1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: scanner.c,v 1.5 2004/03/26 23:34:23 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* scanner.c - program to simulate bi-directional scanner. |
6 |
7 |
* 6/10/86 |
8 |
9 |
10 |
#include <stdio.h> |
11 |
#include <string.h> |
12 |
#include <stdlib.h> |
13 |
#include <ctype.h> |
14 |
#include <signal.h> |
15 |
#include <math.h> |
16 |
#include <unistd.h> /* XXX pipe() fork() etc, use common/process.c instead */ |
17 |
18 |
#include "random.h" |
19 |
20 |
21 |
#define PI 3.14159265358979324 |
22 |
23 |
#define ANGLE short |
24 |
#define AEND -1 |
25 |
26 |
#define atorad(a) ((PI/180.0) * (a)) |
27 |
28 |
char otcom[128] = "oconv"; |
29 |
char rtcom[256] = "rtrace -bf -ar .25 -ad 128"; |
30 |
31 |
char *sourcetemp, /* temp files */ |
32 |
*octreetemp; |
33 |
34 |
ANGLE alpha[181] = {90, AEND}; |
35 |
ANGLE beta[181] = {30, 60, 90, 120, 150, AEND}; |
36 |
ANGLE sgamma[181] = {45, AEND}; /* gamma() is a function from gnu <math.h> */ |
37 |
38 |
char *target; /* target file name */ |
39 |
double targetw = 3.0; /* target width (inches) */ |
40 |
double targeth = 3.0; /* target height (inches) */ |
41 |
int xres = 16; /* x sample resolution */ |
42 |
int yres = 16; /* y sample resolution */ |
43 |
44 |
static void quit(int code); |
45 |
static void setscan(ANGLE *ang, char *arg); |
46 |
static void doscan(void); |
47 |
static void scanend(FILE *fp); |
48 |
static void makesource(ANGLE g); |
49 |
static void sendsamples(FILE *fp); |
50 |
static void writesample(FILE *fp, ANGLE a, ANGLE b); |
51 |
static FILE * scanstart(ANGLE g); |
52 |
static double readsample(FILE *fp); |
53 |
54 |
int |
55 |
main( |
56 |
int argc, |
57 |
char *argv[] |
58 |
59 |
60 |
int i; |
61 |
62 |
#ifdef SIGHUP |
63 |
signal(SIGHUP, quit); |
64 |
#endif |
65 |
signal(SIGINT, quit); |
66 |
signal(SIGTERM, quit); |
67 |
#ifdef SIGXCPU |
68 |
signal(SIGXCPU, SIG_IGN); |
69 |
signal(SIGXFSZ, SIG_IGN); |
70 |
#endif |
71 |
72 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
73 |
switch (argv[i][1]) { |
74 |
case 't': /* target */ |
75 |
switch (argv[i][2]) { |
76 |
case 'w': /* width */ |
77 |
targetw = atof(argv[++i]); |
78 |
break; |
79 |
case 'h': /* height */ |
80 |
targeth = atof(argv[++i]); |
81 |
break; |
82 |
default: |
83 |
goto badopt; |
84 |
85 |
break; |
86 |
case 'a': |
87 |
if (!strcmp(argv[i], "-alpha")) |
88 |
setscan(alpha, argv[++i]); |
89 |
else |
90 |
91 |
case 'd': /* ambient divisions */ |
92 |
strcat(rtcom, " -ad "); |
93 |
strcat(rtcom, argv[++i]); |
94 |
break; |
95 |
case 'r': /* ambient radius */ |
96 |
strcat(rtcom, " -ar "); |
97 |
98 |
break; |
99 |
default: |
100 |
goto badopt; |
101 |
102 |
break; |
103 |
case 'b': |
104 |
if (!strcmp(argv[i], "-beta")) |
105 |
setscan(beta, argv[++i]); |
106 |
else |
107 |
goto badopt; |
108 |
break; |
109 |
case 'g': |
110 |
if (!strcmp(argv[i], "-gamma")) |
111 |
setscan(sgamma, argv[++i]); |
112 |
else |
113 |
goto badopt; |
114 |
break; |
115 |
case 'x': /* x resolution */ |
116 |
xres = atoi(argv[++i]); |
117 |
break; |
118 |
case 'y': /* y resolution */ |
119 |
yres = atoi(argv[++i]); |
120 |
break; |
121 |
case 'l': |
122 |
123 |
case 'w': /* limit weight */ |
124 |
strcat(rtcom, " -lw "); |
125 |
126 |
break; |
127 |
case 'r': /* limit recursion */ |
128 |
strcat(rtcom, " -lr "); |
129 |
130 |
break; |
131 |
default: |
132 |
goto badopt; |
133 |
134 |
break; |
135 |
default:; |
136 |
badopt: |
137 |
fprintf(stderr, "%s: bad option: %s\n", |
138 |
argv[0], argv[i]); |
139 |
quit(1); |
140 |
141 |
142 |
if (i >= argc) { |
143 |
fprintf(stderr, "%s: missing target file\n", argv[0]); |
144 |
quit(1); |
145 |
} else if (i < argc-1) { |
146 |
fprintf(stderr, "%s: too many target files\n", argv[0]); |
147 |
quit(1); |
148 |
149 |
150 |
target = argv[i]; |
151 |
sourcetemp = mktemp("/usr/tmp/soXXXXXX"); |
152 |
octreetemp = mktemp("/usr/tmp/ocXXXXXX"); |
153 |
strcat(strcat(otcom, " "), target); |
154 |
strcat(strcat(otcom, " "), sourcetemp); |
155 |
strcat(strcat(otcom, " > "), octreetemp); |
156 |
strcat(strcat(rtcom, " "), octreetemp); |
157 |
158 |
doscan(); |
159 |
160 |
quit(0); |
161 |
return 0; /* pro forma return */ |
162 |
163 |
164 |
165 |
void |
166 |
quit( /* unlink temp files and exit */ |
167 |
int code |
168 |
169 |
170 |
unlink(sourcetemp); |
171 |
unlink(octreetemp); |
172 |
exit(code); |
173 |
174 |
175 |
176 |
static void |
177 |
setscan( /* set up scan according to arg */ |
178 |
register ANGLE *ang, |
179 |
register char *arg |
180 |
181 |
182 |
int start = 0, finish = -1, step = 1; |
183 |
184 |
for ( ; ; ) { |
185 |
switch (*arg) { |
186 |
case '\0': |
187 |
case ',': |
188 |
while (start <= finish) { |
189 |
*ang++ = start; |
190 |
start += step; |
191 |
192 |
if (*arg) { |
193 |
arg++; |
194 |
continue; |
195 |
} else { |
196 |
*ang = AEND; |
197 |
return; |
198 |
199 |
case '0': |
200 |
case '1': |
201 |
case '2': |
202 |
case '3': |
203 |
case '4': |
204 |
case '5': |
205 |
case '6': |
206 |
case '7': |
207 |
case '8': |
208 |
case '9': |
209 |
start = atoi(arg); |
210 |
finish = start; |
211 |
step = 1; |
212 |
break; |
213 |
case '-': |
214 |
finish = atoi(++arg); |
215 |
break; |
216 |
case ':': |
217 |
step = atoi(++arg); |
218 |
break; |
219 |
default: |
220 |
fprintf(stderr, "Scan specification error\n"); |
221 |
quit(1); |
222 |
223 |
while (isdigit(*arg)) |
224 |
arg++; |
225 |
226 |
227 |
228 |
229 |
static void |
230 |
doscan(void) /* do scan for target */ |
231 |
232 |
FILE *fp; |
233 |
ANGLE *a, *b, *g; |
234 |
235 |
printf("Alpha\tBeta\tGamma\tDistribution for \"%s\"\n", target); |
236 |
for (g = sgamma; *g != AEND; g++) { |
237 |
fp = scanstart(*g); |
238 |
for (b = beta; *b != AEND; b++) /* read data */ |
239 |
for (a = alpha; *a != AEND; a++) |
240 |
printf("%d\t%d\t%d\t%f\n", |
241 |
*a, *b, *g, readsample(fp)); |
242 |
scanend(fp); |
243 |
244 |
245 |
246 |
247 |
static FILE * |
248 |
scanstart( /* open scanner pipeline */ |
249 |
ANGLE g |
250 |
251 |
252 |
int p1[2], p2[2]; |
253 |
int pid; |
254 |
FILE *fp; |
255 |
char buf[128]; |
256 |
257 |
makesource(g); /* make source */ |
258 |
if (system(otcom)) /* generate new octree */ |
259 |
goto err; |
260 |
261 |
if (pipe(p1) < 0) /* get pipe1 */ |
262 |
goto err; |
263 |
if ((pid = fork()) == 0) { /* if child1 */ |
264 |
close(p1[0]); |
265 |
if (p1[1] != 1) { /* connect stdout to pipe1 */ |
266 |
dup2(p1[1], 1); |
267 |
close(p1[1]); |
268 |
269 |
if (pipe(p2) < 0) /* get pipe2 */ |
270 |
goto err; |
271 |
if ((pid = fork()) == 0) { /* if child2 */ |
272 |
close(p2[0]); |
273 |
if ((fp = fdopen(p2[1], "w")) == NULL) |
274 |
goto err; |
275 |
sendsamples(fp); /* send our samples to pipe2 */ |
276 |
fclose(fp); |
277 |
_exit(0); |
278 |
279 |
if (pid == -1) |
280 |
goto err; |
281 |
close(p2[1]); |
282 |
283 |
if (p2[0] != 0) { /* for child1 pipe2 to stdin */ |
284 |
dup2(p2[0], 0); |
285 |
close(p2[0]); |
286 |
287 |
execl("/bin/sh", "sh", "-c", rtcom, 0); /* run ray tracer */ |
288 |
goto err; |
289 |
290 |
if (pid == -1) |
291 |
goto err; |
292 |
close(p1[1]); |
293 |
if ((fp = fdopen(p1[0], "r")) == NULL) /* parent reads pipe1 */ |
294 |
goto err; |
295 |
while (fgets(buf, sizeof(buf), fp) != NULL && buf[0] != '\n') |
296 |
/* discard header */; |
297 |
return(fp); |
298 |
err: |
299 |
fprintf(stderr, "System error in scanstart\n"); |
300 |
quit(1); |
301 |
return NULL; /* pro forma return */ |
302 |
303 |
304 |
305 |
static void |
306 |
scanend( /* done with scanner input */ |
307 |
FILE *fp |
308 |
309 |
310 |
fclose(fp); |
311 |
312 |
313 |
314 |
static void |
315 |
makesource( /* make a source (output normalized) */ |
316 |
ANGLE g |
317 |
318 |
319 |
FILE *fp; |
320 |
double srcdir[3]; |
321 |
322 |
srcdir[0] = sin(atorad(g)); |
323 |
srcdir[1] = 0.0; |
324 |
srcdir[2] = -cos(atorad(g)); |
325 |
if ((fp = fopen(sourcetemp, "w")) == NULL) { |
326 |
fprintf(stderr, "%s: cannot create\n", sourcetemp); |
327 |
quit(1); |
328 |
329 |
fprintf(fp, "0 0 0 1\n"); |
330 |
fprintf(fp, "\nvoid light scanner_light\n"); |
331 |
fprintf(fp, "0\n0\n3 3283 3283 3283\n"); |
332 |
fprintf(fp, "\nscanner_light source scanner_source\n"); |
333 |
fprintf(fp, "0\n0\n4 %f %f %f 2\n", srcdir[0], srcdir[1], srcdir[2]); |
334 |
fclose(fp); |
335 |
336 |
337 |
338 |
static void |
339 |
sendsamples( /* send our samples to fp */ |
340 |
FILE *fp |
341 |
342 |
343 |
ANGLE *a, *b; |
344 |
345 |
for (b = beta; *b != AEND; b++) |
346 |
347 |
writesample(fp, *a, *b); |
348 |
349 |
350 |
351 |
static void |
352 |
writesample( /* write out sample ray grid */ |
353 |
FILE *fp, |
354 |
ANGLE a, |
355 |
ANGLE b |
356 |
357 |
358 |
float sp[6]; |
359 |
int i, j; |
360 |
361 |
sp[3] = -sin(atorad(b)-(PI/2.0)) * sin(atorad(a)); |
362 |
sp[4] = -cos(atorad(a)); |
363 |
sp[5] = -sin(atorad(b)) * sin(atorad(a)); |
364 |
365 |
for (j = 0; j < yres; j++) |
366 |
for (i = 0; i < xres; i++) { |
367 |
sp[0] = -100.0*sp[3] + |
368 |
(i - xres/2.0 + frandom())*targetw/xres; |
369 |
sp[1] = -100.0*sp[4] + |
370 |
(j - yres/2.0 + frandom())*targeth/yres; |
371 |
sp[2] = -100.0*sp[5]; |
372 |
fwrite(sp, sizeof(*sp), 6, fp); |
373 |
if (ferror(fp)) { |
374 |
fprintf(stderr, "Data write error\n"); |
375 |
quit(1); |
376 |
377 |
378 |
379 |
380 |
381 |
static double |
382 |
readsample( /* read in sample ray grid */ |
383 |
FILE *fp |
384 |
385 |
386 |
double sum; |
387 |
float col[3]; |
388 |
int i; |
389 |
390 |
sum = 0.0; |
391 |
i = xres*yres; |
392 |
while (i--) { |
393 |
if (fread(col, sizeof(*col), 3, fp) != 3) { |
394 |
fprintf(stderr, "Data read error\n"); |
395 |
quit(1); |
396 |
397 |
sum += col[1]; |
398 |
399 |
return(sum / (xres*yres)); |
400 |
