--- ray/src/util/trad.hlp 1995/09/13 13:15:29 2.14 +++ ray/src/util/trad.hlp 1995/09/28 14:11:45 2.15 @@ -1,4 +1,4 @@ - $Id: trad.hlp,v 2.14 1995/09/13 13:15:29 greg Exp $ + $Id: trad.hlp,v 2.15 1995/09/28 14:11:45 greg Exp $ This help file is associated with the trad interface to the Radiance rad(1) program. Trad consists of trad.wsh and one do_*.tcl file for @@ -1359,10 +1359,13 @@ details.) The print command window on the Results screen contains the system command to use in printing out finished Radiance pictures. The "%s" format field, which must appear somewhere in the command, -is replaced by the selected Radiance picture file name(s). +is replaced by the selected Radiance picture file name. +This command is executed multiple times if multiple files are +selected. The default command is "ra_ps %s | lpr", which converts the Radiance picture to a black and white PostScript file and sends it to the lpr print spooler. +Add a "-c" option to "ra_ps" if the printer supports color. If your printer does not understand PostScript, or your system does not support lpr, this command must obviously be changed.
