root/radiance/ray/src/util/trad.wsh
Revision: 2.17
Committed: Wed May 1 16:47:54 2019 UTC (4 years, 10 months ago) by greg
CVS Tags: rad5R4, rad5R3, HEAD
Changed default path for wish to "/usr/bin/wish"
1 #!/usr/bin/wish
2 # RCSid: $Id: trad.wsh,v 2.16 2011/10/26 20:06:17 greg Exp $
3 # the next line restarts using wish in case of shell execution \
4 exec wish "$0" "$@"
5 #
6 # TCL/TK-based Rad Input File Editor
7 #
8
9 # Insert our autoload directory (may require local system modification)
10
11 set radlib /usr/local/lib/ray/tcl
12 set helplib $radlib
13
14 set auto_path [linsert $auto_path 0 $radlib]
15
16 # Assign global globbing variables
17
18 set myglob(rif) *.rif
19 set myglob(materials) *.mat
20 set myglob(illum) *.rad
21 set myglob(scene) *.rad
22 set myglob(objects) *
23
24 # Create required procedures
25
26 proc modified {} { # check for radvar modification
27 global radvar oldradvar
28 if {! [info exists oldradvar]} {return 0}
29 foreach n [array names oldradvar] {
30 if {! [info exists radvar($n)] ||
31 "$radvar($n)" != "$oldradvar($n)"} {
32 return 1
33 }
34 }
35 return 0
36 }
37
38 proc chksave {} { # check if RIF is saved and accost user if not
39 global readonly rifname oldradvar curmess
40 if [modified] {
41 if $readonly {
42 set warnmess "You have modified variables, but the\
43 file \"[file tail $rifname]\" was opened read-only.
44 Do you wish to save this information somehow?"
45 set yesmess {Go to File Screen}
46 } else {
47 set warnmess "The file \"[file tail $rifname]\" has\
48 been modified since it was last saved.
49 Do you wish to save it now?"
50 set yesmess {Save File}
51 }
52 switch [tk_dialog .dlg {File Modified} $warnmess \
53 warning 0 $yesmess {Discard Changes} \
54 {Cancel Operation}] {
55 1 { return 1 }
56 2 { return 0 }
57 }
58 if $readonly {
59 set curmess {Rename file or uncheck read-only to save.}
60 .file invoke
61 return 0
62 } elseif {[save_vars $rifname]} {
63 gotfile 1
64 return 1
65 }
66 return 0
67 }
68 return 1
69 }
70
71 # Set global variable default values
72
73 set readonly 0
74 set alldone 0
75 set rifname [pwd]/
76
77 # Propogate essential variables
78
79 proc setrname {name elem op} {
80 global rifname
81 wm title . $rifname
82 wm iconname . [file tail $rifname]
83 }
84 trace variable rifname w setrname
85
86 # Make main window frames
87
88 set smallscrn [expr [winfo screenwidth .] < 830]
89
90 message .mess -relief ridge -font fixed -textvariable curmess -anchor nw
91 if $smallscrn {
92 frame .upper -width 640 -height 410
93 frame .upper.right -width 120 -height 410
94 .mess configure -width 640
95 } else {
96 frame .upper -width 830 -height 410
97 frame .upper.right -width 130 -height 410
98 .mess configure -width 830
99 }
100 pack .upper -side top
101 place .upper.right -relx .98 -rely 0 -anchor ne
102 pack .mess -side top -expand yes -fill both
103 helplink .mess trad trad messages
104 . configure -cursor top_left_arrow
105
106 # Make mode buttons
107
108 proc changescreen {} { # switch screen according to curmode
109 global curscreen curmode curmess smallscrn
110 if [info exists curscreen] {
111 if {"$curmode" == "$curscreen"} {return}
112 destroy .upper.left
113 do_$curscreen done
114 set curmess {}
115 }
116 set curscreen $curmode
117 do_$curscreen .upper.left
118 if $smallscrn {
119 .upper.left configure -width 520 -height 410
120 } else {
121 .upper.left configure -width 700 -height 410
122 }
123 place .upper.left -x 0 -y 0
124 }
125
126 label .upper.right.title -text "- TRAD -"
127 pack .upper.right.title -side top -pady 10
128
129 proc setbutt v {
130 radiobutton .$v -text [string toupper $v] \
131 -variable curmode -value $v \
132 -width 10 -relief groove -anchor w \
133 -command changescreen
134 pack .$v -in .upper.right -side top -pady 5
135 helplink .$v trad $v intro
136 }
137
138 setbutt file
139 setbutt scene
140 setbutt zone
141 setbutt views
142 setbutt options
143 setbutt action
144 setbutt results
145 rename setbutt {}
146 button .upper.right.help -text HELP -width 9 \
147 -command "gethelp trad trad intro"
148 pack .upper.right.help -side top -pady 5 -anchor se
149 helplink .upper.right.help trad trad help
150 button .upper.right.quit -text QUIT \
151 -command {if [chksave] {destroy .}} -width 9
152 pack .upper.right.quit -side top -pady 5 -anchor se
153 helplink .upper.right.quit trad trad quit
154
155 if $smallscrn {
156 wm minsize . 640 460
157 wm maxsize . 640 512
158 } else {
159 wm minsize . 830 460
160 wm maxsize . 830 512
161 }
162 wm iconbitmap . @$radlib/trad.icon
163
164 proc gotfile o { # set file possession state
165 global oldradvar radvar
166 catch {unset oldradvar}
167 if $o {
168 set mode normal
169 foreach n [array names radvar] {
170 set oldradvar($n) $radvar($n)
171 }
172 } else {
173 set mode disabled
174 }
175 foreach b {scene zone views options action results} {
176 .$b configure -state $mode
177 }
178 }
179
180 # Decide where to go and start
181
182 gotfile 0
183 if {[llength $argv] == 0} {
184 set curmess "Choose a Radiance project file."
185 .file invoke
186 } elseif {[llength $argv] == 1} {
187 cd [file dirname $argv]
188 set curfile [file tail $argv]
189 if {! [file isfile $curfile]} {
190 if [newnew $curfile] {
191 .scene invoke
192 } else {
193 .file invoke
194 }
195 } elseif {[newload $curfile]} {
196 if $alldone {
197 set curmess "All renderings are finished."
198 .results invoke
199 } else {
200 .action invoke
201 }
202 } else {
203 .file invoke
204 }
205 } else {
206 puts stderr {Usage: trad [rifname]}
207 exit 1
208 }
