root/radiance/ray/src/util/scanner.c
Changes since 1.4: +61 -41 lines
Diff to previous 1.4
Continued ANSIfication.
Changes since 1.3: +6 -2 lines
Diff to previous 1.3
Changes since 1.2: +7 -8 lines
Diff to previous 1.2
Fri Jun 4 14:33:40 1993 UTC (30 years, 11 months ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1
Removed unnecessary declaration of atof()
Tue Mar 12 13:05:12 1991 UTC (33 years, 2 months ago) by greg
