| 1 |
$Id$ |
| 2 |
| 3 |
This help file is associated with the trad interface to the Radiance |
| 4 |
rad(1) program. Trad consists of trad.wsh and one do_*.tcl file for |
| 5 |
each screen. There are currently seven such screens: Action, File, |
| 6 |
Options, Results, Scene, Views and Zone. |
| 7 |
| 8 |
.Trad.Intro |
| 9 |
| 10 |
Trad is a graphical user interface (GUI) to the |
| 11 |
rad(1) program, which controls the operation of the basic |
| 12 |
Radiance scene compiling, rendering and picture filtering programs. |
| 13 |
Trad also includes links to a few utilities for displaying and |
| 14 |
converting results, but most of what it does can be done by editing a |
| 15 |
small text file, called the "rad input file". |
| 16 |
Scene creation still requires the use of a text or graphical editor, |
| 17 |
or translation from some external CAD format. |
| 18 |
| 19 |
Trad interaction is broken into seven screens. |
| 20 |
Each screen is accessed by pressing its associated radio |
| 21 |
button along the right-hand side of the main window. |
| 22 |
If trad is started with no file name, the File screen is displayed, |
| 23 |
and you must pick a valid rad input file before any other screen may |
| 24 |
be accessed. |
| 25 |
If a name is given for a file that doesn't exist, trad goes to the |
| 26 |
Scene screen and prompts you to enter the names of one or more |
| 27 |
Radiance scene description files. |
| 28 |
If a rad input file exists already, trad determines if there are |
| 29 |
renderings still to be done or if everything is finished. |
| 30 |
If there is still work to be done, trad opens first with the Action |
| 31 |
screen. |
| 32 |
If all renderings are complete and up-to-date, trad opens right to |
| 33 |
Results screen. |
| 34 |
| 35 |
For additional guidance on Radiance in general, consult the Radiance |
| 36 |
Tutorial, Reference Manual, and man pages. |
| 37 |
In particular, it is a good idea to read through the rad(1) man page |
| 38 |
before using this interface. |
| 39 |
| 40 |
To find out how to get more help, press the "Next" button to the |
| 41 |
right. |
| 42 |
| 43 |
.Trad.Help |
| 44 |
| 45 |
If you have specific questions about trad, search through the |
| 46 |
category and topic menus on this help window, or press and release |
| 47 |
the left mouse button while holding the control key over the object of |
| 48 |
curiosity in the main trad window. |
| 49 |
(In general, only active windows are given help file links -- click |
| 50 |
on these rather than the text labels.) |
| 51 |
| 52 |
For help on the help facility itself, Control-click on the problem |
| 53 |
help widget or on the window title in the upper right corner for |
| 54 |
more general information. |
| 55 |
(To get back to trad-specific help, press the "HELP" button in the |
| 56 |
main trad window or Control-click on a trad widget.) |
| 57 |
| 58 |
Once the help window has been displayed, it is usually best to |
| 59 |
lower or iconify it rather than dismissing it if further help is |
| 60 |
needed. |
| 61 |
This way, you will not have to wait for the help file to be read in |
| 62 |
all over again every time you have a question. |
| 63 |
| 64 |
.Trad.Messages |
| 65 |
| 66 |
Informative messages, commands executed by rad, and errors |
| 67 |
appear in the message window at the bottom of the trad frame. |
| 68 |
Growing the trad window means growing this message window, and |
| 69 |
not much else. |
| 70 |
This is not really necessary, since the window will be grown |
| 71 |
automatically if the message requires it. |
| 72 |
| 73 |
Serious errors will be accompanied by the sounding of the bell. |
| 74 |
| 75 |
.Trad.Quit |
| 76 |
| 77 |
To quit the trad application, press the "Quit" button at any time. |
| 78 |
If you have made changes to the rad input variables, you will be |
| 79 |
asked prior to program exit if you want to save your changes first. |
| 80 |
| 81 |
Any batch process running in the background will continue to run, |
| 82 |
and the associated error messages will be viewable by |
| 83 |
trad later when you open the same rad input file. |
| 84 |
| 85 |
.File.Intro |
| 86 |
| 87 |
This button selects the trad File screen, which allows rad input |
| 88 |
files to be loaded and saved, and new files to be created. |
| 89 |
| 90 |
.File.Load |
| 91 |
| 92 |
This button loads the selected file into trad. |
| 93 |
If the current file has been changed and these changes have not been |
| 94 |
saved, you will be given first the opportunity to save your changes. |
| 95 |
| 96 |
The actual load operation may take several seconds or even minutes, |
| 97 |
depending on the status of the rendering process. |
| 98 |
This is because the rad program itself is used to interpret the |
| 99 |
input file, and if there is no up-to-date octree associated with the |
| 100 |
file, it is necessary to run getbbox on the entire scene |
| 101 |
before the variable values can be set. |
| 102 |
It is possible to eliminate this delay in future loads by going to |
| 103 |
the Action screen and running oconv. |
| 104 |
| 105 |
If the opened file has read-only mode set (see chmod(1)), then the |
| 106 |
"Read Only" check box will be lit. |
| 107 |
Unchecking this box means that it will be possible to save the file |
| 108 |
later, though the actual mode on the file will not be changed until |
| 109 |
it is saved. |
| 110 |
Loading a writable file always clears the "Read Only" check box. |
| 111 |
| 112 |
If an error is encountered while trying to load the file, a message |
| 113 |
will be printed in the box at the bottom. |
| 114 |
| 115 |
.File.Save |
| 116 |
| 117 |
The "Save" button in the File screen saves any changes to the |
| 118 |
current file. |
| 119 |
This information is saved in the original file by default, but may |
| 120 |
be saved in another file by entering a new name in the "File" field. |
| 121 |
If this new file already exists, a dialogue box will ask if you really |
| 122 |
want to overwrite it. |
| 123 |
If the file name is different than the original |
| 124 |
one loaded, the "Read Only" check box will be ignored. |
| 125 |
| 126 |
.File.New |
| 127 |
| 128 |
The "New" button clears all rad variables in preparation for |
| 129 |
writing a new rad input file. |
| 130 |
If the file selected already exists, a warning box will ask if you |
| 131 |
really want to ignore the previous file contents. |
| 132 |
If you agree, then no warning will be given when the file is later |
| 133 |
overwritten. |
| 134 |
| 135 |
.File.ReadOnly |
| 136 |
| 137 |
The "Read Only" check box permits you to indicate that the opened |
| 138 |
file should not be overwritten. |
| 139 |
This box will be checked automatically if the permissions on the |
| 140 |
edited file do not allow writing by the user. |
| 141 |
If the box is subsequently unchecked, trad will attempt to change |
| 142 |
permissions and write to the file when a save is requested. |
| 143 |
If this fails, an error message will indicate the problem. |
| 144 |
| 145 |
.Scene.Intro |
| 146 |
| 147 |
This button selects the trad Scene screen. |
| 148 |
On this screen, you may enter the octree file and the scene files |
| 149 |
that go into it, as well as any mkillum or other files on which the |
| 150 |
scene depends. |
| 151 |
These files are generally produced by hand in a text editor or by |
| 152 |
conversion from an external CAD format, such as DXF. |
| 153 |
(See the Radiance Reference Manual and Radiance Tutorial for details on the |
| 154 |
information contained in these files.) |
| 155 |
| 156 |
To enter a file of a particular type, press the corresponding button |
| 157 |
to get a dialogue box that allows you to pick existing files from any |
| 158 |
directory. |
| 159 |
| 160 |
Use the "Discard" button to remove one or more files from a specific |
| 161 |
list. |
| 162 |
The actual file is untouched. |
| 163 |
| 164 |
.Scene.Octree |
| 165 |
| 166 |
The "Octree" entry in the Scene screen names the octree file to be |
| 167 |
compiled by oconv from the materials and scene files. |
| 168 |
(See the oconv(1) man page for more details.) |
| 169 |
| 170 |
If make(1) is being used to build the octree, you should leave all |
| 171 |
other windows on this screen empty. |
| 172 |
The octree can still be rebuilt from trad by pressing the "oconv" |
| 173 |
or "Force" buttons on the Action screen, but normally it is |
| 174 |
expected to be current. |
| 175 |
In particular, an unsupported octree must exist before loading |
| 176 |
a rad input file on which it depends. |
| 177 |
| 178 |
The default octree name is the root name from the render input file |
| 179 |
plus ".oct". |
| 180 |
If mkillum is being used (i.e. one or more illum files is given), |
| 181 |
then two additional octrees will be created, named the same except |
| 182 |
for an additional "0" or "1" immediately before the file suffix |
| 183 |
(normally ".oct"). |
| 184 |
| 185 |
To delete the named octree, and therefore force the scene to be |
| 186 |
recompiled and all the pictures to be rerendered, use the "Delete" |
| 187 |
button next to the octree window. |
| 188 |
| 189 |
.Scene.OctDelete |
| 190 |
| 191 |
The "Delete" button next to the octree window removes the named |
| 192 |
octree from the filesystem, forcing the scene to be later recompiled |
| 193 |
and all the pictures to be rerendered (if desired). |
| 194 |
This is appropriate if you add or remove materials, scene or illum |
| 195 |
files from one or more lists, or make some change to a materials file |
| 196 |
that requires the octree to be rebuilt (such as adding or removing |
| 197 |
individual materials). |
| 198 |
| 199 |
Verification is required before the octree will be deleted. |
| 200 |
| 201 |
You can achieve the same effect as manually removing the octree by |
| 202 |
pressing the "Force" button on the scene compilation section |
| 203 |
of the Action screen. |
| 204 |
(See the "Force" topic under the "Action" help category for more |
| 205 |
information.) |
| 206 |
| 207 |
.Scene.Materials |
| 208 |
| 209 |
Materials files generally contain Radiance material descriptions |
| 210 |
only, not geometry. |
| 211 |
The purpose of listing them separately is so that minor changes to |
| 212 |
material parameters will not force the octree to be rebuilt, |
| 213 |
incurring an additional delay that is unnecessary. |
| 214 |
| 215 |
The "Materials" button is used to add materials files to the list. |
| 216 |
A dialogue box appears when you press this button and allows you to |
| 217 |
select files to be included. |
| 218 |
Each new selection is added to the end of the materials list. |
| 219 |
The default matching pattern for material files is "*.mat". |
| 220 |
This may of course be reassigned within the file selection window. |
| 221 |
| 222 |
The list box showing the current materials may be edited in three |
| 223 |
ways besides the dialogue for adding files. |
| 224 |
First, entries may be removed from the list |
| 225 |
using the "Discard" button. |
| 226 |
Second, entries may be moved within the box by selecting them with |
| 227 |
the left mouse button and clicking the middle mouse button over the |
| 228 |
entry you wish to place the selected items above. |
| 229 |
If you wish to put the selected items at the very end of the list, |
| 230 |
click the middle mouse button below the last entry. |
| 231 |
Third, entries may be moved from other windows by |
| 232 |
selecting them and pressing the middle button. |
| 233 |
This works for the list boxes on this screen as well as selections |
| 234 |
in other windows on the display. |
| 235 |
| 236 |
The order of materials files is usually unimportant, but sometimes |
| 237 |
there are definitions in later files that depend on prerequisites in |
| 238 |
earlier files. |
| 239 |
An example of this is a window illum source that depends on a sky |
| 240 |
description file, which must appear before it. |
| 241 |
The order of files shown in the list is the order they will be given |
| 242 |
to oconv and therefore to the rendering programs. |
| 243 |
| 244 |
.Scene.Illum |
| 245 |
| 246 |
Illum files are Radiance scene descriptions that contain surfaces |
| 247 |
to be converted into illum sources by mkillum(1). |
| 248 |
Please consult the manual page for mkillum and understand the |
| 249 |
Radiance Tutorial before using this box, since these files differ slightly |
| 250 |
from standard Radiance scene descriptions. |
| 251 |
| 252 |
The "Illum" button is used to add illum files to the list. |
| 253 |
| 254 |
| 255 |
Each new selection is added to the end of the illum list. |
| 256 |
The default matching pattern for material files is "*.rad". |
| 257 |
| 258 |
| 259 |
The list box showing the current illum files may be edited in three |
| 260 |
| 261 |
| 262 |
| 263 |
| 264 |
| 265 |
| 266 |
| 267 |
| 268 |
| 269 |
| 270 |
| 271 |
| 272 |
| 273 |
.Scene.Scene |
| 274 |
| 275 |
Scene files give the geometry and (perhaps) some of the materials |
| 276 |
used in a particular Radiance model. |
| 277 |
These files are given to oconv(1) in the order specified. |
| 278 |
The ordering of files is usually not important, unless some later |
| 279 |
files use materials or other modifiers defined in earlier files. |
| 280 |
| 281 |
The "Scene" button is used to add scene files to the list. |
| 282 |
| 283 |
| 284 |
Each new selection is added to the end of the scene list. |
| 285 |
| 286 |
| 287 |
| 288 |
The list box showing the current scene files may be edited in three |
| 289 |
| 290 |
| 291 |
| 292 |
| 293 |
| 294 |
| 295 |
| 296 |
| 297 |
| 298 |
| 299 |
| 300 |
| 301 |
| 302 |
.Scene.Objects |
| 303 |
| 304 |
Object files are files on which the given octree depends, but which |
| 305 |
are not included directly on the oconv command line. |
| 306 |
If any of these files is modified, then it is assumed that the |
| 307 |
octree must be rebuilt. |
| 308 |
| 309 |
To automatically determine which files in the working directory |
| 310 |
affect the octree, press the "Auto" button just below the "Objects" |
| 311 |
button. |
| 312 |
Note that this will only add files to the object list. |
| 313 |
If you wish to completely replace what is already there, you must |
| 314 |
therefore select all the files and use the "Discard" button before |
| 315 |
pressing "Auto". |
| 316 |
| 317 |
.Scene.Discard |
| 318 |
| 319 |
The "Discard" button removes the selected file names from a list. |
| 320 |
The actual files are untouched, of course. |
| 321 |
(Some care should be taken here, since there is no undo |
| 322 |
function associated with this window other than reloading the |
| 323 |
original information with the "Revert" button.) |
| 324 |
| 325 |
.Scene.Edit |
| 326 |
| 327 |
Use the "Edit" button to open a text editor on the selected file(s). |
| 328 |
This is a convenient way to look at and change the contents of the |
| 329 |
Radiance input files. |
| 330 |
| 331 |
.Scene.Copy |
| 332 |
| 333 |
The "Copy" button may be used to selectively copy the scene file |
| 334 |
information from another rad input file. |
| 335 |
Specifically, the variables "OCTREE, materials, illum, scene and |
| 336 |
objects" will be read in to replace the current values. |
| 337 |
| 338 |
All other variables will be unaffected. |
| 339 |
| 340 |
.Scene.Revert |
| 341 |
| 342 |
The "Revert" button is a convenient way to revert to the original |
| 343 |
values in the rad input file. |
| 344 |
Only the variables on the Scene screen will be affected, but any changes |
| 345 |
to these variables since the last save will be lost. |
| 346 |
| 347 |
.Zone.Intro |
| 348 |
| 349 |
This button selects the trad Zone screen. |
| 350 |
On this screen, the user should enter the maximum and minimum |
| 351 |
coordinates of the zone of interest for this set of renderings. |
| 352 |
This zone need not correspond exactly to any interior or exterior |
| 353 |
walls, as it is used primarily to set rendering parameters and |
| 354 |
standard viewpoints. |
| 355 |
| 356 |
An interior zone means that standard viewpoints will be selected |
| 357 |
from the inside of this box. |
| 358 |
An exterior zone means that standard viewpoints will be selected |
| 359 |
from the outside of this box. |
| 360 |
The default zone is an exterior one computed from the bounding box |
| 361 |
of the entire scene. |
| 362 |
(Note that this is not usually desirable.) |
| 363 |
| 364 |
In addition to the ZONE variable, this screen offers the ability |
| 365 |
to set four other rad variables that are generally associated with a |
| 366 |
particular scene and a particular zone. |
| 367 |
These are the rad DETAIL, INDIRECT, VARIABILITY and EXPOSURE |
| 368 |
variables. |
| 369 |
For more information on these topics, use the Topic menu or consult |
| 370 |
the rad manual page. |
| 371 |
| 372 |
.Zone.Type |
| 373 |
| 374 |
There are two types of zones understood by rad, "Interior" and |
| 375 |
"Exterior". |
| 376 |
An interior zone is indicated when renderings generally take place |
| 377 |
inside a specified 3-d box. |
| 378 |
A typical example might be a single room or auditorium. |
| 379 |
An exterior zone is indicated when renderings generally take place |
| 380 |
outside a specified 3-d box, which is the focus of attention. |
| 381 |
A typical example might be a building exterior or a single object, |
| 382 |
such as a chair. |
| 383 |
| 384 |
.Zone.Zone |
| 385 |
| 386 |
A zone is specified by six real numbers, corresponding to the world |
| 387 |
coordinates of the box's corners. |
| 388 |
Zone boxes are always axis-aligned, therefore one need only specify |
| 389 |
the minimum and maximum X, Y, and Z coordinates. |
| 390 |
| 391 |
The exact values of these coordinates is not terribly important, as |
| 392 |
they are only used to guide the setting of certain rendering |
| 393 |
parameters and standard view positions. |
| 394 |
It does not matter for instance whether the values lie on the inside |
| 395 |
or the outside of walls, or if there are non-rectilinear geometries |
| 396 |
defining the space perimeter. |
| 397 |
In fact, the whole space may not even be aligned with the X, Y, and Z |
| 398 |
axes, and a very approximate box may be given. |
| 399 |
In this case, the standard views may not be very intelligent or |
| 400 |
useful, but the rendering parameters will still be satisfactory so |
| 401 |
long as the overall size of the given box is close to the overall |
| 402 |
size of the space. |
| 403 |
| 404 |
The Zone entry windows may be manipulated in the following ways. |
| 405 |
Control-U clears the current window. |
| 406 |
Control-V pastes the contents of the current selection at the |
| 407 |
insertion point. |
| 408 |
Return moves the focus to the next window in the chain. |
| 409 |
| 410 |
.Zone.Detail |
| 411 |
| 412 |
The "Detail" setting indicates the relative level |
| 413 |
of geometric detail in this zone. |
| 414 |
If the zone is empty except for a few large pieces of furniture, a |
| 415 |
"Low" setting is indicated. |
| 416 |
(For an exterior zone, low detail would mean that the object is |
| 417 |
relatively simple.) |
| 418 |
If the zone contains a usual amount of furniture and clutter, a |
| 419 |
"Medium" setting is appropriate. |
| 420 |
If the zone contains a great many small objects or protrusions, a |
| 421 |
setting of "High" is indicated. |
| 422 |
| 423 |
This variable is used by rad to set rendering parameters that are |
| 424 |
affected by the sizes of objects relative to the overall size of the |
| 425 |
space. |
| 426 |
| 427 |
.Zone.Indirect |
| 428 |
| 429 |
The "Indirect" setting indicates how important indirect illumination |
| 430 |
is in this space. |
| 431 |
A setting of "0" means that most light falls directly on visible |
| 432 |
surfaces, and this setting can be used in most cases. |
| 433 |
A setting of "1" means that most objects are not directly |
| 434 |
illuminated by light sources, but receive light only after it has |
| 435 |
bounced once off some other surface, such as the ceiling. |
| 436 |
Likewise, a setting of "2" means that light must reflect twice off |
| 437 |
other surfaces before reaching most objects of interest. |
| 438 |
| 439 |
Keep in mind that the rendering calculation increases substantially |
| 440 |
with each increment to this variable, so it is a good idea to use |
| 441 |
the smallest reasonable value. |
| 442 |
| 443 |
.Zone.Variability |
| 444 |
| 445 |
The "Variability" setting gives a qualitative indication of how |
| 446 |
light varies in magnitude over surfaces in this zone. |
| 447 |
In a typical direct or indirect lighting situation, this variable |
| 448 |
would be set to "Low", indicating that light is fairly uniform |
| 449 |
throughout the space. |
| 450 |
If there are some areas that are much better lit than others, such |
| 451 |
as desks with powerful tasks lights in a room with dimmer ambient |
| 452 |
lighting, a "Medium" setting is appropriate. |
| 453 |
If there is direct sunlight entering the room, casting bright |
| 454 |
patches on some surfaces and not others, then a setting of "High" is |
| 455 |
indicated. |
| 456 |
| 457 |
Note that this variable speaks to the magnitude of light variations |
| 458 |
more than the patterns of light. |
| 459 |
It may well be that the light is casting interesting patterns such |
| 460 |
as scallops on the walls or something, but as long as the variations |
| 461 |
in brightness are less than an order of magnitude or so, it is a low |
| 462 |
variability situation. |
| 463 |
The high variability |
| 464 |
example given above of direct sun entering a space corresponds to a |
| 465 |
a variation in brightness of about three orders of magnitude, or |
| 466 |
1,000 to 1! |
| 467 |
| 468 |
.Zone.Exposure |
| 469 |
| 470 |
The "Exposure" setting gives the multiplier between the initial |
| 471 |
radiance values at each pixel (in watts/steradian/meter^2) to the |
| 472 |
display pixel values (in the range of 0-1, where 0 is black and 1 is |
| 473 |
the maximum monitor output). |
| 474 |
This setting also determines the average "ambient level," which is |
| 475 |
an important parameter for rendering accuracy. |
| 476 |
| 477 |
There are two basic ways to compute the exposure value. |
| 478 |
The first is by trial and error, where the value is adjusted up and |
| 479 |
down within rview using the "e = value" command. |
| 480 |
Though it sounds flaky, this is the most reliable way to set the |
| 481 |
exposure (and ambient level) in general lighting situations. |
| 482 |
| 483 |
The second method is using a zonal cavity approximation. |
| 484 |
For this, you must estimate the total light flux entering the zone |
| 485 |
from light sources and windows, and the total illuminated area. |
| 486 |
(This applies to interior zones, only. For exterior zones, use the |
| 487 |
value suggested by gensky in its output.) |
| 488 |
In addition, you must approximate the area-weighted average |
| 489 |
reflectance of the illuminated surfaces. |
| 490 |
The formula then for the exposure multiplier using this information |
| 491 |
is: pi*tot_area*(1-avg_refl)/(2*tot_flux*avg_refl) |
| 492 |
where pi is 3.1416, tot_area is given in square meters and |
| 493 |
tot_flux is given in watts. |
| 494 |
(Divide total lumens by 179 lumens/watt to get watts.) |
| 495 |
| 496 |
The exposure value may either be given as a positive real value, or |
| 497 |
as a real value preceeded by a '+' or '-' indicating a positive or |
| 498 |
negative number of f-stops (powers of two) from the original value. |
| 499 |
| 500 |
If no exposure is given, pfilt will automatically compute the |
| 501 |
average for each image, and a default ambient level of 10 will be |
| 502 |
used for exterior zones and 0.01 for interior zones. |
| 503 |
| 504 |
.Zone.Copy |
| 505 |
| 506 |
The "Copy" button on the Zone screen takes all values for this |
| 507 |
screen from another rad input file, replacing the current values. |
| 508 |
Specifically, the rad variables "ZONE, DETAIL, INDIRECT, |
| 509 |
VARIABILITY and EXPOSURE" will be copied from the named file. |
| 510 |
| 511 |
All other variables will be left untouched. |
| 512 |
| 513 |
.Zone.Revert |
| 514 |
| 515 |
| 516 |
| 517 |
Only the variables on the Zone screen will be affected, but any changes |
| 518 |
| 519 |
| 520 |
.Views.Intro |
| 521 |
| 522 |
This button selects the trad Views screen. |
| 523 |
This screen provides a means of setting the multi-valued |
| 524 |
"view" variable. |
| 525 |
Each view setting is listed by name, or by number if no name has |
| 526 |
been assigned. |
| 527 |
To add a new view, enter a unique name and specify the view |
| 528 |
options, |
| 529 |
then press the "Add" or "Set Default" button. |
| 530 |
If a view with the same name already exists, it is unconditionally |
| 531 |
overwritten. |
| 532 |
To modify a particular view, simply select it, change its name |
| 533 |
and/or parameters, and press the "Change" button. |
| 534 |
To remove an unwanted view, select it and press the "Delete" button. |
| 535 |
To undo this action, simply press the "Add" button again. |
| 536 |
| 537 |
The first view in the list is the default given to rview during |
| 538 |
interactive rendering, and is the first view rendered in a batch run. |
| 539 |
To change the default view, select the newly desired view and press |
| 540 |
the "Set Default" button. |
| 541 |
This button also acts like the "Add" button inasmuch as a new view |
| 542 |
may be entered and this button will add it and make it the default |
| 543 |
at the same time. |
| 544 |
| 545 |
The Views screen also allows the standard view up vector to be |
| 546 |
changed, as well as the root picture name and the output resolution. |
| 547 |
| 548 |
.Views.List |
| 549 |
| 550 |
The list box on the far left of the Views screen shows the |
| 551 |
currently defined view names. |
| 552 |
Clicking on any of these with the left mouse button shows the view |
| 553 |
parameters and allows the view to be edited. |
| 554 |
| 555 |
To change the name or options, edit the "Name" or "Options" |
| 556 |
entry and click on the "Change" button. |
| 557 |
| 558 |
Use the "Add" button to add a new view, which may be modified from |
| 559 |
an old one by changing the name and options. |
| 560 |
| 561 |
Use the "Delete" button to delete the selected view from the list. |
| 562 |
| 563 |
Views are listed in the order in which they appear in |
| 564 |
| 565 |
| 566 |
The standard view is "X" is used if no views are specified. |
| 567 |
| 568 |
.Views.Name |
| 569 |
| 570 |
Each view has a unique name, which may be chosen at the user's |
| 571 |
discretion or taken from a list of standard views, described below. |
| 572 |
An invented name should be kept as short as possible, since it is |
| 573 |
added to the picture file name along with the standard ".pic" suffix. |
| 574 |
| 575 |
The standard views are specified by strings of the form |
| 576 |
"[Xx]?[Yy]?[Zz]?[vlah]?". |
| 577 |
(That is, an optional upper or lower case X followed by an optional |
| 578 |
upper or lower case Y followed by an optional upper or lower case Z |
| 579 |
followed by an optional lower case V, L, A or H.) |
| 580 |
The letters indicate the desired view position, where upper case "X" |
| 581 |
means maximum X, lower case "y" means minimum Y and so on. |
| 582 |
The final letter is the view type, where 'v' is perspective (the |
| 583 |
default), 'l' is parallel, 'a' is angular fisheye, and 'h' is |
| 584 |
hemispherical fisheye. |
| 585 |
A perspective view from maximum X, minimum Y would be "Xy" or |
| 586 |
"Xyv". |
| 587 |
A parallel view from maximum Z would be "Zl". |
| 588 |
If "ZONE" is an interior zone, the standard views will |
| 589 |
be inside the perimeter. |
| 590 |
If it is an exterior zone, the standard views will be outside. |
| 591 |
Note that the standard views are best used as starting points, |
| 592 |
and additional arguments may be given after the |
| 593 |
identifier to modify a standard view to suit a particular model. |
| 594 |
| 595 |
.Views.Options |
| 596 |
| 597 |
The "Options" entry window is where the Radiance view |
| 598 |
corresponding to the selected name is given. |
| 599 |
If the view is one of the standard names (described in the "Views |
| 600 |
Name" section), then the options are truly optional, and will |
| 601 |
modify the standard view. |
| 602 |
Otherwise, it is usually necessary to specify a set of options to |
| 603 |
define a view. |
| 604 |
| 605 |
The simplest view specification is of the form "-vf viewfile", where |
| 606 |
"viewfile" is a file created with the rview "view" command, or a |
| 607 |
Radiance picture. |
| 608 |
This method of naming views, although convenient, is not the best |
| 609 |
since it is difficult to know exactly where such a view is by |
| 610 |
seeing only its file name. |
| 611 |
Also, the file may change or be moved or removed, and then the view |
| 612 |
may be different than expected or gone altogether. |
| 613 |
| 614 |
To add view options selected from another X11 window, select the |
| 615 |
text from another window in the normal fashion, use the left mouse |
| 616 |
button to click on the insertion point in the options string, then |
| 617 |
use Control-V to insert the text at that point. |
| 618 |
For convenience, the middle mouse button has been made |
| 619 |
equivalent to Control-V in this window, but it is not the normal |
| 620 |
interaction mode for trad. |
| 621 |
| 622 |
Consult the rpict(1) manual page for a full description of the various |
| 623 |
view options, all of which begin with "-v". |
| 624 |
Just briefly, the "-vt?" option sets the view type, where "?" is |
| 625 |
replaced by one of the letters "v, l, a or h", corresponding to |
| 626 |
perspective, parallel, angular and hemispherical fisheye, respectively. |
| 627 |
The "-vp x y z" option sets the view position (eyepoint), where "x y z" |
| 628 |
is replaced by the position in 3-space. |
| 629 |
The "-vd xd yd zd" option sets the view direction, where "xd yd zd" |
| 630 |
is a vector pointing in the desired direction. |
| 631 |
(To compute this direction from a "look-at" point, simply subtract |
| 632 |
the eyepoint from the look-at point. Vector normalization is |
| 633 |
unnecessary.) |
| 634 |
The "-vh horiz" and "-vv vert" options set the horizontal and |
| 635 |
vertical view sizes, respectively. |
| 636 |
For perspective views, these correspond to full camera angles in |
| 637 |
degrees. |
| 638 |
For parallel views (using the "-vtl" option), they correspond to |
| 639 |
image plane size in world coordinates. |
| 640 |
The lesser used "-vu xd yd zd", "-vs vs" and "-vl vl" options |
| 641 |
will not be discussed here. |
| 642 |
| 643 |
The order of the view options is irrelevant, unless the same option |
| 644 |
is given twice, in which case the last one is used. |
| 645 |
Trad does not check the syntax of the view options strings, so be |
| 646 |
careful! |
| 647 |
In particular, make sure that each option and each argument has a |
| 648 |
space between it and whatever follows. |
| 649 |
| 650 |
Hitting return in the "Options" window is equivalent to pressing the |
| 651 |
"Add" button. |
| 652 |
| 653 |
.Views.Add |
| 654 |
| 655 |
The view "Add" button takes the currently defined view given by the |
| 656 |
"Name" and "Options" windows and appends it to the list of views. |
| 657 |
If another view by the same name exists, it is removed first. |
| 658 |
| 659 |
Since the view is added to the end of the "Views" list, the "Add" |
| 660 |
button is a convenient way to move views to a lower-priority |
| 661 |
position. |
| 662 |
Simply select the view you wish to be last and press "Add". |
| 663 |
| 664 |
To add a view as the first (i.e. the default) view instead of the |
| 665 |
last, use the "Set Default" button. |
| 666 |
| 667 |
.Views.Change |
| 668 |
| 669 |
The view "Change" button deletes the currently selected view and |
| 670 |
adds the currently defined view in its place, changing the name |
| 671 |
and/or view options in the process. |
| 672 |
| 673 |
.Views.Delete |
| 674 |
| 675 |
The view "Delete" button removes the currently selected view from |
| 676 |
the view list. |
| 677 |
| 678 |
To undo this action, simply press the "Add" button immediately |
| 679 |
afterwards, while the deleted view is still present in the edit |
| 680 |
window. |
| 681 |
| 682 |
.Views.Clear |
| 683 |
| 684 |
The "Clear" button simply clears the "Name" and "Options" windows |
| 685 |
for the convenience of entering a new view. |
| 686 |
It has no effect on the rad input variables. |
| 687 |
| 688 |
Note that Control-U will always clear an entry box whose cursor is |
| 689 |
active. |
| 690 |
| 691 |
.Views.Default |
| 692 |
| 693 |
The "Set Default" button may be used to make the selected view the |
| 694 |
default view for rendering. |
| 695 |
This simply moves the view to the top of the list in the rad input file. |
| 696 |
The default view will be the one normally rendered by rview when rad |
| 697 |
is started interactively, and is the first view rendered in a batch |
| 698 |
process. |
| 699 |
| 700 |
A new view may be added as the default view by pressing the "Set |
| 701 |
Default" button rather than the "Add" button. |
| 702 |
It is never necessary to press both. |
| 703 |
| 704 |
If the selected view is already the default, this button will be |
| 705 |
disabled and will read "Is Default" instead of "Set Default". |
| 706 |
| 707 |
.Views.Up |
| 708 |
| 709 |
The standard view up vector may be set to the positive X axis (+X), |
| 710 |
the positive Y axis (+Y), the positive Z axis (+Z), the negative |
| 711 |
X axis (-X), the negative Y axis (-Y), or the negative Z axis (-Z). |
| 712 |
| 713 |
This setting may always be overriden by the "-vu xd yd zd" option, |
| 714 |
and will be altered for a particular view if it happens to be |
| 715 |
parallel to the view direction. |
| 716 |
| 717 |
.Views.Picture |
| 718 |
| 719 |
The root picture file name is given in the "Picture" entry window. |
| 720 |
To this will be added an underscore, followed by the name of |
| 721 |
the particular view being rendered, followed by the ".pic" suffix. |
| 722 |
| 723 |
To render pictures into a different directory than the one |
| 724 |
containing the rad input file, simply precede the file name by a |
| 725 |
relative or absolute directory. |
| 726 |
(Do not use the tilde shorthand for home directories, |
| 727 |
as it is not guaranteed to work on all systems.) |
| 728 |
| 729 |
The default picture name is the root name of the rad input file. |
| 730 |
| 731 |
.Views.Resolution |
| 732 |
| 733 |
The final picture resolution is set in the "Resolution" entry |
| 734 |
window. |
| 735 |
The first entry is the X resolution (in pixels), and the second |
| 736 |
(optional) entry is the Y resolution. |
| 737 |
If there is only one entry, the maximum X and Y resolution will be |
| 738 |
equal. |
| 739 |
If a third entry is given, it is taken as the aspect ratio of the |
| 740 |
destination pixels. |
| 741 |
A number greater than one means that the pixels on the destination |
| 742 |
device are taller than they are wide (and therefore there are more |
| 743 |
of them horizontally than vertically spanning a like distance), and |
| 744 |
a number less than one means the opposite. |
| 745 |
An aspect ratio of zero means that the exact given X and Y |
| 746 |
dimensions are to be honored, whatever the resulting pixel ratio. |
| 747 |
Normally, either the X or the Y resolution is reduced as necessary |
| 748 |
to maintain a specific pixel aspect ratio (1 by default). |
| 749 |
| 750 |
The default value for this variable is "512". |
| 751 |
| 752 |
.Views.Copy |
| 753 |
| 754 |
The "Copy" button in the Views screen permits those variables |
| 755 |
represented on this screen to be copied from another rad input file. |
| 756 |
Specifically, the affected variables are "view, UP, PICTURE, and |
| 757 |
RESOLUTION". |
| 758 |
| 759 |
The original values will be lost, and all other variables will be |
| 760 |
untouched. |
| 761 |
| 762 |
.Views.Revert |
| 763 |
| 764 |
| 765 |
| 766 |
Only the variables on the Views screen will be affected, but any changes |
| 767 |
| 768 |
| 769 |
.Options.Intro |
| 770 |
| 771 |
This button selects the trad Options screen. |
| 772 |
This screen allows the setting of various options for |
| 773 |
controlling the rendering process. |
| 774 |
The most general option is rendering "Quality", which determines the |
| 775 |
overall accuracy and beauty of the pictures produced. |
| 776 |
A separate "Penumbras" option indicates the importance of soft |
| 777 |
shadows in this scene. |
| 778 |
The "Ambfile" variable allows you to specify a file for sharing |
| 779 |
ambient files between runs, and it is recommended that you set |
| 780 |
this variable for high quality renderings. |
| 781 |
The "Optfile" variable allows you to specify a separate file for |
| 782 |
storing rendering options, which reduces the size of the command |
| 783 |
line and makes it easier to run programs such as rtrace(1). |
| 784 |
The "Report" variable may be used to specify a time interval (in |
| 785 |
minutes) between progress reports. |
| 786 |
| 787 |
Other windows allow the user to customize the options to oconv(1), |
| 788 |
mkillum(1), rview(1) and rpict(1), and pfilt(1). |
| 789 |
| 790 |
.Options.Quality |
| 791 |
| 792 |
The "Quality" setting affects the overall accuracy and beauty of the |
| 793 |
renderings produced. |
| 794 |
| 795 |
A "Low" setting is appropriate for quick checks of scene geometry and |
| 796 |
crude lighting studies. |
| 797 |
No interreflection calculation will take place, regardless of the |
| 798 |
setting of the "INDIRECT" variable, and other options are tuned for |
| 799 |
speed over accuracy. |
| 800 |
The computed picture size will exactly equal the final picture |
| 801 |
size, thus some aliasing may be apparent. |
| 802 |
| 803 |
A "Medium" quality setting is most often used for draft renderings, as |
| 804 |
it provides a good balance between rendering time and accuracy. |
| 805 |
The number of interreflections calculated will be equal to the |
| 806 |
setting of the "INDIRECT" variable. |
| 807 |
The computed picture size will be twice the final size, for a modest |
| 808 |
degree of anti-aliasing. |
| 809 |
| 810 |
A "High" quality setting is usually reserved for final renderings. |
| 811 |
The number of interreflections computed will equal the value of the |
| 812 |
"INDIRECT" variable plus one, to guarantee accuracy. |
| 813 |
The computed picture size will be three times the final size, so |
| 814 |
aliasing artifacts should be negligible. |
| 815 |
| 816 |
When increasing the value of the "Quality" setting, it is usually a |
| 817 |
good idea to delete the old "Ambfile", if there is one. |
| 818 |
(See the "AmbDelete" topic under the current help category for |
| 819 |
details.) |
| 820 |
| 821 |
.Options.Penumbras |
| 822 |
| 823 |
The "Penumbras" setting determines whether or not Radiance will |
| 824 |
make a special effort to generate soft shadows from area light sources. |
| 825 |
Since this is a potentially expensive calculation, penumbras should |
| 826 |
only be switched "On" when they are really needed. |
| 827 |
| 828 |
Leaving this setting "Off" does not mean that area light sources |
| 829 |
will be treated as points. |
| 830 |
It only means that some accuracy and possibly some smoothness |
| 831 |
will be traded for speed in the shadow calculations. |
| 832 |
| 833 |
.Options.Ambfile |
| 834 |
| 835 |
The "Ambfile" is the file used to store Radiance ambient values for |
| 836 |
later reuse in other renderings. |
| 837 |
This can greatly reduce the time required to generate multiple |
| 838 |
views, as well as improve the quality of a single view whenever |
| 839 |
interreflections are computed. |
| 840 |
| 841 |
It is strongly recommended that the user set this variable, especially |
| 842 |
when the "QUALITY" variable is set to "High". |
| 843 |
The usual convention is to use the root name of the rad input file, |
| 844 |
followed with the ".amb" suffix. |
| 845 |
It is generally not a good idea to share ambient files between |
| 846 |
different zones, as the placement and accuracy of these values will |
| 847 |
vary according to the location and characteristics of each zone. |
| 848 |
| 849 |
.Options.AmbDelete |
| 850 |
| 851 |
The "Delete" button next to the "Ambfile" window on the Options |
| 852 |
screens allows you to remove the named ambient file. |
| 853 |
This is usually done when a change to one or more rad variables |
| 854 |
casts doubt on the accuracy of the values stored in this file. |
| 855 |
In particular, increases in the variables, "DETAIL, INDIRECT, |
| 856 |
VARIABILITY, EXPOSURE or QUALITY" generally invalidate this file. |
| 857 |
| 858 |
If the ambient file is not empty, you will be asked to verify this |
| 859 |
operation since the values may represent a significant computational |
| 860 |
effort. |
| 861 |
| 862 |
.Options.Optfile |
| 863 |
| 864 |
The "Optfile" setting assigns a file to hold rendering options, |
| 865 |
which may be a convenience when these options are reused for |
| 866 |
rtrace(1) or rpiece(1), or manual invocations of rview or rpict. |
| 867 |
Using an options file also reduces the size of the command line, |
| 868 |
making it a little easier on the eye. |
| 869 |
| 870 |
To assure that the "Optfile" contents are up-to-date, you should press |
| 871 |
the "oconv" or "Script" button on the Action screen. |
| 872 |
| 873 |
.Options.Report |
| 874 |
| 875 |
The "Report" setting indicates the time interval (in minutes) |
| 876 |
between rpict progress reports. |
| 877 |
Normally, rpict runs silently, but it is often nice to know how far |
| 878 |
a given rendering has progressed. |
| 879 |
Normally, progress reports and errors during batch renderings |
| 880 |
are sent to the error file given by the root of the rad input |
| 881 |
file name followed by the ".err" suffix. |
| 882 |
(See the "Errors" topic under the "Action" screen category.) |
| 883 |
If you wish these reports and errors to be directed to a different |
| 884 |
file, follow the time interval by a space and a file name. |
| 885 |
| 886 |
No setting on this variable means do not report rendering progress. |
| 887 |
A zero setting means the same thing, and may be used when a |
| 888 |
separate error file is desired but progress reports are not. |
| 889 |
| 890 |
.Options.Oconv |
| 891 |
| 892 |
The "oconv opts" window may be used to specify any additional |
| 893 |
options to the oconv(1) command used to compile the scene |
| 894 |
description. |
| 895 |
| 896 |
In particular, the "-f" option for creating a "frozen" octree may |
| 897 |
speed rendering start-up substantially, although it makes it |
| 898 |
impossible to change even material properties without |
| 899 |
recompiling the scene again. |
| 900 |
(The "-f" option is technically incompatible with naming |
| 901 |
"materials" files on the Scene screen.) |
| 902 |
| 903 |
If oconv generates a "set overflow" error, it may mean that the "-r |
| 904 |
res" option is needed to increase the octree resolution. |
| 905 |
See the oconv(1) man page for details. |
| 906 |
| 907 |
The "-i octree" option should be used with extreme caution, as incremental |
| 908 |
building of octrees is not very well supported by rad. |
| 909 |
You may do it this way if you specify the input octree as one of the |
| 910 |
"Objects" files on the Scene screen, but it is preferable to use the |
| 911 |
UNIX make(1) utility to incrementally build the octree instead, and |
| 912 |
indicate this by not specifying any illum or scene files. |
| 913 |
| 914 |
.Options.Mkillum |
| 915 |
| 916 |
The "mkillum opts" window may be used to specify options to the |
| 917 |
mkillum(1) command, whose options are actually passed to rtrace(1). |
| 918 |
These options apply only if there are one or more "Illum" files |
| 919 |
named on the Scene screen. |
| 920 |
| 921 |
It is very important to set mkillum options sensibly, |
| 922 |
since rad does not have the intelligence to do it for you. |
| 923 |
| 924 |
.Options.Render |
| 925 |
| 926 |
The "render opts" window is used to specify additional options to |
| 927 |
the rview(1) and rpict(1) rendering programs. |
| 928 |
Most of the important parameters are computed by rad, so this |
| 929 |
window is usually used to override specific parameters or to give |
| 930 |
additional information, such as which materials to exclude from the |
| 931 |
interreflection calculation. |
| 932 |
| 933 |
.Options.Pfilt |
| 934 |
| 935 |
The "pfilt opts" window is used to specify additional options to |
| 936 |
the pfilt(1) picture filtering program. |
| 937 |
| 938 |
Note that the "-e expval", "-x xres" and "-y yres" options are |
| 939 |
already dictated by the settings of the "EXPOSURE" and "RESOLUTION" |
| 940 |
variables, and should therefore be used with caution. |
| 941 |
| 942 |
Also note that the setting of some pfilt options require a |
| 943 |
two-pass filtering process, rather than the default single pass. |
| 944 |
If no "EXPOSURE" setting is given, this is not a problem, but if a |
| 945 |
value for the "EXPOSURE" variable is set as recommended, then it is |
| 946 |
necessary to manually specify the "-2" option to pfilt, followed by |
| 947 |
an exposure that undoes the "EXPOSURE" setting. |
| 948 |
An equivalent workaround is to unset the EXPOSURE variable and |
| 949 |
manually set the render option "-av V V V", where "V" is equal to |
| 950 |
0.5/old_EXPOSURE. |
| 951 |
| 952 |
.Options.Copy |
| 953 |
| 954 |
The "Copy" button in the Options screen permits those variables |
| 955 |
| 956 |
Specifically, the affected variables are "QUALITY, PENUMBRAS, |
| 957 |
AMBFILE, OPTFILE, REPORT, oconv, mkillum, render and pfilt". |
| 958 |
| 959 |
| 960 |
untouched. |
| 961 |
| 962 |
.Options.Revert |
| 963 |
| 964 |
The "Revert" button is a convenient way to revert to the original values |
| 965 |
| 966 |
Only the variables on the Options screen will be affected, but any changes |
| 967 |
| 968 |
| 969 |
.Action.Intro |
| 970 |
| 971 |
This button selects the trad Action screen. |
| 972 |
This screen is where the actual Radiance programs are |
| 973 |
run, usually via rad(1). |
| 974 |
The top row of buttons is used to update the octree following a |
| 975 |
change to one or more input files. |
| 976 |
The "rview" button starts an interactive rendering in the |
| 977 |
foreground. |
| 978 |
The next set of buttons provides for the control of a batch |
| 979 |
rendering process, taking place in the background. |
| 980 |
Finally, the bottom set of buttons allows you to preview what would |
| 981 |
happen during a batch rendering, or (equivalently) make a script of |
| 982 |
UNIX commands for later execution. |
| 983 |
| 984 |
When the Action screen is first brought up, the message window |
| 985 |
displays the current status of any batch rendering process. |
| 986 |
The status must either be "No batch rendering in progress," which |
| 987 |
means that as far as trad can tell a batch rendering was never |
| 988 |
started, "Batch rendering stopped," meaning that there is no current |
| 989 |
process but at least some views have not been rendered or are |
| 990 |
out-of-date, or "Batch rendering finished," meaning that everything |
| 991 |
is done. |
| 992 |
| 993 |
.Action.Oconv |
| 994 |
| 995 |
The "oconv" button on the Action screen may be used to manually |
| 996 |
compile the scene description and bring the octree up to date. |
| 997 |
It is normally not necessary to use this button, since the octree |
| 998 |
will be rebuilt if appropriate prior to rendering. |
| 999 |
However, if the octree is maintained by make(1) rather than rad, or |
| 1000 |
the octree was never created and you want trad to start a little |
| 1001 |
faster next time, or you just need the octree for some reason other |
| 1002 |
than rendering, this is the button for you. |
| 1003 |
| 1004 |
If you have made changes to the rad variables or the Radiance |
| 1005 |
material files that invalidate the current octree or renderings but |
| 1006 |
would not automatically rebuild the octree because the scene files |
| 1007 |
themselves were not changed, it may be wise to use the "Force" |
| 1008 |
button. |
| 1009 |
In contrast, if you have made some insignificant changes to the |
| 1010 |
scene files that should not make any difference to the octree or the |
| 1011 |
renderings, you may want to use the "Touch" button. |
| 1012 |
| 1013 |
Pressing the "oconv" button also updates the contents of the |
| 1014 |
"Optfile" if one is given on the Options screen. |
| 1015 |
This may be useful for computing rendering parameters for rtrace(1) |
| 1016 |
or rpiece(1). |
| 1017 |
| 1018 |
.Action.Force |
| 1019 |
| 1020 |
The "Force" button on the Action screen |
| 1021 |
causes the octree to be unconditionally rebuilt, |
| 1022 |
by removing it first. |
| 1023 |
This will also require all pictures to be rerendered, so only use |
| 1024 |
this button if it is really necessary, i.e. if you have made |
| 1025 |
some important changes to the rad |
| 1026 |
variables on the Scene, Zone or Options screens, but have not |
| 1027 |
changed any scene file on which the octree depends. |
| 1028 |
| 1029 |
If the octree itself should not be affected by these changes, only |
| 1030 |
the renderings, you may delete the faulty picture files instead from |
| 1031 |
the Results screen and the ambient file (if it exists) from the |
| 1032 |
Options screen. |
| 1033 |
| 1034 |
.Action.Touch |
| 1035 |
| 1036 |
The "Touch" button on the Action screen |
| 1037 |
should be used when some insignificant change has |
| 1038 |
been made to the Radiance input files, which might otherwise cause |
| 1039 |
the octree to be rebuilt and the picture files to be rerendered. |
| 1040 |
| 1041 |
Care should be exercised in using this button since you may have |
| 1042 |
made a change that really does affect the octree in an important |
| 1043 |
way. |
| 1044 |
Even something as seemingly trivial as deleting an unused material |
| 1045 |
will cause an unfrozen octree to become invalid and unusable. |
| 1046 |
| 1047 |
Therefore, if you know the octree should be rebuilt, but you do not |
| 1048 |
want to cause any of the currently rendered pictures to be redone, |
| 1049 |
press the "oconv" button to bring the octree up to date, followed |
| 1050 |
by the "Touch" button. |
| 1051 |
(This will still cause the ambient file to be removed, |
| 1052 |
unfortunately.) |
| 1053 |
| 1054 |
.Action.Rview |
| 1055 |
| 1056 |
The "rview" button on the Action screen starts an interactive |
| 1057 |
rendering for the selected view, indicated by the menu button |
| 1058 |
just to the right. |
| 1059 |
Other views may be accessed within rview using the "L name" |
| 1060 |
command, and new views can be added with the "V name" |
| 1061 |
command. |
| 1062 |
(See the rview(1) man page and the "View" topic in the current |
| 1063 |
help category for more information.) |
| 1064 |
| 1065 |
If the octree is out-of-date, it will be rebuilt before rendering |
| 1066 |
begins. |
| 1067 |
| 1068 |
.Action.View |
| 1069 |
| 1070 |
The Action screen contains two menus for selecting views. |
| 1071 |
The top menu, next to the "rview" button, sets the view to start |
| 1072 |
with in rview, and is selected from the current view list. |
| 1073 |
The second view menu, next to the "Start" button for batch |
| 1074 |
rendering, selects the view or views to render in batch mode. |
| 1075 |
If the special entry "ALL" is selected, then every view in the |
| 1076 |
current list will be rendered if it hasn't been already. |
| 1077 |
| 1078 |
The batch rendering view menu also selects the view or views |
| 1079 |
to use in producing a script during a dry run. |
| 1080 |
| 1081 |
.Action.Start |
| 1082 |
| 1083 |
The "Start" button for batch rendering on the Action screen |
| 1084 |
initiates a rad rendering process in the background using the |
| 1085 |
selected view or views shown on the menu button to the right. |
| 1086 |
| 1087 |
If any of the rad variables have been changed since the |
| 1088 |
file was last saved, you will first be asked if you wish to save |
| 1089 |
your changes before starting a background process. |
| 1090 |
If you discard these changes, then the batch rendering will be |
| 1091 |
conducted using the previously saved values. |
| 1092 |
| 1093 |
Once a background process is going, the "Start" button is |
| 1094 |
disabled, and rendering progress can be monitored by checking |
| 1095 |
the error file periodically. |
| 1096 |
(This file is named by the root of the rad input file followed by |
| 1097 |
".err".) |
| 1098 |
When a batch process is started or already running, this button |
| 1099 |
will be disabled. |
| 1100 |
| 1101 |
The background process can be killed during this or later |
| 1102 |
invocations of trad using the "Kill" button. |
| 1103 |
| 1104 |
.Action.Kill |
| 1105 |
| 1106 |
The batch rendering "Kill" button kills the |
| 1107 |
background process started earlier with the "Start" button. |
| 1108 |
The rad process id is taken from the first line of the error file, |
| 1109 |
and this process and all its children are killed when the |
| 1110 |
button is pressed. |
| 1111 |
| 1112 |
So long as there is an ambient file specified in the Options |
| 1113 |
screen, no data is lost by killing and restarting a batch |
| 1114 |
rendering, though some new startup costs will be incurred. |
| 1115 |
| 1116 |
The "Kill" button is disabled if no running batch process is |
| 1117 |
detected. |
| 1118 |
| 1119 |
.Action.CheckErr |
| 1120 |
| 1121 |
Pressing the "Check errors" button |
| 1122 |
displays the contents of the batch rendering error file, named |
| 1123 |
by the root of the current rad input file followed by the ".err" |
| 1124 |
suffix. |
| 1125 |
This file will contain the command lines executed by rad so far, |
| 1126 |
and may or may not contain additional progress reports from |
| 1127 |
rpict, depending on the initial setting of the "REPORT" variable. |
| 1128 |
| 1129 |
If no error file exists, this button will be disabled. |
| 1130 |
| 1131 |
.Action.Script |
| 1132 |
| 1133 |
The dry run "Script" button runs rad with the |
| 1134 |
"-n" option so that you may see the commands that would be |
| 1135 |
executed during a batch run without actually executing them. |
| 1136 |
If a file is named in the window next to this button, the output |
| 1137 |
will simply be written to that file. |
| 1138 |
If no file is named, a temporary file is created and an editor |
| 1139 |
window is opened on it. |
| 1140 |
| 1141 |
Producing a dry run also writes the "Optfile" if one is specified |
| 1142 |
| 1143 |
| 1144 |
or rpiece(1). |
| 1145 |
| 1146 |
The view or views are selected by the same menu used for |
| 1147 |
batch rendering. |
| 1148 |
(See the "View" topic under the current help category for more |
| 1149 |
information.) |
| 1150 |
| 1151 |
.Action.Edit |
| 1152 |
| 1153 |
The dry run "Edit" button is used to edit the named script file |
| 1154 |
created by pressing the "Script" button. |
| 1155 |
If no file is named, this button is ineffective. |
| 1156 |
| 1157 |
.Action.Delete |
| 1158 |
| 1159 |
The "Delete" button removes the named script file, created by the |
| 1160 |
"Script" button. |
| 1161 |
If no file is named, or the named file does not exist, this button has |
| 1162 |
no effect. |
| 1163 |
| 1164 |
.Results.Intro |
| 1165 |
| 1166 |
This button selects the trad Results screen. |
| 1167 |
This screen permits rendered pictures to be displayed, |
| 1168 |
converted to other image formats, and printed. |
| 1169 |
Only finished pictures may be converted or printed, but |
| 1170 |
incomplete pictures (i.e. aborted renderings or renderings in |
| 1171 |
progress) may be displayed interactively. |
| 1172 |
| 1173 |
The left-hand window shows a list of completed views, and the |
| 1174 |
right-hand window shows views that have been started but not |
| 1175 |
finished. |
| 1176 |
Note that other views may not even be started, thus may not |
| 1177 |
appear in either list. |
| 1178 |
Also, just because a view appears on the Results screen, it does |
| 1179 |
not mean that view is up-to-date with respect to the Radiance |
| 1180 |
input files. |
| 1181 |
(The best way currently to tell which pictures are out-of-date |
| 1182 |
is to press the "Script" button on the Action screen and examine |
| 1183 |
the output.) |
| 1184 |
| 1185 |
.Results.Finished |
| 1186 |
| 1187 |
The "Finished views" list box on the Results screen shows those |
| 1188 |
renderings which have completed, whether or not they are up-to-date |
| 1189 |
with respect to the Radiance input files. |
| 1190 |
Select pictures in this box for display, conversion to other image |
| 1191 |
formats, and/or printing. |
| 1192 |
Selected pictures may also be deleted with the "Delete" button. |
| 1193 |
| 1194 |
To select one or more pictures from this box, click the left mouse |
| 1195 |
button on a view name, and drag it up or down to select multiple |
| 1196 |
views. |
| 1197 |
Shift-click also allows views to be added to the selection. |
| 1198 |
| 1199 |
.Results.Unfinished |
| 1200 |
| 1201 |
The "Unfinished views" list box on the Results screen shows those |
| 1202 |
renderings which have not yet completed. |
| 1203 |
These partial pictures may or may not be out-of-date |
| 1204 |
| 1205 |
Select pictures in this box for display or deletion. |
| 1206 |
It is not possible to convert or print an unfinished picture. |
| 1207 |
| 1208 |
| 1209 |
| 1210 |
views. |
| 1211 |
| 1212 |
| 1213 |
.Results.Rescan |
| 1214 |
| 1215 |
The "Rescan" button on the Results screen is used to update the |
| 1216 |
finished and unfinished view lists, in case one or more pictures |
| 1217 |
has completed since the Results screen was brought up. |
| 1218 |
| 1219 |
.Results.Delete |
| 1220 |
| 1221 |
The "Delete" button on the Results screen is used to remove the |
| 1222 |
selected picture files from the filesystem. |
| 1223 |
Verification is required before any action is taken. |
| 1224 |
| 1225 |
.Results.Display |
| 1226 |
| 1227 |
The "Display" button on the Results screen may be used to display |
| 1228 |
the selected images using ximage(1) or any other Radiance picture |
| 1229 |
display program. |
| 1230 |
| 1231 |
The current display command is shown in the adjacent command window, |
| 1232 |
and may be customized if necessary. |
| 1233 |
(See the "DispCommand" topic in the current help category for |
| 1234 |
details.) |
| 1235 |
| 1236 |
.Results.DispCommand |
| 1237 |
| 1238 |
The current display command in the Results screen determines how |
| 1239 |
finished and unfinished Radiance pictures will be displayed. |
| 1240 |
This command contains two variable fields. |
| 1241 |
The first field is a signed integer, indicated by the "%+d" format. |
| 1242 |
The second field is a string, indicated by the "%s" format. |
| 1243 |
Both fields must appear in any display command used, and must be in |
| 1244 |
this order on the command line. |
| 1245 |
The first field is used to adjust the exposure of an unfinished |
| 1246 |
picture, and the second field is the file name. |
| 1247 |
The rest of the command is arbitrary, so long as it is understood by |
| 1248 |
the system. |
| 1249 |
| 1250 |
The default command is "ximage -e %+d %s >& /dev/null &", which |
| 1251 |
executes ximage in the background and sends any output (including |
| 1252 |
error messages) to the null device. |
| 1253 |
If you don't wish ximage to run in the background, you may remove |
| 1254 |
the last part of the command (" >& /dev/null &"). |
| 1255 |
| 1256 |
.Results.Convert |
| 1257 |
| 1258 |
The "Convert" button on the Results screen converts the selected |
| 1259 |
pictures to the format indicated on the menu button to the right. |
| 1260 |
(See the "ConvType" topic under the current help category for |
| 1261 |
details.) |
| 1262 |
| 1263 |
Each finished picture is converted to the selected format and given |
| 1264 |
the name indicated by the adjacent window labeled "File". |
| 1265 |
(See the "ConvFile" topic under the current help category for |
| 1266 |
details.) |
| 1267 |
| 1268 |
.Results.ConvType |
| 1269 |
| 1270 |
The image type button on the Results screen determines the |
| 1271 |
destination format for converted Radiance pictures. |
| 1272 |
You may choose from the list that pops up when you press this |
| 1273 |
button. |
| 1274 |
Often, a given format may have more than one subtype. |
| 1275 |
In general, 8-bit means 8-bit color with a lookup table, |
| 1276 |
B&W means 8-bit greyscale with no lookup, and 24-bit means 24-bit |
| 1277 |
true color. |
| 1278 |
| 1279 |
The file suffix is determined by the basic conversion type, but may |
| 1280 |
be changed along with the rest of the name by editing the file name |
| 1281 |
window. |
| 1282 |
| 1283 |
details.) |
| 1284 |
| 1285 |
.Results.ConvFile |
| 1286 |
| 1287 |
The image conversion file name window on the Results screen should contain |
| 1288 |
a single "%s" format field, which will be replaced by the view name |
| 1289 |
being converted. |
| 1290 |
| 1291 |
The default name is the same as the value of the rad "PICTURE" |
| 1292 |
variable, followed by a suffix appropriate to the selected file type. |
| 1293 |
| 1294 |
.Results.Print |
| 1295 |
| 1296 |
The "Print" button on the Results screen executes the given |
| 1297 |
system command to print one copy each of the selected picture(s). |
| 1298 |
This button does not work on unfinished pictures. |
| 1299 |
| 1300 |
The actual command used for printing may be edited in the adjacent |
| 1301 |
window. |
| 1302 |
(See the "PrintCommand" topic under the current help category for |
| 1303 |
details.) |
| 1304 |
| 1305 |
.Results.PrintCommand |
| 1306 |
| 1307 |
The print command window on the Results screen contains the system |
| 1308 |
command to use in printing out finished Radiance pictures. |
| 1309 |
The "%s" format field, which must appear somewhere in the command, |
| 1310 |
is replaced by the selected Radiance picture file name(s). |
| 1311 |
| 1312 |
The default command is "ra_ps %s | lpr", which converts the Radiance |
| 1313 |
picture to a black and white PostScript file and sends it to the lpr |
| 1314 |
print spooler. |
| 1315 |
If your printer does not understand PostScript, or your system does |
| 1316 |
not support lpr, this command must obviously be changed. |
