root/radiance/ray/src/util/trad.hlp
Thu Jan 1 19:31:46 2004 UTC (20 years, 5 months ago) by greg
Changes since 2.19: +15 -15 lines
Diff to previous 2.19 , to selected 2.11
Tue Oct 20 11:52:15 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 2.17: +9 -0 lines
added EYESEP variable
Fri May 17 14:59:20 1996 UTC (28 years ago) by greg
Changes since 2.16: +16 -4 lines
added "Auto" button to compute bounding box using getbbox
Thu Oct 5 13:03:04 1995 UTC (28 years, 8 months ago) by greg
minor spelling corrections
Thu Sep 28 14:11:45 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.14: +4 -1 lines
added color PostScript output
Wed Sep 13 13:15:29 1995 UTC (28 years, 9 months ago) by greg
Changes since 2.13: +2 -0 lines
made changes appropriate for addition of RAWFILE and ZFILE to rad
Mon Aug 28 10:12:35 1995 UTC (28 years, 9 months ago) by greg
Changes since 2.12: +31 -7 lines
added ZFILE variable to rad
Fri Aug 18 10:34:56 1995 UTC (28 years, 9 months ago) by greg
Changes since 2.11: +7 -6 lines
added cylindrical view type
Thu Jul 6 12:23:37 1995 UTC (28 years, 11 months ago) by greg
Changes since 2.10: +11 -0 lines
Tue Feb 21 14:27:06 1995 UTC (29 years, 3 months ago) by greg
clarified wording under rview button
Tue Jan 3 16:11:28 1995 UTC (29 years, 5 months ago) by greg
minor reference correction
Tue Dec 6 13:00:26 1994 UTC (29 years, 6 months ago) by greg
Changes since 2.7: +9 -3 lines
added host name tracking to batch rendering processes
Mon Dec 5 10:19:25 1994 UTC (29 years, 6 months ago) by greg
Changes since 2.6: +5 -0 lines
minor wording addtion to .Action.View entry
Fri Dec 2 14:02:12 1994 UTC (29 years, 6 months ago) by greg
documented problem with redefining views in rview
Sun Nov 6 09:39:09 1994 UTC (29 years, 7 months ago) by greg
Changes since 2.4: +2 -6 lines
removed small statement about slow help restart
Sat Nov 5 09:31:49 1994 UTC (29 years, 7 months ago) by greg
modified <Return> action in view options window
Tue Nov 1 14:38:31 1994 UTC (29 years, 7 months ago) by greg
Changes since 2.2: +66 -66 lines
eliminated spaces accidentally put at the ends of some lines
Fri Oct 28 11:09:52 1994 UTC (29 years, 7 months ago) by greg
Changes since 2.1: +1 -3 lines
correction about loading bad RIF
Thu Oct 27 15:56:04 1994 UTC (29 years, 7 months ago) by greg
Diff to selected 2.11
