1 |
$Id$ |
2 |
3 |
This help file is associated with the trad interface to the Radiance |
4 |
rad(1) program. Trad consists of trad.wsh and one do_*.tcl file for |
5 |
each screen. There are currently seven such screens: File, Scene, |
6 |
Zone, Views, Options, Action and Results. |
7 |
8 |
.Trad.Intro |
9 |
10 |
Trad is a graphical user interface (GUI) to the |
11 |
rad(1) program, which controls the operation of the basic |
12 |
Radiance scene compiling, rendering and picture filtering programs. |
13 |
Trad also includes links to a few utilities for displaying and |
14 |
converting results, but most of what it does can be done by editing a |
15 |
small text file, called the "rad input file". |
16 |
Scene creation still requires the use of a text or graphical editor, |
17 |
or translation from some external CAD format. |
18 |
19 |
Trad interaction is broken into seven screens. |
20 |
Each screen is accessed by pressing its associated radio |
21 |
button along the right-hand side of the main window. |
22 |
If trad is started with no file name, the File screen is displayed, |
23 |
and you must pick a valid rad input file before any other screen may |
24 |
be accessed. |
25 |
If a name is given for a file that doesn't exist, trad goes to the |
26 |
Scene screen and prompts you to enter the names of one or more |
27 |
Radiance scene description files. |
28 |
If a rad input file exists already, trad determines if there are |
29 |
renderings still to be done or if everything is finished. |
30 |
If there is still work to be done, trad opens first with the Action |
31 |
screen. |
32 |
If all renderings are complete and up-to-date, trad opens right to |
33 |
Results screen. |
34 |
35 |
For additional guidance on Radiance in general, consult the Radiance |
36 |
Tutorial, Reference Manual, and man pages. |
37 |
In particular, it is a good idea to read through the rad(1) man page |
38 |
before using this interface. |
39 |
40 |
To find out how to get more help, press the "Next" button to the |
41 |
right. |
42 |
43 |
.Trad.Help |
44 |
45 |
If you have specific questions about trad, search through the |
46 |
category and topic menus on this help window, or press and release |
47 |
the left mouse button while holding the control key over the object of |
48 |
curiosity in the main trad window. |
49 |
(In general, only active windows are given help file links -- click |
50 |
on these rather than the text labels.) |
51 |
Additional search capabilities are available over all topics using |
52 |
the "Grep" button. |
53 |
54 |
For help on the help facility itself, Control-click on the problem |
55 |
help widget or on the window title in the upper right corner for |
56 |
more general information. |
57 |
(To get back to trad-specific help, press the "HELP" button in the |
58 |
main trad window or Control-click on a trad widget.) |
59 |
60 |
.Trad.Messages |
61 |
62 |
Informative messages, commands executed by rad, and errors |
63 |
appear in the message window at the bottom of the trad frame. |
64 |
Growing the trad window means growing this message window, and |
65 |
not much else. |
66 |
This is not really necessary, since the window will be grown |
67 |
automatically if the message requires it. |
68 |
69 |
Serious errors will be accompanied by the sounding of the bell. |
70 |
71 |
.Trad.Quit |
72 |
73 |
To quit the trad application, press the "Quit" button at any time. |
74 |
If you have made changes to the rad input variables, you will be |
75 |
asked prior to program exit if you want to save your changes first. |
76 |
77 |
Any batch process running in the background will continue to run, |
78 |
and the associated error messages will be viewable by |
79 |
trad later when you open the same rad input file. |
80 |
81 |
.File.Intro |
82 |
83 |
This button selects the trad File screen, which allows rad input |
84 |
files to be loaded and saved, and new files to be created. |
85 |
86 |
.File.Load |
87 |
88 |
This button loads the selected file into trad. |
89 |
If the current file has been changed and these changes have not been |
90 |
saved, you will be given first the opportunity to save your changes. |
91 |
92 |
The actual load operation may take several seconds or even minutes, |
93 |
depending on the status of the rendering process. |
94 |
This is because the rad program itself is used to interpret the |
95 |
input file, and if there is no up-to-date octree associated with the |
96 |
file, it is necessary to run getbbox on the entire scene |
97 |
before the variable values can be set. |
98 |
It is possible to eliminate this delay in future loads by going to |
99 |
the Action screen and running oconv. |
100 |
101 |
If the opened file has read-only mode set (see chmod(1)), then the |
102 |
"Read Only" check box will be lit. |
103 |
Unchecking this box means that it will be possible to save the file |
104 |
later, though the actual mode on the file will not be changed until |
105 |
it is saved. |
106 |
Loading a writable file always clears the "Read Only" check box. |
107 |
108 |
If an error is encountered while trying to load the file, a message |
109 |
will be printed in the box at the bottom. |
110 |
111 |
.File.Save |
112 |
113 |
The "Save" button in the File screen saves any changes to the |
114 |
current file. |
115 |
This information is saved in the original file by default, but may |
116 |
be saved in another file by entering a new name in the "File" field. |
117 |
If this new file already exists, a dialogue box will ask if you really |
118 |
want to overwrite it. |
119 |
If the file name is different than the original |
120 |
one loaded, the "Read Only" check box will be ignored. |
121 |
122 |
.File.New |
123 |
124 |
The "New" button clears all rad variables in preparation for |
125 |
writing a new rad input file. |
126 |
If the file selected already exists, a warning box will ask if you |
127 |
really want to ignore the previous file contents. |
128 |
If you agree, then no warning will be given when the file is later |
129 |
overwritten. |
130 |
131 |
.File.ReadOnly |
132 |
133 |
The "Read Only" check box permits you to indicate that the opened |
134 |
file should not be overwritten. |
135 |
This box will be checked automatically if the permissions on the |
136 |
edited file do not allow writing by the user. |
137 |
If the box is subsequently unchecked, trad will attempt to change |
138 |
permissions and write to the file when a save is requested. |
139 |
If this fails, an error message will indicate the problem. |
140 |
141 |
.Scene.Intro |
142 |
143 |
This button selects the trad Scene screen. |
144 |
On this screen, you may enter the octree file and the scene files |
145 |
that go into it, as well as any mkillum or other files on which the |
146 |
scene depends. |
147 |
These files are generally produced by hand in a text editor or by |
148 |
conversion from an external CAD format, such as DXF. |
149 |
(See the Radiance Reference Manual and Radiance Tutorial for details on the |
150 |
information contained in these files.) |
151 |
152 |
To enter a file of a particular type, press the corresponding button |
153 |
to get a dialogue box that allows you to pick existing files from any |
154 |
directory. |
155 |
156 |
Use the "Discard" button to remove one or more files from a specific |
157 |
list. |
158 |
The actual file is untouched. |
159 |
160 |
.Scene.Octree |
161 |
162 |
The "Octree" entry in the Scene screen names the octree file to be |
163 |
compiled by oconv from the materials and scene files. |
164 |
(See the oconv(1) man page for more details.) |
165 |
166 |
If make(1) is being used to build the octree, you should leave all |
167 |
other windows on this screen empty. |
168 |
The octree can still be rebuilt from trad by pressing the "oconv" |
169 |
or "Force" buttons on the Action screen, but normally it is |
170 |
expected to be current. |
171 |
In particular, an unsupported octree must exist before loading |
172 |
a rad input file on which it depends. |
173 |
174 |
The default octree name is the root name from the render input file |
175 |
plus ".oct". |
176 |
If mkillum is being used (i.e. one or more illum files is given), |
177 |
then two additional octrees will be created, named the same except |
178 |
for an additional "0" or "1" immediately before the file suffix |
179 |
(normally ".oct"). |
180 |
181 |
To delete the named octree, and therefore force the scene to be |
182 |
recompiled and all the pictures to be rerendered, use the "Delete" |
183 |
button next to the octree window. |
184 |
185 |
.Scene.OctDelete |
186 |
187 |
The "Delete" button next to the octree window removes the named |
188 |
octree from the filesystem, forcing the scene to be later recompiled |
189 |
and all the pictures to be rerendered (if desired). |
190 |
This is appropriate if you add or remove materials, scene or illum |
191 |
files from one or more lists, or make some change to a materials file |
192 |
that requires the octree to be rebuilt (such as adding or removing |
193 |
individual materials). |
194 |
195 |
Verification is required before the octree will be deleted. |
196 |
197 |
You can achieve the same effect as manually removing the octree by |
198 |
pressing the "Force" button on the scene compilation section |
199 |
of the Action screen. |
200 |
(See the "Force" topic under the "Action" help category for more |
201 |
information.) |
202 |
203 |
.Scene.Materials |
204 |
205 |
Materials files generally contain Radiance material descriptions |
206 |
only, not geometry. |
207 |
The purpose of listing them separately is so that minor changes to |
208 |
material parameters will not force the octree to be rebuilt, |
209 |
incurring an additional delay that is unnecessary. |
210 |
211 |
The "Materials" button is used to add materials files to the list. |
212 |
A dialogue box appears when you press this button and allows you to |
213 |
select files to be included. |
214 |
Each new selection is added to the end of the materials list. |
215 |
The default matching pattern for material files is "*.mat". |
216 |
This may of course be reassigned within the file selection window. |
217 |
218 |
The list box showing the current materials may be edited in three |
219 |
ways besides the dialogue for adding files. |
220 |
First, entries may be removed from the list |
221 |
using the "Discard" button. |
222 |
Second, entries may be moved within the box by selecting them with |
223 |
the left mouse button and clicking the middle mouse button over the |
224 |
entry you wish to place the selected items above. |
225 |
If you wish to put the selected items at the very end of the list, |
226 |
click the middle mouse button below the last entry. |
227 |
Third, entries may be moved from other windows by |
228 |
selecting them and pressing the middle button. |
229 |
This works for the list boxes on this screen as well as selections |
230 |
in other windows on the display. |
231 |
232 |
The order of materials files is usually unimportant, but sometimes |
233 |
there are definitions in later files that depend on prerequisites in |
234 |
earlier files. |
235 |
An example of this is a window illum source that depends on a sky |
236 |
description file, which must appear before it. |
237 |
The order of files shown in the list is the order they will be given |
238 |
to oconv and therefore to the rendering programs. |
239 |
240 |
.Scene.Illum |
241 |
242 |
Illum files are Radiance scene descriptions that contain surfaces |
243 |
to be converted into illum sources by mkillum(1). |
244 |
Please consult the manual page for mkillum and understand the |
245 |
Radiance Tutorial before using this box, since these files differ slightly |
246 |
from standard Radiance scene descriptions. |
247 |
248 |
The "Illum" button is used to add illum files to the list. |
249 |
250 |
251 |
Each new selection is added to the end of the illum list. |
252 |
The default matching pattern for material files is "*.rad". |
253 |
254 |
255 |
The list box showing the current illum files may be edited in three |
256 |
257 |
258 |
259 |
260 |
261 |
262 |
263 |
264 |
265 |
266 |
267 |
268 |
269 |
.Scene.Scene |
270 |
271 |
Scene files give the geometry and (perhaps) some of the materials |
272 |
used in a particular Radiance model. |
273 |
These files are given to oconv(1) in the order specified. |
274 |
The ordering of files is usually not important, unless some later |
275 |
files use materials or other modifiers defined in earlier files. |
276 |
277 |
The "Scene" button is used to add scene files to the list. |
278 |
279 |
280 |
Each new selection is added to the end of the scene list. |
281 |
282 |
283 |
284 |
The list box showing the current scene files may be edited in three |
285 |
286 |
287 |
288 |
289 |
290 |
291 |
292 |
293 |
294 |
295 |
296 |
297 |
298 |
.Scene.Objects |
299 |
300 |
Object files are files on which the given octree depends, but which |
301 |
are not included directly on the oconv command line. |
302 |
If any of these files is modified, then it is assumed that the |
303 |
octree must be rebuilt. |
304 |
305 |
To automatically determine which files in the working directory |
306 |
affect the octree, press the "Auto" button just below the "Objects" |
307 |
button. |
308 |
Note that this will only add files to the object list. |
309 |
If you wish to completely replace what is already there, you must |
310 |
therefore select all the files and use the "Discard" button before |
311 |
pressing "Auto". |
312 |
313 |
.Scene.Discard |
314 |
315 |
The "Discard" button removes the selected file names from a list. |
316 |
The actual files are untouched, of course. |
317 |
(Some care should be taken here, since there is no undo |
318 |
function associated with this window other than reloading the |
319 |
original information with the "Revert" button.) |
320 |
321 |
.Scene.Edit |
322 |
323 |
Use the "Edit" button to open a text editor on the selected file(s). |
324 |
This is a convenient way to look at and change the contents of the |
325 |
Radiance input files. |
326 |
327 |
.Scene.Copy |
328 |
329 |
The "Copy" button may be used to selectively copy the scene file |
330 |
information from another rad input file. |
331 |
Specifically, the variables "OCTREE, materials, illum, scene and |
332 |
objects" will be read in to replace the current values. |
333 |
334 |
All other variables will be unaffected. |
335 |
336 |
.Scene.Revert |
337 |
338 |
The "Revert" button is a convenient way to revert to the original |
339 |
values in the rad input file. |
340 |
Only the variables on the Scene screen will be affected, but any changes |
341 |
to these variables since the last save will be lost. |
342 |
343 |
.Zone.Intro |
344 |
345 |
This button selects the trad Zone screen. |
346 |
On this screen, the user should enter the maximum and minimum |
347 |
coordinates of the zone of interest for this set of renderings. |
348 |
This zone need not correspond exactly to any interior or exterior |
349 |
walls, as it is used primarily to set rendering parameters and |
350 |
standard viewpoints. |
351 |
352 |
An interior zone means that standard viewpoints will be selected |
353 |
from the inside of this box. |
354 |
An exterior zone means that standard viewpoints will be selected |
355 |
from the outside of this box. |
356 |
The default zone is an exterior one computed from the bounding box |
357 |
of the entire scene. |
358 |
(Note that this is not usually desirable.) |
359 |
360 |
In addition to the ZONE variable, this screen offers the ability |
361 |
to set four other rad variables that are generally associated with a |
362 |
particular scene and a particular zone. |
363 |
These are the rad DETAIL, INDIRECT, VARIABILITY and EXPOSURE |
364 |
variables. |
365 |
For more information on these topics, use the Topic menu or consult |
366 |
the rad manual page. |
367 |
368 |
.Zone.Type |
369 |
370 |
There are two types of zones understood by rad, "Interior" and |
371 |
"Exterior". |
372 |
An interior zone is indicated when renderings generally take place |
373 |
inside a specified 3-d box. |
374 |
A typical example might be a single room or auditorium. |
375 |
An exterior zone is indicated when renderings generally take place |
376 |
outside a specified 3-d box, which is the focus of attention. |
377 |
A typical example might be a building exterior or a single object, |
378 |
such as a chair. |
379 |
380 |
.Zone.Zone |
381 |
382 |
A zone is specified by six real numbers, corresponding to the world |
383 |
coordinates of the box's corners. |
384 |
Zone boxes are always axis-aligned, therefore one need only specify |
385 |
the minimum and maximum X, Y, and Z coordinates. |
386 |
387 |
The exact values of these coordinates is not terribly important, as |
388 |
they are only used to guide the setting of certain rendering |
389 |
parameters and standard view positions. |
390 |
It does not matter for instance whether the values lie on the inside |
391 |
or the outside of walls, or if there are non-rectilinear geometries |
392 |
defining the space perimeter. |
393 |
In fact, the whole space may not even be aligned with the X, Y, and Z |
394 |
axes, and a very approximate box may be given. |
395 |
In this case, the standard views may not be very intelligent or |
396 |
useful, but the rendering parameters will still be satisfactory so |
397 |
long as the overall size of the given box is close to the overall |
398 |
size of the space. |
399 |
400 |
The Zone entry windows may be manipulated in the following ways. |
401 |
Control-U clears the current window. |
402 |
Control-V pastes the contents of the current selection at the |
403 |
insertion point. |
404 |
Return moves the focus to the next window in the chain. |
405 |
406 |
.Zone.Detail |
407 |
408 |
The "Detail" setting indicates the relative level |
409 |
of geometric detail in this zone. |
410 |
If the zone is empty except for a few large pieces of furniture, a |
411 |
"Low" setting is indicated. |
412 |
(For an exterior zone, low detail would mean that the object is |
413 |
relatively simple.) |
414 |
If the zone contains a usual amount of furniture and clutter, a |
415 |
"Medium" setting is appropriate. |
416 |
If the zone contains a great many small objects or protrusions, a |
417 |
setting of "High" is indicated. |
418 |
419 |
This variable is used by rad to set rendering parameters that are |
420 |
affected by the sizes of objects relative to the overall size of the |
421 |
space. |
422 |
423 |
.Zone.Indirect |
424 |
425 |
The "Indirect" setting indicates how important indirect illumination |
426 |
is in this space. |
427 |
A setting of "0" means that most light falls directly on visible |
428 |
surfaces, and this setting can be used in most cases. |
429 |
A setting of "1" means that most objects are not directly |
430 |
illuminated by light sources, but receive light only after it has |
431 |
bounced once off some other surface, such as the ceiling. |
432 |
Likewise, a setting of "2" means that light must reflect twice off |
433 |
other surfaces before reaching most objects of interest. |
434 |
435 |
Keep in mind that the rendering calculation increases substantially |
436 |
with each increment to this variable, so it is a good idea to use |
437 |
the smallest reasonable value. |
438 |
439 |
.Zone.Variability |
440 |
441 |
The "Variability" setting gives a qualitative indication of how |
442 |
light varies in magnitude over surfaces in this zone. |
443 |
In a typical direct or indirect lighting situation, this variable |
444 |
would be set to "Low", indicating that light is fairly uniform |
445 |
throughout the space. |
446 |
If there are some areas that are much better lit than others, such |
447 |
as desks with powerful tasks lights in a room with dimmer ambient |
448 |
lighting, a "Medium" setting is appropriate. |
449 |
If there is direct sunlight entering the room, casting bright |
450 |
patches on some surfaces and not others, then a setting of "High" is |
451 |
indicated. |
452 |
453 |
Note that this variable speaks to the magnitude of light variations |
454 |
more than the patterns of light. |
455 |
It may well be that the light is casting interesting patterns such |
456 |
as scallops on the walls or something, but as long as the variations |
457 |
in brightness are less than an order of magnitude or so, it is a low |
458 |
variability situation. |
459 |
The high variability |
460 |
example given above of direct sun entering a space corresponds to a |
461 |
a variation in brightness of about three orders of magnitude, or |
462 |
1,000 to 1! |
463 |
464 |
.Zone.Exposure |
465 |
466 |
The "Exposure" setting gives the multiplier between the initial |
467 |
radiance values at each pixel (in watts/steradian/meter^2) to the |
468 |
display pixel values (in the range of 0-1, where 0 is black and 1 is |
469 |
the maximum monitor output). |
470 |
This setting also determines the average "ambient level," which is |
471 |
an important parameter for rendering accuracy. |
472 |
473 |
There are two basic ways to compute the exposure value. |
474 |
The first is by trial and error, where the value is adjusted up and |
475 |
down within rview using the "e = value" command. |
476 |
Though it sounds flaky, this is the most reliable way to set the |
477 |
exposure (and ambient level) in general lighting situations. |
478 |
479 |
The second method is using a zonal cavity approximation. |
480 |
For this, you must estimate the total light flux entering the zone |
481 |
from light sources and windows, and the total illuminated area. |
482 |
(This applies to interior zones, only. For exterior zones, use the |
483 |
value suggested by gensky in its output.) |
484 |
In addition, you must approximate the area-weighted average |
485 |
reflectance of the illuminated surfaces. |
486 |
The formula then for the exposure multiplier using this information |
487 |
is: pi*tot_area*(1-avg_refl)/(2*tot_flux*avg_refl) |
488 |
where pi is 3.1416, tot_area is given in square meters and |
489 |
tot_flux is given in watts. |
490 |
(Divide total lumens by 179 lumens/watt to get watts.) |
491 |
492 |
The exposure value may either be given as a positive real value, or |
493 |
as a real value preceeded by a '+' or '-' indicating a positive or |
494 |
negative number of f-stops (powers of two) from the original value. |
495 |
496 |
If no exposure is given, pfilt will automatically compute the |
497 |
average for each image, and a default ambient level of 10 will be |
498 |
used for exterior zones and 0.01 for interior zones. |
499 |
500 |
.Zone.Copy |
501 |
502 |
The "Copy" button on the Zone screen takes all values for this |
503 |
screen from another rad input file, replacing the current values. |
504 |
Specifically, the rad variables "ZONE, DETAIL, INDIRECT, |
505 |
VARIABILITY and EXPOSURE" will be copied from the named file. |
506 |
507 |
All other variables will be left untouched. |
508 |
509 |
.Zone.Revert |
510 |
511 |
512 |
513 |
Only the variables on the Zone screen will be affected, but any changes |
514 |
515 |
516 |
.Views.Intro |
517 |
518 |
This button selects the trad Views screen. |
519 |
This screen provides a means of setting the multi-valued |
520 |
"view" variable. |
521 |
Each view setting is listed by name, or by number if no name has |
522 |
been assigned. |
523 |
To add a new view, enter a unique name and specify the view |
524 |
options, |
525 |
then press the "Add" or "Set Default" button. |
526 |
If a view with the same name already exists, it is unconditionally |
527 |
overwritten. |
528 |
To modify a particular view, simply select it, change its name |
529 |
and/or parameters, and press the "Change" button. |
530 |
To remove an unwanted view, select it and press the "Delete" button. |
531 |
To undo this action, simply press the "Add" button again. |
532 |
533 |
The first view in the list is the default given to rview during |
534 |
interactive rendering, and is the first view rendered in a batch run. |
535 |
To change the default view, select the newly desired view and press |
536 |
the "Set Default" button. |
537 |
This button also acts like the "Add" button inasmuch as a new view |
538 |
may be entered and this button will add it and make it the default |
539 |
at the same time. |
540 |
541 |
The Views screen also allows the standard view up vector to be |
542 |
changed, as well as the root picture name and the output resolution. |
543 |
544 |
.Views.List |
545 |
546 |
The list box on the far left of the Views screen shows the |
547 |
currently defined view names. |
548 |
Clicking on any of these with the left mouse button shows the view |
549 |
parameters and allows the view to be edited. |
550 |
551 |
To change the name or options, edit the "Name" or "Options" |
552 |
entry and click on the "Change" button. |
553 |
554 |
Use the "Add" button to add a new view, which may be modified from |
555 |
an old one by changing the name and options. |
556 |
557 |
Use the "Delete" button to delete the selected view from the list. |
558 |
559 |
Views are listed in the order in which they appear in |
560 |
561 |
562 |
The standard view is "X" is used if no views are specified. |
563 |
564 |
.Views.Name |
565 |
566 |
Each view has a unique name, which may be chosen at the user's |
567 |
discretion or taken from a list of standard views, described below. |
568 |
An invented name should be kept as short as possible, since it is |
569 |
added to the picture file name along with the standard ".pic" suffix. |
570 |
571 |
The standard views are specified by strings of the form |
572 |
"[Xx]?[Yy]?[Zz]?[vlah]?". |
573 |
(That is, an optional upper or lower case X followed by an optional |
574 |
upper or lower case Y followed by an optional upper or lower case Z |
575 |
followed by an optional lower case V, L, A or H.) |
576 |
The letters indicate the desired view position, where upper case "X" |
577 |
means maximum X, lower case "y" means minimum Y and so on. |
578 |
The final letter is the view type, where 'v' is perspective (the |
579 |
default), 'l' is parallel, 'a' is angular fisheye, and 'h' is |
580 |
hemispherical fisheye. |
581 |
A perspective view from maximum X, minimum Y would be "Xy" or |
582 |
"Xyv". |
583 |
A parallel view from maximum Z would be "Zl". |
584 |
If "ZONE" is an interior zone, the standard views will |
585 |
be inside the perimeter. |
586 |
If it is an exterior zone, the standard views will be outside. |
587 |
Note that the standard views are best used as starting points, |
588 |
and additional arguments may be given after the |
589 |
identifier to modify a standard view to suit a particular model. |
590 |
591 |
.Views.Options |
592 |
593 |
The "Options" entry window is where the Radiance view |
594 |
corresponding to the selected name is given. |
595 |
If the view is one of the standard names (described in the "Views |
596 |
Name" section), then the options are truly optional, and will |
597 |
modify the standard view. |
598 |
Otherwise, it is usually necessary to specify a set of options to |
599 |
define a view. |
600 |
601 |
The simplest view specification is of the form "-vf viewfile", where |
602 |
"viewfile" is a file created with the rview "view" command, or a |
603 |
Radiance picture. |
604 |
This method of naming views, although convenient, is not the best |
605 |
since it is difficult to know exactly where such a view is by |
606 |
seeing only its file name. |
607 |
Also, the file may change or be moved or removed, and then the view |
608 |
may be different than expected or gone altogether. |
609 |
610 |
To add view options selected from another X11 window, select the |
611 |
text from another window in the normal fashion, use the left mouse |
612 |
button to click on the insertion point in the options string, then |
613 |
use Control-V to insert the text at that point. |
614 |
For convenience, the middle mouse button has been made |
615 |
equivalent to Control-V in this window, but it is not the normal |
616 |
interaction mode for trad. |
617 |
618 |
Consult the rpict(1) manual page for a full description of the various |
619 |
view options, all of which begin with "-v". |
620 |
Just briefly, the "-vt?" option sets the view type, where "?" is |
621 |
replaced by one of the letters "v, l, a or h", corresponding to |
622 |
perspective, parallel, angular and hemispherical fisheye, respectively. |
623 |
The "-vp x y z" option sets the view position (eyepoint), where "x y z" |
624 |
is replaced by the position in 3-space. |
625 |
The "-vd xd yd zd" option sets the view direction, where "xd yd zd" |
626 |
is a vector pointing in the desired direction. |
627 |
(To compute this direction from a "look-at" point, simply subtract |
628 |
the eyepoint from the look-at point. Vector normalization is |
629 |
unnecessary.) |
630 |
The "-vh horiz" and "-vv vert" options set the horizontal and |
631 |
vertical view sizes, respectively. |
632 |
For perspective views, these correspond to full camera angles in |
633 |
degrees. |
634 |
For parallel views (using the "-vtl" option), they correspond to |
635 |
image plane size in world coordinates. |
636 |
The lesser used "-vu xd yd zd", "-vs vs" and "-vl vl" options |
637 |
will not be discussed here. |
638 |
639 |
The order of the view options is irrelevant, unless the same option |
640 |
is given twice, in which case the last one is used. |
641 |
Trad does not check the syntax of the view options strings, so be |
642 |
careful! |
643 |
In particular, make sure that each option and each argument has a |
644 |
space between it and whatever follows. |
645 |
646 |
Hitting return in the "Options" window is equivalent to pressing the |
647 |
"Add" button followed by the "Clear" button. |
648 |
649 |
.Views.Add |
650 |
651 |
The view "Add" button takes the currently defined view given by the |
652 |
"Name" and "Options" windows and appends it to the list of views. |
653 |
If another view by the same name exists, it is removed first. |
654 |
655 |
Since the view is added to the end of the "Views" list, the "Add" |
656 |
button is a convenient way to move views to a lower-priority |
657 |
position. |
658 |
Simply select the view you wish to be last and press "Add". |
659 |
660 |
To add a view as the first (i.e. the default) view instead of the |
661 |
last, use the "Set Default" button. |
662 |
663 |
.Views.Change |
664 |
665 |
The view "Change" button deletes the currently selected view and |
666 |
adds the currently defined view in its place, changing the name |
667 |
and/or view options in the process. |
668 |
669 |
.Views.Delete |
670 |
671 |
The view "Delete" button removes the currently selected view from |
672 |
the view list. |
673 |
674 |
To undo this action, simply press the "Add" button immediately |
675 |
afterwards, while the deleted view is still present in the edit |
676 |
window. |
677 |
678 |
.Views.Clear |
679 |
680 |
The "Clear" button simply clears the "Name" and "Options" windows |
681 |
for the convenience of entering a new view. |
682 |
It has no effect on the rad input variables. |
683 |
684 |
Note that Control-U will always clear an entry box whose cursor is |
685 |
active. |
686 |
687 |
.Views.Default |
688 |
689 |
The "Set Default" button may be used to make the selected view the |
690 |
default view for rendering. |
691 |
This simply moves the view to the top of the list in the rad input file. |
692 |
The default view will be the one normally rendered by rview when rad |
693 |
is started interactively, and is the first view rendered in a batch |
694 |
process. |
695 |
696 |
A new view may be added as the default view by pressing the "Set |
697 |
Default" button rather than the "Add" button. |
698 |
It is never necessary to press both. |
699 |
700 |
If the selected view is already the default, this button will be |
701 |
disabled and will read "Is Default" instead of "Set Default". |
702 |
703 |
.Views.Up |
704 |
705 |
The standard view up vector may be set to the positive X axis (+X), |
706 |
the positive Y axis (+Y), the positive Z axis (+Z), the negative |
707 |
X axis (-X), the negative Y axis (-Y), or the negative Z axis (-Z). |
708 |
709 |
This setting may always be overriden by the "-vu xd yd zd" option, |
710 |
and will be altered for a particular view if it happens to be |
711 |
parallel to the view direction. |
712 |
713 |
.Views.Picture |
714 |
715 |
The root picture file name is given in the "Picture" entry window. |
716 |
To this will be added an underscore, followed by the name of |
717 |
the particular view being rendered, followed by the ".pic" suffix. |
718 |
719 |
To render pictures into a different directory than the one |
720 |
containing the rad input file, simply precede the file name by a |
721 |
relative or absolute directory. |
722 |
(Do not use the tilde shorthand for home directories, |
723 |
as it is not guaranteed to work on all systems.) |
724 |
725 |
The default picture name is the root name of the rad input file. |
726 |
727 |
.Views.Resolution |
728 |
729 |
The final picture resolution is set in the "Resolution" entry |
730 |
window. |
731 |
The first entry is the X resolution (in pixels), and the second |
732 |
(optional) entry is the Y resolution. |
733 |
If there is only one entry, the maximum X and Y resolution will be |
734 |
equal. |
735 |
If a third entry is given, it is taken as the aspect ratio of the |
736 |
destination pixels. |
737 |
A number greater than one means that the pixels on the destination |
738 |
device are taller than they are wide (and therefore there are more |
739 |
of them horizontally than vertically spanning a like distance), and |
740 |
a number less than one means the opposite. |
741 |
An aspect ratio of zero means that the exact given X and Y |
742 |
dimensions are to be honored, whatever the resulting pixel ratio. |
743 |
Normally, either the X or the Y resolution is reduced as necessary |
744 |
to maintain a specific pixel aspect ratio (1 by default). |
745 |
746 |
The default value for this variable is "512". |
747 |
748 |
.Views.Copy |
749 |
750 |
The "Copy" button in the Views screen permits those variables |
751 |
represented on this screen to be copied from another rad input file. |
752 |
Specifically, the affected variables are "view, UP, PICTURE, and |
753 |
RESOLUTION". |
754 |
755 |
The original values will be lost, and all other variables will be |
756 |
untouched. |
757 |
758 |
.Views.Revert |
759 |
760 |
761 |
762 |
Only the variables on the Views screen will be affected, but any changes |
763 |
764 |
765 |
.Options.Intro |
766 |
767 |
This button selects the trad Options screen. |
768 |
This screen allows the setting of various options for |
769 |
controlling the rendering process. |
770 |
The most general option is rendering "Quality", which determines the |
771 |
overall accuracy and beauty of the pictures produced. |
772 |
A separate "Penumbras" option indicates the importance of soft |
773 |
shadows in this scene. |
774 |
The "Ambfile" variable allows you to specify a file for sharing |
775 |
ambient files between runs, and it is recommended that you set |
776 |
this variable for high quality renderings. |
777 |
The "Optfile" variable allows you to specify a separate file for |
778 |
storing rendering options, which reduces the size of the command |
779 |
line and makes it easier to run programs such as rtrace(1). |
780 |
The "Report" variable may be used to specify a time interval (in |
781 |
minutes) between progress reports. |
782 |
783 |
Other windows allow the user to customize the options to oconv(1), |
784 |
mkillum(1), rview(1) and rpict(1), and pfilt(1). |
785 |
786 |
.Options.Quality |
787 |
788 |
The "Quality" setting affects the overall accuracy and beauty of the |
789 |
renderings produced. |
790 |
791 |
A "Low" setting is appropriate for quick checks of scene geometry and |
792 |
crude lighting studies. |
793 |
No interreflection calculation will take place, regardless of the |
794 |
setting of the "INDIRECT" variable, and other options are tuned for |
795 |
speed over accuracy. |
796 |
The computed picture size will exactly equal the final picture |
797 |
size, thus some aliasing may be apparent. |
798 |
799 |
A "Medium" quality setting is most often used for draft renderings, as |
800 |
it provides a good balance between rendering time and accuracy. |
801 |
The number of interreflections calculated will be equal to the |
802 |
setting of the "INDIRECT" variable. |
803 |
The computed picture size will be twice the final size, for a modest |
804 |
degree of anti-aliasing. |
805 |
806 |
A "High" quality setting is usually reserved for final renderings. |
807 |
The number of interreflections computed will equal the value of the |
808 |
"INDIRECT" variable plus one, to guarantee accuracy. |
809 |
The computed picture size will be three times the final size, so |
810 |
aliasing artifacts should be negligible. |
811 |
812 |
When increasing the value of the "Quality" setting, it is usually a |
813 |
good idea to delete the old "Ambfile", if there is one. |
814 |
(See the "AmbDelete" topic under the current help category for |
815 |
details.) |
816 |
817 |
.Options.Penumbras |
818 |
819 |
The "Penumbras" setting determines whether or not Radiance will |
820 |
make a special effort to generate soft shadows from area light sources. |
821 |
Since this is a potentially expensive calculation, penumbras should |
822 |
only be switched "On" when they are really needed. |
823 |
824 |
Leaving this setting "Off" does not mean that area light sources |
825 |
will be treated as points. |
826 |
It only means that some accuracy and possibly some smoothness |
827 |
will be traded for speed in the shadow calculations. |
828 |
829 |
.Options.Ambfile |
830 |
831 |
The "Ambfile" is the file used to store Radiance ambient values for |
832 |
later reuse in other renderings. |
833 |
This can greatly reduce the time required to generate multiple |
834 |
views, as well as improve the quality of a single view whenever |
835 |
interreflections are computed. |
836 |
837 |
It is strongly recommended that the user set this variable, especially |
838 |
when the "QUALITY" variable is set to "High". |
839 |
The usual convention is to use the root name of the rad input file, |
840 |
followed with the ".amb" suffix. |
841 |
It is generally not a good idea to share ambient files between |
842 |
different zones, as the placement and accuracy of these values will |
843 |
vary according to the location and characteristics of each zone. |
844 |
845 |
.Options.AmbDelete |
846 |
847 |
The "Delete" button next to the "Ambfile" window on the Options |
848 |
screens allows you to remove the named ambient file. |
849 |
This is usually done when a change to one or more rad variables |
850 |
casts doubt on the accuracy of the values stored in this file. |
851 |
In particular, increases in the variables, "DETAIL, INDIRECT, |
852 |
VARIABILITY, EXPOSURE or QUALITY" generally invalidate this file. |
853 |
854 |
If the ambient file is not empty, you will be asked to verify this |
855 |
operation since the values may represent a significant computational |
856 |
effort. |
857 |
858 |
.Options.Optfile |
859 |
860 |
The "Optfile" setting assigns a file to hold rendering options, |
861 |
which may be a convenience when these options are reused for |
862 |
rtrace(1) or rpiece(1), or manual invocations of rview or rpict. |
863 |
Using an options file also reduces the size of the command line, |
864 |
making it a little easier on the eye. |
865 |
866 |
To assure that the "Optfile" contents are up-to-date, you should press |
867 |
the "oconv" or "Script" button on the Action screen. |
868 |
869 |
.Options.Report |
870 |
871 |
The "Report" setting indicates the time interval (in minutes) |
872 |
between rpict progress reports. |
873 |
Normally, rpict runs silently, but it is often nice to know how far |
874 |
a given rendering has progressed. |
875 |
Normally, progress reports and errors during batch renderings |
876 |
are sent to the error file given by the root of the rad input |
877 |
file name followed by the ".err" suffix. |
878 |
(See the "Errors" topic under the "Action" screen category.) |
879 |
If you wish these reports and errors to be directed to a different |
880 |
file, follow the time interval by a space and a file name. |
881 |
882 |
No setting on this variable means do not report rendering progress. |
883 |
A zero setting means the same thing, and may be used when a |
884 |
separate error file is desired but progress reports are not. |
885 |
886 |
.Options.Oconv |
887 |
888 |
The "oconv opts" window may be used to specify any additional |
889 |
options to the oconv(1) command used to compile the scene |
890 |
description. |
891 |
892 |
In particular, the "-f" option for creating a "frozen" octree may |
893 |
speed rendering start-up substantially, although it makes it |
894 |
impossible to change even material properties without |
895 |
recompiling the scene again. |
896 |
(The "-f" option is technically incompatible with naming |
897 |
"materials" files on the Scene screen.) |
898 |
899 |
If oconv generates a "set overflow" error, it may mean that the "-r |
900 |
res" option is needed to increase the octree resolution. |
901 |
See the oconv(1) man page for details. |
902 |
903 |
The "-i octree" option should be used with extreme caution, as incremental |
904 |
building of octrees is not very well supported by rad. |
905 |
You may do it this way if you specify the input octree as one of the |
906 |
"Objects" files on the Scene screen, but it is preferable to use the |
907 |
UNIX make(1) utility to incrementally build the octree instead, and |
908 |
indicate this by not specifying any illum or scene files. |
909 |
910 |
.Options.Mkillum |
911 |
912 |
The "mkillum opts" window may be used to specify options to the |
913 |
mkillum(1) command, whose options are actually passed to rtrace(1). |
914 |
These options apply only if there are one or more "Illum" files |
915 |
named on the Scene screen. |
916 |
917 |
It is very important to set mkillum options sensibly, |
918 |
since rad does not have the intelligence to do it for you. |
919 |
920 |
.Options.Render |
921 |
922 |
The "render opts" window is used to specify additional options to |
923 |
the rview(1) and rpict(1) rendering programs. |
924 |
Most of the important parameters are computed by rad, so this |
925 |
window is usually used to override specific parameters or to give |
926 |
additional information, such as which materials to exclude from the |
927 |
interreflection calculation. |
928 |
929 |
.Options.Pfilt |
930 |
931 |
The "pfilt opts" window is used to specify additional options to |
932 |
the pfilt(1) picture filtering program. |
933 |
934 |
Note that the "-e expval", "-x xres" and "-y yres" options are |
935 |
already dictated by the settings of the "EXPOSURE" and "RESOLUTION" |
936 |
variables, and should therefore be used with caution. |
937 |
938 |
Also note that the setting of some pfilt options require a |
939 |
two-pass filtering process, rather than the default single pass. |
940 |
If no "EXPOSURE" setting is given, this is not a problem, but if a |
941 |
value for the "EXPOSURE" variable is set as recommended, then it is |
942 |
necessary to manually specify the "-2" option to pfilt, followed by |
943 |
an exposure that undoes the "EXPOSURE" setting. |
944 |
An equivalent workaround is to unset the EXPOSURE variable and |
945 |
manually set the render option "-av V V V", where "V" is equal to |
946 |
0.5/old_EXPOSURE. |
947 |
948 |
.Options.Copy |
949 |
950 |
The "Copy" button in the Options screen permits those variables |
951 |
952 |
Specifically, the affected variables are "QUALITY, PENUMBRAS, |
953 |
AMBFILE, OPTFILE, REPORT, oconv, mkillum, render and pfilt". |
954 |
955 |
956 |
untouched. |
957 |
958 |
.Options.Revert |
959 |
960 |
The "Revert" button is a convenient way to revert to the original values |
961 |
962 |
Only the variables on the Options screen will be affected, but any changes |
963 |
964 |
965 |
.Action.Intro |
966 |
967 |
This button selects the trad Action screen. |
968 |
This screen is where the actual Radiance programs are |
969 |
run, usually via rad(1). |
970 |
The top row of buttons is used to update the octree following a |
971 |
change to one or more input files. |
972 |
The "rview" button starts an interactive rendering in the |
973 |
foreground. |
974 |
The next set of buttons provides for the control of a batch |
975 |
rendering process, taking place in the background. |
976 |
Finally, the bottom set of buttons allows you to preview what would |
977 |
happen during a batch rendering, or (equivalently) make a script of |
978 |
UNIX commands for later execution. |
979 |
980 |
When the Action screen is first brought up, the message window |
981 |
displays the current status of any batch rendering process. |
982 |
The status must either be "No batch rendering in progress," which |
983 |
means that as far as trad can tell a batch rendering was never |
984 |
started, "Batch rendering stopped," meaning that there is no current |
985 |
process but at least some views have not been rendered or are |
986 |
out-of-date, or "Batch rendering finished," meaning that everything |
987 |
is done. |
988 |
989 |
.Action.Oconv |
990 |
991 |
The "oconv" button on the Action screen may be used to manually |
992 |
compile the scene description and bring the octree up to date. |
993 |
It is normally not necessary to use this button, since the octree |
994 |
will be rebuilt if appropriate prior to rendering. |
995 |
However, if the octree is maintained by make(1) rather than rad, or |
996 |
the octree was never created and you want trad to start a little |
997 |
faster next time, or you just need the octree for some reason other |
998 |
than rendering, this is the button for you. |
999 |
1000 |
If you have made changes to the rad variables or the Radiance |
1001 |
material files that invalidate the current octree or renderings but |
1002 |
would not automatically rebuild the octree because the scene files |
1003 |
themselves were not changed, it may be wise to use the "Force" |
1004 |
button. |
1005 |
In contrast, if you have made some insignificant changes to the |
1006 |
scene files that should not make any difference to the octree or the |
1007 |
renderings, you may want to use the "Touch" button. |
1008 |
1009 |
Pressing the "oconv" button also updates the contents of the |
1010 |
"Optfile" if one is given on the Options screen. |
1011 |
This may be useful for computing rendering parameters for rtrace(1) |
1012 |
or rpiece(1). |
1013 |
1014 |
.Action.Force |
1015 |
1016 |
The "Force" button on the Action screen |
1017 |
causes the octree to be unconditionally rebuilt, |
1018 |
by removing it first. |
1019 |
This will also require all pictures to be rerendered, so only use |
1020 |
this button if it is really necessary, i.e. if you have made |
1021 |
some important changes to the rad |
1022 |
variables on the Scene, Zone or Options screens, but have not |
1023 |
changed any scene file on which the octree depends. |
1024 |
1025 |
If the octree itself should not be affected by these changes, only |
1026 |
the renderings, you may delete the faulty picture files instead from |
1027 |
the Results screen and the ambient file (if it exists) from the |
1028 |
Options screen. |
1029 |
1030 |
.Action.Touch |
1031 |
1032 |
The "Touch" button on the Action screen |
1033 |
should be used when some insignificant change has |
1034 |
been made to the Radiance input files, which might otherwise cause |
1035 |
the octree to be rebuilt and the picture files to be rerendered. |
1036 |
1037 |
Care should be exercised in using this button since you may have |
1038 |
made a change that really does affect the octree in an important |
1039 |
way. |
1040 |
Even something as seemingly trivial as deleting an unused material |
1041 |
will cause an unfrozen octree to become invalid and unusable. |
1042 |
1043 |
Therefore, if you know the octree should be rebuilt, but you do not |
1044 |
want to cause any of the currently rendered pictures to be redone, |
1045 |
press the "oconv" button to bring the octree up to date, followed |
1046 |
by the "Touch" button. |
1047 |
(This will still cause the ambient file to be removed, |
1048 |
unfortunately.) |
1049 |
1050 |
.Action.Rview |
1051 |
1052 |
The "rview" button on the Action screen starts an interactive |
1053 |
rendering for the selected view, indicated by the menu button |
1054 |
just to the right. |
1055 |
Other views may be accessed within rview using the "L name" |
1056 |
command, and new views can be added with the "V name" |
1057 |
command. |
1058 |
1059 |
When using the "V" command to change an existing view, do not |
1060 |
give it a name because the previous view will not be overridden. |
1061 |
Instead, give it a new name (or no name, which will show up as |
1062 |
a number later), then use the Views screen to override the previous |
1063 |
view definition with the new one. |
1064 |
(See the rview(1) man page and the "View" topic in the current |
1065 |
help category for more information.) |
1066 |
1067 |
If the octree is out-of-date, it will be rebuilt before rendering |
1068 |
begins. |
1069 |
1070 |
.Action.View |
1071 |
1072 |
The Action screen contains two menus for selecting views. |
1073 |
The top menu, next to the "rview" button, sets the view to start |
1074 |
with in rview, and is selected from the current view list. |
1075 |
The second view menu, next to the "Start" button for batch |
1076 |
rendering, selects the view or views to render in batch mode. |
1077 |
If the special entry "ALL" is selected, then every view in the |
1078 |
current list will be rendered if it hasn't been already. |
1079 |
1080 |
The view menu next to the "rview" button will be disabled if there |
1081 |
is only one view to choose from. |
1082 |
The view menu next to the "Start" button will be disabled if there |
1083 |
is a batch job in progress, and thus the view cannot be changed. |
1084 |
1085 |
The batch rendering view menu also selects the view or views |
1086 |
to use in producing a script during a dry run. |
1087 |
1088 |
.Action.Start |
1089 |
1090 |
The "Start" button for batch rendering on the Action screen |
1091 |
initiates a rad rendering process in the background using the |
1092 |
selected view or views shown on the menu button to the right. |
1093 |
1094 |
If any of the rad variables have been changed since the |
1095 |
file was last saved, you will first be asked if you wish to save |
1096 |
your changes before starting a background process. |
1097 |
If you discard these changes, then the batch rendering will be |
1098 |
conducted using the previously saved values. |
1099 |
1100 |
Once a background process is going, the "Start" button is |
1101 |
disabled, and rendering progress can be monitored by checking |
1102 |
the error file periodically. |
1103 |
(This file is named by the root of the rad input file followed by |
1104 |
".err".) |
1105 |
When a batch process is started or already running, this button |
1106 |
will be disabled. |
1107 |
1108 |
The background process can be killed during this or later |
1109 |
invocations of trad using the "Kill" button. |
1110 |
1111 |
.Action.Kill |
1112 |
1113 |
The batch rendering "Kill" button kills the |
1114 |
background process started earlier with the "Start" button. |
1115 |
The rad process id is taken from the first line of the error file, |
1116 |
and this process and all its children are killed when the |
1117 |
button is pressed. |
1118 |
1119 |
So long as there is an ambient file specified in the Options |
1120 |
screen, no data is lost by killing and restarting a batch |
1121 |
rendering, though some new startup costs will be incurred. |
1122 |
1123 |
The "Kill" button is disabled if no running batch process is |
1124 |
detected. |
1125 |
1126 |
.Action.CheckErr |
1127 |
1128 |
Pressing the "Check errors" button |
1129 |
displays the contents of the batch rendering error file, named |
1130 |
by the root of the current rad input file followed by the ".err" |
1131 |
suffix. |
1132 |
This file will contain the command lines executed by rad so far, |
1133 |
and may or may not contain additional progress reports from |
1134 |
rpict, depending on the initial setting of the "REPORT" variable. |
1135 |
1136 |
If no error file exists, this button will be disabled. |
1137 |
1138 |
.Action.Script |
1139 |
1140 |
The dry run "Script" button runs rad with the |
1141 |
"-n" option so that you may see the commands that would be |
1142 |
executed during a batch run without actually executing them. |
1143 |
If a file is named in the window next to this button, the output |
1144 |
will simply be written to that file. |
1145 |
If no file is named, a temporary file is created and an editor |
1146 |
window is opened on it. |
1147 |
1148 |
Producing a dry run also writes the "Optfile" if one is specified |
1149 |
1150 |
1151 |
or rpiece(1). |
1152 |
1153 |
The view or views are selected by the same menu used for |
1154 |
batch rendering. |
1155 |
(See the "View" topic under the current help category for more |
1156 |
information.) |
1157 |
1158 |
.Action.Edit |
1159 |
1160 |
The dry run "Edit" button is used to edit the named script file |
1161 |
created by pressing the "Script" button. |
1162 |
If no file is named, this button is ineffective. |
1163 |
1164 |
.Action.Delete |
1165 |
1166 |
The "Delete" button removes the named script file, created by the |
1167 |
"Script" button. |
1168 |
If no file is named, or the named file does not exist, this button has |
1169 |
no effect. |
1170 |
1171 |
.Results.Intro |
1172 |
1173 |
This button selects the trad Results screen. |
1174 |
This screen permits rendered pictures to be displayed, |
1175 |
converted to other image formats, and printed. |
1176 |
Only finished pictures may be converted or printed, but |
1177 |
incomplete pictures (i.e. aborted renderings or renderings in |
1178 |
progress) may be displayed interactively. |
1179 |
1180 |
The left-hand window shows a list of completed views, and the |
1181 |
right-hand window shows views that have been started but not |
1182 |
finished. |
1183 |
Note that other views may not even be started, thus may not |
1184 |
appear in either list. |
1185 |
Also, just because a view appears on the Results screen, it does |
1186 |
not mean that view is up-to-date with respect to the Radiance |
1187 |
input files. |
1188 |
(The best way currently to tell which pictures are out-of-date |
1189 |
is to press the "Script" button on the Action screen and examine |
1190 |
the output.) |
1191 |
1192 |
.Results.Finished |
1193 |
1194 |
The "Finished views" list box on the Results screen shows those |
1195 |
renderings which have completed, whether or not they are up-to-date |
1196 |
with respect to the Radiance input files. |
1197 |
Select pictures in this box for display, conversion to other image |
1198 |
formats, and/or printing. |
1199 |
Selected pictures may also be deleted with the "Delete" button. |
1200 |
1201 |
To select one or more pictures from this box, click the left mouse |
1202 |
button on a view name, and drag it up or down to select multiple |
1203 |
views. |
1204 |
Shift-click also allows views to be added to the selection. |
1205 |
1206 |
.Results.Unfinished |
1207 |
1208 |
The "Unfinished views" list box on the Results screen shows those |
1209 |
renderings which have not yet completed. |
1210 |
These partial pictures may or may not be out-of-date |
1211 |
1212 |
Select pictures in this box for display or deletion. |
1213 |
It is not possible to convert or print an unfinished picture. |
1214 |
1215 |
1216 |
1217 |
views. |
1218 |
1219 |
1220 |
.Results.Rescan |
1221 |
1222 |
The "Rescan" button on the Results screen is used to update the |
1223 |
finished and unfinished view lists, in case one or more pictures |
1224 |
has completed since the Results screen was brought up. |
1225 |
1226 |
.Results.Delete |
1227 |
1228 |
The "Delete" button on the Results screen is used to remove the |
1229 |
selected picture files from the filesystem. |
1230 |
Verification is required before any action is taken. |
1231 |
1232 |
.Results.Display |
1233 |
1234 |
The "Display" button on the Results screen may be used to display |
1235 |
the selected images using ximage(1) or any other Radiance picture |
1236 |
display program. |
1237 |
1238 |
The current display command is shown in the adjacent command window, |
1239 |
and may be customized if necessary. |
1240 |
(See the "DispCommand" topic in the current help category for |
1241 |
details.) |
1242 |
1243 |
.Results.DispCommand |
1244 |
1245 |
The current display command in the Results screen determines how |
1246 |
finished and unfinished Radiance pictures will be displayed. |
1247 |
This command contains two variable fields. |
1248 |
The first field is a signed integer, indicated by the "%+d" format. |
1249 |
The second field is a string, indicated by the "%s" format. |
1250 |
Both fields must appear in any display command used, and must be in |
1251 |
this order on the command line. |
1252 |
The first field is used to adjust the exposure of an unfinished |
1253 |
picture, and the second field is the file name. |
1254 |
The rest of the command is arbitrary, so long as it is understood by |
1255 |
the system. |
1256 |
1257 |
The default command is "ximage -e %+d %s >& /dev/null &", which |
1258 |
executes ximage in the background and sends any output (including |
1259 |
error messages) to the null device. |
1260 |
If you don't wish ximage to run in the background, you may remove |
1261 |
the last part of the command (" >& /dev/null &"). |
1262 |
1263 |
.Results.Convert |
1264 |
1265 |
The "Convert" button on the Results screen converts the selected |
1266 |
pictures to the format indicated on the menu button to the right. |
1267 |
(See the "ConvType" topic under the current help category for |
1268 |
details.) |
1269 |
1270 |
Each finished picture is converted to the selected format and given |
1271 |
the name indicated by the adjacent window labeled "File". |
1272 |
(See the "ConvFile" topic under the current help category for |
1273 |
details.) |
1274 |
1275 |
.Results.ConvType |
1276 |
1277 |
The image type button on the Results screen determines the |
1278 |
destination format for converted Radiance pictures. |
1279 |
You may choose from the list that pops up when you press this |
1280 |
button. |
1281 |
Often, a given format may have more than one subtype. |
1282 |
In general, 8-bit means 8-bit color with a lookup table, |
1283 |
B&W means 8-bit greyscale with no lookup, and 24-bit means 24-bit |
1284 |
true color. |
1285 |
1286 |
The file suffix is determined by the basic conversion type, but may |
1287 |
be changed along with the rest of the name by editing the file name |
1288 |
window. |
1289 |
1290 |
details.) |
1291 |
1292 |
.Results.ConvFile |
1293 |
1294 |
The image conversion file name window on the Results screen should contain |
1295 |
a single "%s" format field, which will be replaced by the view name |
1296 |
being converted. |
1297 |
1298 |
The default name is the same as the value of the rad "PICTURE" |
1299 |
variable, followed by a suffix appropriate to the selected file type. |
1300 |
1301 |
.Results.Print |
1302 |
1303 |
The "Print" button on the Results screen executes the given |
1304 |
system command to print one copy each of the selected picture(s). |
1305 |
This button does not work on unfinished pictures. |
1306 |
1307 |
The actual command used for printing may be edited in the adjacent |
1308 |
window. |
1309 |
(See the "PrintCommand" topic under the current help category for |
1310 |
details.) |
1311 |
1312 |
.Results.PrintCommand |
1313 |
1314 |
The print command window on the Results screen contains the system |
1315 |
command to use in printing out finished Radiance pictures. |
1316 |
The "%s" format field, which must appear somewhere in the command, |
1317 |
is replaced by the selected Radiance picture file name(s). |
1318 |
1319 |
The default command is "ra_ps %s | lpr", which converts the Radiance |
1320 |
picture to a black and white PostScript file and sends it to the lpr |
1321 |
print spooler. |
1322 |
If your printer does not understand PostScript, or your system does |
1323 |
not support lpr, this command must obviously be changed. |
