root/radiance/ray/src/util/t16anim.c
Revision: 1.4
Committed: Fri Nov 5 03:31:39 2004 UTC (19 years, 5 months ago) by greg
State: FILE REMOVED
Error occurred while calculating annotation data.
2 static const char RCSid[] = "$Id: t16anim.c,v 1.3 2003/10/27 10:32:06 schorsch Exp $";
5 * Send Targa 16-bit files to PC animation system.
6 *
7 * 6/20/88
8 */
9
10 #include <stdio.h>
11
12 #include "rtprocess.h"
13 #include "client/clnt.h"
14 #include "targa.h"
15
16 #define goodpic(h) (((h)->dataType==IM_RGB || (h)->dataType==IM_CRGB) \
17 && (h)->dataBits==16)
18
19
20 char *pcom = NULL; /* uncompress command */
21
22
23 main(argc, argv)
24 int argc;
25 char **argv;
26 {
27 int startrec = 0;
28 char *progname;
29 int prognum = PCPROGRAM;
30 /* initialize */
31 for (progname = *argv++; --argc; argv++)
32 if (!strcmp(*argv, "-p") && argv[1]) {
33 prognum = atoi(*++argv); argc--;
34 } else if (!strcmp(*argv, "-u") && argv[1]) {
35 pcom = *++argv; argc--;
36 } else if (!strcmp(*argv, "-r") && argv[1]) {
37 startrec = atoi(*++argv); argc--;
38 } else
39 break;
40 if (!argc) {
41 fputs("Usage: ", stderr);
42 fputs(progname, stderr);
43 fputs(" [-p prognum] [-u uncompress] [-r record] hostname [frame..]\n",
44 stderr);
45 exit(1);
46 }
47 scry_open(*argv++, prognum); argc--;
48 scry_get_info(2) ;
49 scry_set_compress(NONE);
50 if (startrec > 0)
51 scry_init_record(startrec, argc>0?argc:1);
52 else
53 scry_init_record(PREVIEW,0);
54 /* send frames */
55 if (argc <= 0)
56 sendframe(NULL);
57 else
58 for ( ; argc > 0; argc--, argv++)
59 sendframe(*argv);
60 /* clean up */
61 scry_close();
62 exit(0);
63 }
64
65
66 sendframe(file) /* convert and send a frame */
67 char *file;
68 {
69 static struct hdStruct head;
70 char command[128];
71 register FILE *fp;
72 register int i, j;
73 register int c;
74 /* DAVIDR */
75 unsigned char *image_read,*newimage,*compdata ;
76 int new_ht, new_wd, new_depth ;
77 /* end DAVIDR */
78 /* open file */
79 if (file == NULL) {
80 if (pcom != NULL)
81 fp = popen(pcom, "r");
82 else
83 fp = stdin;
84 file = "<stdin>";
85 } else {
86 if (pcom != NULL) {
87 sprintf(command, "( %s ) < %s", pcom, file);
88 fp = popen(command, "r");
89 } else
90 fp = fopen(file, "r");
91 }
92 if (fp == NULL) {
93 perror(file);
94 exit(1);
95 }
96 /* check format */
97 if (getthead(&head, NULL, fp) == -1 || !goodpic(&head))
98 goto badfmt;
99 /* DAVIDR */
100 image_read = (unsigned char *) malloc((head.dataBits)/8 * head.x * head.y) ;
101 /* get frame */
102 for (i = 0 ; i < head.y ; i++)
103 fread(&(image_read[(head.y-i-1)*head.x*(head.dataBits/8)]),(head.dataBits)/8,head.x,fp) ;
104 newimage = NULL ;
105 /* convert to server size and visual */
106 scry_conv_vis (image_read,&newimage,head.y,head.x,&new_ht,&new_wd,(head.dataBits)/8,&new_depth) ;
107 free (image_read) ;
108 compdata = NULL ;
109 /* compress if necessary */
110 scry_compress(newimage,&compdata,new_ht,new_wd,new_depth) ;
111 /* send frame */
112 scry_send_frame(compdata);
113 free(newimage) ;
114 free(compdata) ;
115 /* end DAVIDR */
116 /* close file */
117 if (pcom != NULL)
118 pclose(fp);
119 else
120 fclose(fp);
121 return;
122 badfmt:
123 fputs(file, stderr);
124 fputs(": wrong targa format\n", stderr);
125 exit(1);
126 readerr:
127 fputs(file, stderr);
128 fputs(": read error\n", stderr);
129 exit(1);
130 }
131
132
133 getthead(hp, ip, fp) /* read header from input */
134 struct hdStruct *hp;
135 char *ip;
136 register FILE *fp;
137 {
138 int nidbytes;
139
140 if ((nidbytes = getc(fp)) == EOF)
141 return(-1);
142 hp->mapType = getc(fp);
143 hp->dataType = getc(fp);
144 hp->mapOrig = getint2(fp);
145 hp->mapLength = getint2(fp);
146 hp->CMapBits = getc(fp);
147 hp->XOffset = getint2(fp);
148 hp->YOffset = getint2(fp);
149 hp->x = getint2(fp);
150 hp->y = getint2(fp);
151 hp->dataBits = getc(fp);
152 hp->imType = getc(fp);
153
154 if (ip != NULL)
155 if (nidbytes)
156 fread(ip, nidbytes, 1, fp);
157 else
158 *ip = '\0';
159 else if (nidbytes)
160 fseek(fp, (long)nidbytes, 1);
161
162 return(feof(fp) || ferror(fp) ? -1 : 0);
163 }
164
165
166
167
168 int
169 getint2(fp) /* get a 2-byte positive integer */
170 register FILE *fp;
171 {
172 register int b1, b2;
173
174 if ((b1 = getc(fp)) == EOF || (b2 = getc(fp)) == EOF) {
175 fputs("Unexpected EOF\n", stderr);
176 exit(1);
177 }
178 return(b1 | b2<<8);
179 }
180
181
