.11 pack .upper.right.quit -side top -pady 5 -anchor se
151 greg 2.1 helplink .upper.right.quit trad trad quit
152
153 greg 2.3 if $smallscrn {
154     wm minsize . 640 460
155 greg 2.5 wm maxsize . 640 512
156 greg 2.3 } else {
157     wm minsize . 830 460
158 greg 2.5 wm maxsize . 830 512
159 greg 2.3 }
160 greg 2.1 wm iconbitmap . @$radlib/trad.icon
161
162 greg 2.12 proc gotfile o { # set file possession state
163 greg 2.1 global oldradvar radvar
164     catch {unset oldradvar}
165     if $o {
166     set mode normal
167     foreach n [array names radvar] {
168     set oldradvar($n) $radvar($n)
169     }
170     } else {
171     set mode disabled
172     }
173     foreach b {scene zone views options action results} {
174     .$b configure -state $mode
175     }
176     }
177
178     # Decide where to go and start
179
180 greg 2.12 gotfile 0
181 greg 2.1 if {[llength $argv] == 0} {
182 greg 2.7 set curmess "Choose a Radiance project file."
183 greg 2.12 .file invoke
184 greg 2.1 } elseif {[llength $argv] == 1} {
185     cd [file dirname $argv]
186     set curfile [file tail $argv]
187 greg 2.13 if {! [file isfile $curfile]} {
188     if [newnew $curfile] {
189     .scene invoke
190     } else {
191     .file invoke
192     }
193 greg 2.1 } elseif {[newload $curfile]} {
194     if $alldone {
195     set curmess "All renderings are finished."
196     .results invoke
197     } else {
198     .action invoke
199     }
200     } else {
201     .file invoke
202     }
203     } else {
204     puts stderr {Usage: trad [rifname]}
205     exit 1
206     }
