root/radiance/ray/src/util/scanner.c
Revision: 1.3
Committed: Sat Feb 22 02:07:30 2003 UTC (20 years, 1 month ago) by greg
Changes since 1.2: +7 -8 lines
5 * scanner.c - program to simulate bi-directional scanner.
6 *
7 * 6/10/86
8 */
9
10 #include <stdio.h>
11
12 #include <stdlib.h>
13
14 #include <ctype.h>
15
16 #include <signal.h>
17
18 #include "random.h"
19
20
21 #define PI 3.14159265358979324
22
23 #define ANGLE short
24 #define AEND -1
25
26 #define atorad(a) ((PI/180.0) * (a))
27
28 char otcom[128] = "oconv";
29 char rtcom[256] = "rtrace -bf -ar .25 -ad 128";
30
31 char *sourcetemp, /* temp files */
32 *octreetemp;
33
34 ANGLE alpha[181] = {90, AEND};
35 ANGLE beta[181] = {30, 60, 90, 120, 150, AEND};
36 ANGLE gamma[181] = {45, AEND};
37
38 char *target; /* target file name */
39 double targetw = 3.0; /* target width (inches) */
40 double targeth = 3.0; /* target height (inches) */
41 int xres = 16; /* x sample resolution */
42 int yres = 16; /* y sample resolution */
43
44
45 main(argc, argv)
46 int argc;
47 char *argv[];
48 {
49 char *strcat(), *mktemp();
50 int quit();
51 int i;
52
53 signal(SIGHUP, quit);
54 signal(SIGINT, quit);
55 signal(SIGTERM, quit);
56 signal(SIGXCPU, SIG_IGN);
57 signal(SIGXFSZ, SIG_IGN);
58
59 for (i = 1; i < argc && argv[i][0] == '-'; i++)
60 switch (argv[i][1]) {
61 case 't': /* target */
62 switch (argv[i][2]) {
63 case 'w': /* width */
64 targetw = atof(argv[++i]);
65 break;
66 case 'h': /* height */
67 targeth = atof(argv[++i]);
68 break;
69 default:
70 goto badopt;
71 }
72 break;
73 case 'a':
74 if (!strcmp(argv[i], "-alpha"))
75 setscan(alpha, argv[++i]);
76 else
77 switch (argv[i][2]) {
78 case 'd': /* ambient divisions */
79 strcat(rtcom, " -ad ");
80 strcat(rtcom, argv[++i]);
81 break;
82 case 'r': /* ambient radius */
83 strcat(rtcom, " -ar ");
84 strcat(rtcom, argv[++i]);
85 break;
86 default:
87 goto badopt;
88 }
89 break;
90 case 'b':
91 if (!strcmp(argv[i], "-beta"))
92 setscan(beta, argv[++i]);
93 else
94 goto badopt;
95 break;
96 case 'g':
97 if (!strcmp(argv[i], "-gamma"))
98 setscan(gamma, argv[++i]);
99 else
100 goto badopt;
101 break;
102 case 'x': /* x resolution */
103 xres = atoi(argv[++i]);
104 break;
105 case 'y': /* y resolution */
106 yres = atoi(argv[++i]);
107 break;
108 case 'l':
109 switch (argv[i][2]) {
110 case 'w': /* limit weight */
111 strcat(rtcom, " -lw ");
112 strcat(rtcom, argv[++i]);
113 break;
114 case 'r': /* limit recursion */
115 strcat(rtcom, " -lr ");
116 strcat(rtcom, argv[++i]);
117 break;
118 default:
119 goto badopt;
120 }
121 break;
122 default:;
123 badopt:
124 fprintf(stderr, "%s: bad option: %s\n",
125 argv[0], argv[i]);
126 quit(1);
127 }
128
129 if (i >= argc) {
130 fprintf(stderr, "%s: missing target file\n", argv[0]);
131 quit(1);
132 } else if (i < argc-1) {
133 fprintf(stderr, "%s: too many target files\n", argv[0]);
134 quit(1);
135 }
136
137 target = argv[i];
138 sourcetemp = mktemp("/usr/tmp/soXXXXXX");
139 octreetemp = mktemp("/usr/tmp/ocXXXXXX");
140 strcat(strcat(otcom, " "), target);
141 strcat(strcat(otcom, " "), sourcetemp);
142 strcat(strcat(otcom, " > "), octreetemp);
143 strcat(strcat(rtcom, " "), octreetemp);
144
145 doscan();
146
147 quit(0);
148 }
149
150
151 void
152 quit(code) /* unlink temp files and exit */
153 int code;
154 {
155 int i;
156
157 unlink(sourcetemp);
158 unlink(octreetemp);
159 exit(code);
160 }
161
162
163 setscan(ang, arg) /* set up scan according to arg */
164 register ANGLE *ang;
165 register char *arg;
166 {
167 int start = 0, finish = -1, step = 1;
168
169 for ( ; ; ) {
170 switch (*arg) {
171 case '\0':
172 case ',':
173 while (start <= finish) {
174 *ang++ = start;
175 start += step;
176 }
177 if (*arg) {
178 arg++;
179 continue;
180 } else {
181 *ang = AEND;
182 return;
183 }
184 case '0':
185 case '1':
186 case '2':
187 case '3':
188 case '4':
189 case '5':
190 case '6':
191 case '7':
192 case '8':
193 case '9':
194 start = atoi(arg);
195 finish = start;
196 step = 1;
197 break;
198 case '-':
199 finish = atoi(++arg);
200 break;
201 case ':':
202 step = atoi(++arg);
203 break;
204 default:
205 fprintf(stderr, "Scan specification error\n");
206 quit(1);
207 }
208 while (isdigit(*arg))
209 arg++;
210 }
211 }
212
213
214 doscan() /* do scan for target */
215 {
216 FILE *fopen(), *scanstart();
217 double readsample();
218 FILE *fp;
219 ANGLE *a, *b, *g;
220
221 printf("Alpha\tBeta\tGamma\tDistribution for \"%s\"\n", target);
222 for (g = gamma; *g != AEND; g++) {
223 fp = scanstart(*g);
224 for (b = beta; *b != AEND; b++) /* read data */
225 for (a = alpha; *a != AEND; a++)
226 printf("%d\t%d\t%d\t%f\n",
227 *a, *b, *g, readsample(fp));
228 scanend(fp);
229 }
230 }
231
232
233 FILE *
234 scanstart(g) /* open scanner pipeline */
235 ANGLE g;
236 {
237 char *fgets();
238 int p1[2], p2[2];
239 int pid;
240 FILE *fp;
241 char buf[128];
242
243 makesource(g); /* make source */
244 if (system(otcom)) /* generate new octree */
245 goto err;
246
247 if (pipe(p1) < 0) /* get pipe1 */
248 goto err;
249 if ((pid = fork()) == 0) { /* if child1 */
250 close(p1[0]);
251 if (p1[1] != 1) { /* connect stdout to pipe1 */
252 dup2(p1[1], 1);
253 close(p1[1]);
254 }
255 if (pipe(p2) < 0) /* get pipe2 */
256 goto err;
257 if ((pid = fork()) == 0) { /* if child2 */
258 close(p2[0]);
259 if ((fp = fdopen(p2[1], "w")) == NULL)
260 goto err;
261 sendsamples(fp); /* send our samples to pipe2 */
262 fclose(fp);
263 _exit(0);
264 }
265 if (pid == -1)
266 goto err;
267 close(p2[1]);
268
269 if (p2[0] != 0) { /* for child1 pipe2 to stdin */
270 dup2(p2[0], 0);
271 close(p2[0]);
272 }
273 execl("/bin/sh", "sh", "-c", rtcom, 0); /* run ray tracer */
274 goto err;
275 }
276 if (pid == -1)
277 goto err;
278 close(p1[1]);
279 if ((fp = fdopen(p1[0], "r")) == NULL) /* parent reads pipe1 */
280 goto err;
281 while (fgets(buf, sizeof(buf), fp) != NULL && buf[0] != '\n')
282 /* discard header */;
283 return(fp);
284 err:
285 fprintf(stderr, "System error in scanstart\n");
286 quit(1);
287 }
288
289
290 scanend(fp) /* done with scanner input */
291 FILE *fp;
292 {
293 fclose(fp);
294 }
295
296
297 makesource(g) /* make a source (output normalized) */
298 ANGLE g;
299 {
300 FILE *fp, *fopen();
301 double srcdir[3], sin(), cos();
302
303 srcdir[0] = sin(atorad(g));
304 srcdir[1] = 0.0;
305 srcdir[2] = -cos(atorad(g));
306 if ((fp = fopen(sourcetemp, "w")) == NULL) {
307 fprintf(stderr, "%s: cannot create\n", sourcetemp);
308 quit(1);
309 }
310 fprintf(fp, "0 0 0 1\n");
311 fprintf(fp, "\nvoid light scanner_light\n");
312 fprintf(fp, "0\n0\n3 3283 3283 3283\n");
313 fprintf(fp, "\nscanner_light source scanner_source\n");
314 fprintf(fp, "0\n0\n4 %f %f %f 2\n", srcdir[0], srcdir[1], srcdir[2]);
315 fclose(fp);
316 }
317
318
319 sendsamples(fp) /* send our samples to fp */
320 FILE *fp;
321 {
322 ANGLE *a, *b;
323
324 for (b = beta; *b != AEND; b++)
325 for (a = alpha; *a != AEND; a++)
326 writesample(fp, *a, *b);
327 }
328
329
330 writesample(fp, a, b) /* write out sample ray grid */
331 FILE *fp;
332 ANGLE a, b;
333 {
334 double sin(), cos();
335 float sp[6];
336 int i, j;
337
338 sp[3] = -sin(atorad(b)-(PI/2.0)) * sin(atorad(a));
339 sp[4] = -cos(atorad(a));
340 sp[5] = -sin(atorad(b)) * sin(atorad(a));
341
342 for (j = 0; j < yres; j++)
343 for (i = 0; i < xres; i++) {
344 sp[0] = -100.0*sp[3] +
345 (i - xres/2.0 + frandom())*targetw/xres;
346 sp[1] = -100.0*sp[4] +
347 (j - yres/2.0 + frandom())*targeth/yres;
348 sp[2] = -100.0*sp[5];
349 fwrite(sp, sizeof(*sp), 6, fp);
350 if (ferror(fp)) {
351 fprintf(stderr, "Data write error\n");
352 quit(1);
353 }
354 }
355 }
356
357
358 double
359 readsample(fp) /* read in sample ray grid */
360 FILE *fp;
361 {
362 double sum;
363 float col[3];
364 int i;
365
366 sum = 0.0;
367 i = xres*yres;
368 while (i--) {
369 if (fread(col, sizeof(*col), 3, fp) != 3) {
370 fprintf(stderr, "Data read error\n");
371 quit(1);
372 }
373 sum += col[1];
374 }
375 return(sum / (xres*yres));
376 }
