root/radiance/ray/src/util/setscan.c
Fri Mar 26 23:34:23 2004 UTC (20 years, 2 months ago) by schorsch
CVS Tags: HEAD, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Continued ANSIfication.
Fri Jun 27 11:32:12 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.2: +6 -5 lines
Changes since 2.1: +1 -4 lines
Diff to previous 2.1
Tue Nov 12 17:19:09 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.3
Thu Mar 14 17:38:27 1991 UTC (33 years, 2 months ago) by greg
Changes since 1.2: +8 -4 lines
Diff to previous 1.2
set setscan.h into its own file
Wed Mar 13 16:23:49 1991 UTC (33 years, 2 months ago) by greg
Diff to previous 1.1
got rid of negative angles
Tue Mar 12 13:07:40 1991 UTC (33 years, 2 months ago) by greg
