--- ray/src/util/trad.hlp 1995/02/21 14:27:06 2.10 +++ ray/src/util/trad.hlp 1995/07/06 12:23:37 2.11 @@ -1,4 +1,4 @@ - $Id: trad.hlp,v 2.10 1995/02/21 14:27:06 greg Exp $ + $Id: trad.hlp,v 2.11 1995/07/06 12:23:37 greg Exp $ This help file is associated with the trad interface to the Radiance rad(1) program. Trad consists of trad.wsh and one do_*.tcl file for @@ -744,6 +744,17 @@ Normally, either the X or the Y resolution is reduced to maintain a specific pixel aspect ratio (1 by default). The default value for this variable is "512". + +.Views.Rawsave + +The "Rawsave" check box determines whether or not the raw output picture +from rpict will be saved. +The default action (box unchecked) is to remove this file, since it +takes up disk space and is not generally useful. +However, if you wish to perform some special filtering function on +the file, this file can be renamed instead of removed by checking this box. +The final name in this case will be the same as the finished +picture, except with a ".rwp" suffix. .Views.Copy
