1 |
#!/usr/local/bin/wish -f |
2 |
# SCCSid "$SunId$ LBL" |
3 |
4 |
# TCL/TK-based Rad Input File Editor |
5 |
6 |
7 |
# Insert our autoload directory (may require local system modification) |
8 |
9 |
set radlib /usr/local/lib/ray/tcl |
10 |
set helplib $radlib |
11 |
12 |
set auto_path [linsert $auto_path 0 $radlib] |
13 |
14 |
# Create required procedures |
15 |
16 |
proc modified {} { # check for radvar modification |
17 |
global radvar oldradvar |
18 |
if {! [info exists oldradvar]} {return 0} |
19 |
foreach n [array names oldradvar] { |
20 |
if {! [info exists radvar($n)] || |
21 |
"$radvar($n)" != "$oldradvar($n)"} { |
22 |
return 1 |
23 |
24 |
25 |
return 0 |
26 |
27 |
28 |
proc chksave {} { # check if RIF is saved and accost user if not |
29 |
global readonly rifname oldradvar curmess |
30 |
if $readonly { |
31 |
set warnmess "You have modified variables, but the file\ |
32 |
\"[file tail $rifname]\" was opened read-only. |
33 |
Do you wish to save this information somehow?" |
34 |
set yesmess {Go to File Screen} |
35 |
} else { |
36 |
set warnmess "The file \"[file tail $rifname]\" has been\ |
37 |
modified since it was last saved. |
38 |
Do you wish to save it now?" |
39 |
set yesmess {Save File} |
40 |
41 |
if [modified] { |
42 |
switch [tk_dialog .dlg {File Modified} $warnmess \ |
43 |
warning 0 $yesmess {Discard Changes} \ |
44 |
{Cancel Operation}] { |
45 |
1 { return 1 } |
46 |
2 { return 0 } |
47 |
48 |
if $readonly { |
49 |
set curmess {Rename file or uncheck read-only to save.} |
50 |
.file invoke |
51 |
return 0 |
52 |
} elseif {[save_vars $rifname]} { |
53 |
gotfile 1 |
54 |
return 1 |
55 |
} else { return 0 } |
56 |
} else { return 1 } |
57 |
58 |
59 |
# Set global variable default values |
60 |
61 |
set readonly 0 |
62 |
set alldone 0 |
63 |
set rifname [pwd]/ |
64 |
65 |
# Propogate essential variables |
66 |
67 |
proc setrname {name elem op} { |
68 |
global rifname |
69 |
wm title . $rifname |
70 |
wm iconname . [file tail $rifname] |
71 |
72 |
trace variable rifname w setrname |
73 |
74 |
# Make main window frames |
75 |
76 |
set smallscrn [expr [winfo screenwidth .] < 830] |
77 |
78 |
message .mess -relief ridge -font fixed -textvariable curmess -anchor nw |
79 |
if $smallscrn { |
80 |
frame .upper -geometry 640x410 |
81 |
frame .upper.right -geometry 120x410 |
82 |
.mess configure -width 640 |
83 |
} else { |
84 |
frame .upper -geometry 830x410 |
85 |
frame .upper.right -geometry 130x410 |
86 |
.mess configure -width 830 |
87 |
88 |
pack .upper -side top |
89 |
place .upper.right -relx .98 -rely 0 -anchor ne |
90 |
pack .mess -side top -expand yes -fill both |
91 |
helplink .mess trad trad messages |
92 |
. configure -cursor top_left_arrow |
93 |
94 |
# Make mode buttons |
95 |
96 |
proc changescreen {} { # switch screen according to curmode |
97 |
global curscreen curmode curmess smallscrn |
98 |
if [info exists curscreen] { |
99 |
if {"$curmode" == "$curscreen"} {return} |
100 |
destroy .upper.left |
101 |
do_$curscreen done |
102 |
set curmess {} |
103 |
104 |
set curscreen $curmode |
105 |
do_$curscreen .upper.left |
106 |
if $smallscrn { |
107 |
.upper.left configure -geometry 520x410 |
108 |
} else { |
109 |
.upper.left configure -geometry 700x410 |
110 |
111 |
place .upper.left -x 0 -y 0 |
112 |
113 |
114 |
label .upper.right.title -text "- TRAD -" |
115 |
pack .upper.right.title -side top -pady 10 |
116 |
117 |
proc setbutt v { |
118 |
radiobutton .$v -text [string toupper $v] \ |
119 |
-variable curmode -value $v \ |
120 |
-width 9 -relief groove -anchor w \ |
121 |
-command changescreen |
122 |
pack .$v -in .upper.right -side top -pady 5 |
123 |
helplink .$v trad $v intro |
124 |
125 |
126 |
setbutt file |
127 |
setbutt scene |
128 |
setbutt zone |
129 |
setbutt views |
130 |
setbutt options |
131 |
setbutt action |
132 |
setbutt results |
133 |
rename setbutt {} |
134 |
button .upper.right.help -text HELP -width 9 \ |
135 |
-command "gethelp trad trad intro" |
136 |
pack .upper.right.help -side top -pady 10 -anchor se |
137 |
helplink .upper.right.help trad trad help |
138 |
button .upper.right.quit -text QUIT \ |
139 |
-command {if [chksave] {destroy .}} -width 9 |
140 |
pack .upper.right.quit -side top -pady 10 -anchor se |
141 |
helplink .upper.right.quit trad trad quit |
142 |
143 |
if $smallscrn { |
144 |
wm minsize . 640 460 |
145 |
wm maxsize . 640 512 |
146 |
} else { |
147 |
wm minsize . 830 460 |
148 |
wm maxsize . 830 512 |
149 |
150 |
wm iconbitmap . @$radlib/trad.icon |
151 |
152 |
proc gotfile {{o 1}} { # set file possession state |
153 |
global oldradvar radvar |
154 |
catch {unset oldradvar} |
155 |
if $o { |
156 |
set mode normal |
157 |
foreach n [array names radvar] { |
158 |
set oldradvar($n) $radvar($n) |
159 |
160 |
} else { |
161 |
set mode disabled |
162 |
.file invoke |
163 |
164 |
foreach b {scene zone views options action results} { |
165 |
.$b configure -state $mode |
166 |
167 |
168 |
169 |
# Decide where to go and start |
170 |
171 |
if {[llength $argv] == 0} { |
172 |
set curmess "Choose a Radiance project file." |
173 |
gotfile 0 |
174 |
} elseif {[llength $argv] == 1} { |
175 |
cd [file dirname $argv] |
176 |
set curfile [file tail $argv] |
177 |
if {! [file exists $curfile]} { |
178 |
newnew $curfile |
179 |
.scene invoke |
180 |
} elseif {[newload $curfile]} { |
181 |
if $alldone { |
182 |
set curmess "All renderings are finished." |
183 |
.results invoke |
184 |
} else { |
185 |
.action invoke |
186 |
187 |
} else { |
188 |
.file invoke |
189 |
190 |
} else { |
191 |
puts stderr {Usage: trad [rifname]} |
192 |
exit 1 |
193 |
