--- ray/src/util/trad.hlp 1995/08/28 10:12:35 2.13 +++ ray/src/util/trad.hlp 2015/06/25 18:53:39 2.26 @@ -1,4 +1,4 @@ - $Id: trad.hlp,v 2.13 1995/08/28 10:12:35 greg Exp $ + trad.hlp 2.18 10/20/98 This help file is associated with the trad interface to the Radiance rad(1) program. Trad consists of trad.wsh and one do_*.tcl file for @@ -398,11 +398,26 @@ long as the overall size of the given box is close to size of the space. The Zone entry windows may be manipulated in the following ways. -Control-U clears the current window. Control-V pastes the contents of the current selection at the insertion point. Return moves the focus to the next window in the chain. +The "Auto" button may be used to set these values based on the bounding +box of one or more Radiance scene files. + +.Zone.Auto + +Use this button to automatically determine the bounding box for this +zone, based on the output of the "getbbox" command run on one or +more Radiance scene files. +The appropriate scene files are entered via a file +selection dialogue box, which comes up after the button is pressed. + +The reason for selecting specific files rather than running getbbox +on the entire scene is that a zone usually does not include large +external objects, which may be present in the complete scene +description. + .Zone.Detail The "Detail" setting indicates the relative level @@ -472,7 +487,7 @@ an important parameter for rendering accuracy. There are two basic ways to compute the exposure value. The first is by trial and error, where the value is adjusted up and -down within rview using the "e = value" command. +down within rvu using the "e = value" command. Though it sounds flaky, this is the most reliable way to set the exposure (and ambient level) in general lighting situations. @@ -490,7 +505,7 @@ tot_flux is given in watts. (Divide total lumens by 179 lumens/watt to get watts.) The exposure value may either be given as a positive real value, or -as a real value preceeded by a '+' or '-' indicating a positive or +as a real value preceded by a '+' or '-' indicating a positive or negative number of f-stops (powers of two) from the original value. If no exposure is given, pfilt will automatically compute the @@ -530,7 +545,7 @@ and/or parameters, and press the "Change" button. To remove an unwanted view, select it and press the "Delete" button. To undo this action, simply press the "Add" button again. -The first view in the list is the default given to rview during +The first view in the list is the default given to rvu during interactive rendering, and is the first view rendered in a batch run. To change the default view, select the newly desired view and press the "Set Default" button. @@ -569,17 +584,17 @@ An invented name should be kept as short as possible, added to the picture file name along with the standard ".pic" suffix. The standard views are specified by strings of the form -"[Xx]?[Yy]?[Zz]?[vlahc]?". +"[Xx]?[Yy]?[Zz]?[vlahsc]?". (That is, an optional upper or lower case X followed by an optional upper or lower case Y followed by an optional upper or lower case Z -followed by an optional lower case V, L, A, H or C.) +followed by an optional lower case view type.) The letters indicate the desired view position, where upper case "X" means maximum X, lower case "y" means minimum Y and so on. The final letter is the view type, where 'v' is perspective (the default), 'l' is parallel, 'a' is angular fisheye, 'h' is -hemispherical fisheye and 'c' is for cylindrical panorama. -A perspective view from maximum X, minimum Y would be "Xy" or -"Xyv". +hemispherical fisheye, 's' is for planisphere (stereographic) fisheye, +and 'c' is for cylindrical panorama. +A perspective view from maximum X, minimum Y would be "Xy" or "Xyv". A parallel view from maximum Z would be "Zl". If "ZONE" is an interior zone, the standard views will be inside the perimeter. @@ -599,7 +614,7 @@ Otherwise, it is usually necessary to specify a set of define a view. The simplest view specification is of the form "-vf viewfile", where -"viewfile" is a file created with the rview "view" command, or a +"viewfile" is a file created with the rvu "view" command, or a Radiance picture. This method of naming views, although convenient, is not the best since it is difficult to know exactly where such a view is by @@ -618,7 +633,7 @@ interaction mode for trad. Consult the rpict(1) manual page for a full description of the various view options, all of which begin with "-v". Just briefly, the "-vt?" option sets the view type, where "?" is -replaced by one of the letters "v, l, a, h or c", corresponding to +replaced by one of the letters "v, l, a, h, s or c", corresponding to perspective, parallel, angular fisheye, hemispherical fisheye and cylindrical panorama, respectively. The "-vp x y z" option sets the view position (eyepoint), where "x y z" @@ -682,15 +697,12 @@ The "Clear" button simply clears the "Name" and "Optio for the convenience of entering a new view. It has no effect on the rad input variables. -Note that Control-U will always clear an entry box whose cursor is -active. - .Views.Default The "Set Default" button may be used to make the selected view the default view for rendering. This simply moves the view to the top of the list in the rad input file. -The default view will be the one normally rendered by rview when rad +The default view will be the one normally rendered by rvu when rad is started interactively, and is the first view rendered in a batch process. @@ -707,10 +719,19 @@ The standard view up vector may be set to the positive the positive Y axis (+Y), the positive Z axis (+Z), the negative X axis (-X), the negative Y axis (-Y), or the negative Z axis (-Z). -This setting may always be overriden by the "-vu xd yd zd" option, +This setting may always be overridden by the "-vu xd yd zd" option, and will be altered for a particular view if it happens to be parallel to the view direction. +.Views.Eyesep + +The eye separation is used for generating stereo views of +the scene. +It is the measured distance between a viewer's pupils in world +coordinate units. +It is not used directly by rad, but should be set for other programs +that need it, such as rholo and glrad. + .Views.Picture The root picture file name is given in the "Picture" entry window. @@ -817,7 +838,7 @@ The "Report" variable may be used to specify a time in minutes) between progress reports. Other windows allow the user to customize the options to oconv(1), -mkillum(1), rview(1) and rpict(1), and pfilt(1). +mkillum(1), rvu(1) and rpict(1), and pfilt(1). .Options.Quality @@ -862,6 +883,47 @@ will be treated as points. It only means that some accuracy and possibly some smoothness will be traded for speed in the shadow calculations. +.Options.Pgmap + +The "Pgmap" specifies the file to hold the global photons computed +by the "mkpmap" command, followed by the number of photons to generate +(required). +A typical photon count for a global map is on the order of 100-200K. +(A 'K', 'M', or 'G' may follow the value to indicate thousands, millions, +or billions of photons.) +By convention, photon map files are given a ".pmp" suffix. +An optional third parameter specifies the bandwidth to use +for the global photons during rendering, and this value should be +around 50. + +.Options.PgmDelete + +The "Delete" button next to the "Pgmap" window on the Options +screen allows you to remove the named global photon map file. +This is usually done when a change is made to the "mkpmap" options, +as the file will be regenerated automatically after most scene changes. + +.Options.Pcmap + +The "Pcmap" specifies the file to hold the caustic photons computed +by the "mkpmap" command, followed by the number of photons to generate +(required). +A typical photon count for a global map is on the order of 1000K (1M). +(A 'K', 'M', or 'G' may follow the value to indicate thousands, millions, +or billions of photons.) +By convention, photon map files are given a ".pmp" suffix. +An optional third parameter specifies the bandwidth to use +for the global photons during rendering, and this value should be +around 50. +(See the "Pgmap" topic under the current help category.) + +.Options.PcmDelete + +The "Delete" button next to the "Pcmap" window on the Options +screen allows you to remove the named caustic photon map file. +This is usually done when a change is made to the "mkpmap" options, +as the file will be regenerated automatically after most scene changes. + .Options.Ambfile The "Ambfile" is the file used to store Radiance ambient values for @@ -895,7 +957,7 @@ effort. The "Optfile" setting assigns a file to hold rendering options, which may be a convenience when these options are reused for -rtrace(1) or rpiece(1), or manual invocations of rview or rpict. +rtrace(1) or rpiece(1), or manual invocations of rvu or rpict. Using an options file also reduces the size of the command line, making it a little easier on the eye. @@ -946,17 +1008,24 @@ indicate this by not specifying any illum or scene fil .Options.Mkillum The "mkillum opts" window may be used to specify options to the -mkillum(1) command, whose options are actually passed to rtrace(1). +mkillum(1) command. These options apply only if there are one or more "Illum" files named on the Scene screen. It is very important to set mkillum options sensibly, since rad does not have the intelligence to do it for you. +.Options.Mkpmap + +The "mkpmap opts" window may be used to specify options +to the mkpmap(1) command. +There are no default values, and rad does not set these +options intelligently. + .Options.Render The "render opts" window is used to specify additional options to -the rview(1) and rpict(1) rendering programs. +the rvu(1) and rpict(1) rendering programs. Most of the important parameters are computed by rad, so this window is usually used to override specific parameters or to give additional information, such as which materials to exclude from the @@ -1005,7 +1074,7 @@ This screen is where the actual Radiance programs are run, usually via rad(1). The top row of buttons is used to update the octree following a change to one or more input files. -The "rview" button starts an interactive rendering in the +The "rvu" button starts an interactive rendering in the foreground. The next set of buttons provides for the control of a batch rendering process, taking place in the background. @@ -1083,12 +1152,12 @@ by the "Touch" button. (This will still cause the ambient file to be removed, unfortunately.) -.Action.Rview +.Action.Rvu -The "rview" button on the Action screen starts an interactive +The "rvu" button on the Action screen starts an interactive rendering for the selected view, indicated by the menu button just to the right. -Other views may be accessed within rview using the "L name" +Other views may be accessed within rvu using the "L name" command, and new views can be added with the "V name" command. @@ -1098,7 +1167,7 @@ Instead, give it a new name (or no name, which will sh a number later), then use the Views screen to override the previous view definition with the new one. (See the "View" topic in the current -help category, the "Change" topic under "Views" and the rview(1) +help category, the "Change" topic under "Views" and the rvu(1) manual page for more information.) If the octree is out-of-date, it will be rebuilt before rendering @@ -1107,14 +1176,14 @@ begins. .Action.View The Action screen contains two menus for selecting views. -The top menu, next to the "rview" button, sets the view to start -with in rview, and is selected from the current view list. +The top menu, next to the "rvu" button, sets the view to start +with in rvu, and is selected from the current view list. The second view menu, next to the "Start" button for batch rendering, selects the view or views to render in batch mode. If the special entry "ALL" is selected, then every view in the current list will be rendered if it hasn't been already. -The view menu next to the "rview" button will be disabled if there +The view menu next to the "rvu" button will be disabled if there is only one view to choose from. The view menu next to the "Start" button will be disabled if there is a batch job in progress, and thus the view cannot be changed. @@ -1122,6 +1191,24 @@ is a batch job in progress, and thus the view cannot b The batch rendering view menu also selects the view or views to use in producing a script during a dry run. +.Action.Processes + +The "Number of processes" slider controls how many independent +processes are initiated by the "rvu" and "Start" buttons above +and below. +This should be set no greater than the number of virtual cores +on your system. + +For interactive rendering, the "new" command within rvu may +be used to change the number of processes running. + +For rendering in the background, the number of processes will +never be greater than the number of views if all views are +being rendered. +If only a single view is selected for rendering, rad +will call rpiece to render it in tiles using the given +number of processes. + .Action.Start The "Start" button for batch rendering on the Action screen @@ -1270,6 +1357,8 @@ has completed since the Results screen was brought up. The "Delete" button on the Results screen is used to remove the selected picture files from the filesystem. +Associated raw picture and z-buffer files +will also be deleted if they exist. Verification is required before any action is taken. .Results.Display @@ -1357,10 +1446,13 @@ details.) The print command window on the Results screen contains the system command to use in printing out finished Radiance pictures. The "%s" format field, which must appear somewhere in the command, -is replaced by the selected Radiance picture file name(s). +is replaced by the selected Radiance picture file name. +This command is executed multiple times if multiple files are +selected. The default command is "ra_ps %s | lpr", which converts the Radiance picture to a black and white PostScript file and sends it to the lpr print spooler. +Add a "-c" option to "ra_ps" if the printer supports color. If your printer does not understand PostScript, or your system does not support lpr, this command must obviously be changed.
