root/radiance/ray/src/util/t16anim.c
Revision: 1.4
Committed: Fri Nov 5 03:31:39 2004 UTC (20 years, 6 months ago) by greg
State: FILE REMOVED
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 1.4 static const char RCSid[] = "$Id: t16anim.c,v 1.3 2003/10/27 10:32:06 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * Send Targa 16-bit files to PC animation system.
6     *
7     * 6/20/88
8     */
9
10     #include <stdio.h>
11
12 schorsch 1.3 #include "rtprocess.h"
13 greg 1.1 #include "client/clnt.h"
14     #include "targa.h"
15
16     #define goodpic(h) (((h)->dataType==IM_RGB || (h)->dataType==IM_CRGB) \
17     && (h)->dataBits==16)
18
19
20     char *pcom = NULL; /* uncompress command */
21
22
23     main(argc, argv)
24     int argc;
25     char **argv;
26     {
27     int startrec = 0;
28     char *progname;
29     int prognum = PCPROGRAM;
30     /* initialize */
31     for (progname = *argv++; --argc; argv++)
32     if (!strcmp(*argv, "-p") && argv[1]) {
33     prognum = atoi(*++argv); argc--;
34     } else if (!strcmp(*argv, "-u") && argv[1]) {
35     pcom = *++argv; argc--;
36     } else if (!strcmp(*argv, "-r") && argv[1]) {
37     startrec = atoi(*++argv); argc--;
38     } else
39     break;
40     if (!argc) {
41     fputs("Usage: ", stderr);
42     fputs(progname, stderr);
43     fputs(" [-p prognum] [-u uncompress] [-r record] hostname [frame..]\n",
44     stderr);
45     exit(1);
46     }
47     scry_open(*argv++, prognum); argc--;
48     scry_get_info(2) ;
49     scry_set_compress(NONE);
50     if (startrec > 0)
51     scry_init_record(startrec, argc>0?argc:1);
52     else
53     scry_init_record(PREVIEW,0);
54     /* send frames */
55     if (argc <= 0)
56     sendframe(NULL);
57     else
58     for ( ; argc > 0; argc--, argv++)
59     sendframe(*argv);
60     /* clean up */
61     scry_close();
62     exit(0);
63     }
64
65
66     sendframe(file) /* convert and send a frame */
67     char *file;
68     {
69     static struct hdStruct head;
70     char command[128];
71     register FILE *fp;
72     register int i, j;
73     register int c;
74     /* DAVIDR */
75     unsigned char *image_read,*newimage,*compdata ;
76     int new_ht, new_wd, new_depth ;
77     /* end DAVIDR */
78     /* open file */
79     if (file == NULL) {
80     if (pcom != NULL)
81     fp = popen(pcom, "r");
82     else
83     fp = stdin;
84     file = "<stdin>";
85     } else {
86     if (pcom != NULL) {
87     sprintf(command, "( %s ) < %s", pcom, file);
88     fp = popen(command, "r");
89     } else
90     fp = fopen(file, "r");
91     }
92     if (fp == NULL) {
93     perror(file);
94     exit(1);
95     }
96     /* check format */
97     if (getthead(&head, NULL, fp) == -1 || !goodpic(&head))
98     goto badfmt;
99     /* DAVIDR */
100     image_read = (unsigned char *) malloc((head.dataBits)/8 * head.x * head.y) ;
101     /* get frame */
102     for (i = 0 ; i < head.y ; i++)
103     fread(&(image_read[(head.y-i-1)*head.x*(head.dataBits/8)]),(head.dataBits)/8,head.x,fp) ;
104     newimage = NULL ;
105     /* convert to server size and visual */
106     scry_conv_vis (image_read,&newimage,head.y,head.x,&new_ht,&new_wd,(head.dataBits)/8,&new_depth) ;
107     free (image_read) ;
108     compdata = NULL ;
109     /* compress if necessary */
110     scry_compress(newimage,&compdata,new_ht,new_wd,new_depth) ;
111     /* send frame */
112     scry_send_frame(compdata);
113     free(newimage) ;
114     free(compdata) ;
115     /* end DAVIDR */
116     /* close file */
117     if (pcom != NULL)
118     pclose(fp);
119     else
120     fclose(fp);
121     return;
122     badfmt:
123     fputs(file, stderr);
124     fputs(": wrong targa format\n", stderr);
125     exit(1);
126     readerr:
127     fputs(file, stderr);
128     fputs(": read error\n", stderr);
129     exit(1);
130     }
131
132
133     getthead(hp, ip, fp) /* read header from input */
134     struct hdStruct *hp;
135     char *ip;
136     register FILE *fp;
137     {
138     int nidbytes;
139
140     if ((nidbytes = getc(fp)) == EOF)
141     return(-1);
142     hp->mapType = getc(fp);
143     hp->dataType = getc(fp);
144     hp->mapOrig = getint2(fp);
145     hp->mapLength = getint2(fp);
146     hp->CMapBits = getc(fp);
147     hp->XOffset = getint2(fp);
148     hp->YOffset = getint2(fp);
149     hp->x = getint2(fp);
150     hp->y = getint2(fp);
151     hp->dataBits = getc(fp);
152     hp->imType = getc(fp);
153
154     if (ip != NULL)
155     if (nidbytes)
156     fread(ip, nidbytes, 1, fp);
157     else
158     *ip = '\0';
159     else if (nidbytes)
160     fseek(fp, (long)nidbytes, 1);
161
162     return(feof(fp) || ferror(fp) ? -1 : 0);
163     }
164
165
166
167
168     int
169     getint2(fp) /* get a 2-byte positive integer */
170     register FILE *fp;
171     {
172     register int b1, b2;
173
174     if ((b1 = getc(fp)) == EOF || (b2 = getc(fp)) == EOF) {
175     fputs("Unexpected EOF\n", stderr);
176     exit(1);
177     }
178     return(b1 | b2<<8);
179     }
180
181
