root/radiance/ray/src/util/scanner.c
Revision: 1.5
Committed: Fri Mar 26 23:34:23 2004 UTC (21 years, 1 month ago) by schorsch
CVS Tags: rad3R6P1, rad3R6
Changes since 1.4: +61 -41 lines
Continued ANSIfication.
2 static const char RCSid[] = "$Id: scanner.c,v 1.4 2003/06/26 00:58:11 schorsch Exp $";
5 * scanner.c - program to simulate bi-directional scanner.
6 *
7 * 6/10/86
8 */
9
10 #include <stdio.h>
11 #include <string.h>
12 #include <stdlib.h>
13 #include <ctype.h>
14 #include <signal.h>
15 #include <math.h>
16 #include <unistd.h> /* XXX pipe() fork() etc, use common/process.c instead */
17
18 #include "random.h"
19
20
21 #define PI 3.14159265358979324
22
23 #define ANGLE short
24 #define AEND -1
25
26 #define atorad(a) ((PI/180.0) * (a))
27
28 char otcom[128] = "oconv";
29 char rtcom[256] = "rtrace -bf -ar .25 -ad 128";
30
31 char *sourcetemp, /* temp files */
32 *octreetemp;
33
34 ANGLE alpha[181] = {90, AEND};
35 ANGLE beta[181] = {30, 60, 90, 120, 150, AEND};
36 ANGLE sgamma[181] = {45, AEND}; /* gamma() is a function from gnu <math.h> */
37
38 char *target; /* target file name */
39 double targetw = 3.0; /* target width (inches) */
40 double targeth = 3.0; /* target height (inches) */
41 int xres = 16; /* x sample resolution */
42 int yres = 16; /* y sample resolution */
43
44 static void quit(int code);
45 static void setscan(ANGLE *ang, char *arg);
46 static void doscan(void);
47 static void scanend(FILE *fp);
48 static void makesource(ANGLE g);
49 static void sendsamples(FILE *fp);
50 static void writesample(FILE *fp, ANGLE a, ANGLE b);
51 static FILE * scanstart(ANGLE g);
52 static double readsample(FILE *fp);
53
54 int
55 main(
56 int argc,
57 char *argv[]
58 )
59 {
60 int i;
61
62 #ifdef SIGHUP
63 signal(SIGHUP, quit);
64 #endif
65 signal(SIGINT, quit);
66 signal(SIGTERM, quit);
67 #ifdef SIGXCPU
68 signal(SIGXCPU, SIG_IGN);
69 signal(SIGXFSZ, SIG_IGN);
70 #endif
71
72 for (i = 1; i < argc && argv[i][0] == '-'; i++)
73 switch (argv[i][1]) {
74 case 't': /* target */
75 switch (argv[i][2]) {
76 case 'w': /* width */
77 targetw = atof(argv[++i]);
78 break;
79 case 'h': /* height */
80 targeth = atof(argv[++i]);
81 break;
82 default:
83 goto badopt;
84 }
85 break;
86 case 'a':
87 if (!strcmp(argv[i], "-alpha"))
88 setscan(alpha, argv[++i]);
89 else
90 switch (argv[i][2]) {
91 case 'd': /* ambient divisions */
92 strcat(rtcom, " -ad ");
93 strcat(rtcom, argv[++i]);
94 break;
95 case 'r': /* ambient radius */
96 strcat(rtcom, " -ar ");
97 strcat(rtcom, argv[++i]);
98 break;
99 default:
100 goto badopt;
101 }
102 break;
103 case 'b':
104 if (!strcmp(argv[i], "-beta"))
105 setscan(beta, argv[++i]);
106 else
107 goto badopt;
108 break;
109 case 'g':
110 if (!strcmp(argv[i], "-gamma"))
111 setscan(sgamma, argv[++i]);
112 else
113 goto badopt;
114 break;
115 case 'x': /* x resolution */
116 xres = atoi(argv[++i]);
117 break;
118 case 'y': /* y resolution */
119 yres = atoi(argv[++i]);
120 break;
121 case 'l':
122 switch (argv[i][2]) {
123 case 'w': /* limit weight */
124 strcat(rtcom, " -lw ");
125 strcat(rtcom, argv[++i]);
126 break;
127 case 'r': /* limit recursion */
128 strcat(rtcom, " -lr ");
129 strcat(rtcom, argv[++i]);
130 break;
131 default:
132 goto badopt;
133 }
134 break;
135 default:;
136 badopt:
137 fprintf(stderr, "%s: bad option: %s\n",
138 argv[0], argv[i]);
139 quit(1);
140 }
141
142 if (i >= argc) {
143 fprintf(stderr, "%s: missing target file\n", argv[0]);
144 quit(1);
145 } else if (i < argc-1) {
146 fprintf(stderr, "%s: too many target files\n", argv[0]);
147 quit(1);
148 }
149
150 target = argv[i];
151 sourcetemp = mktemp("/usr/tmp/soXXXXXX");
152 octreetemp = mktemp("/usr/tmp/ocXXXXXX");
153 strcat(strcat(otcom, " "), target);
154 strcat(strcat(otcom, " "), sourcetemp);
155 strcat(strcat(otcom, " > "), octreetemp);
156 strcat(strcat(rtcom, " "), octreetemp);
157
158 doscan();
159
160 quit(0);
161 return 0; /* pro forma return */
162 }
163
164
165 void
166 quit( /* unlink temp files and exit */
167 int code
168 )
169 {
170 unlink(sourcetemp);
171 unlink(octreetemp);
172 exit(code);
173 }
174
175
176 static void
177 setscan( /* set up scan according to arg */
178 register ANGLE *ang,
179 register char *arg
180 )
181 {
182 int start = 0, finish = -1, step = 1;
183
184 for ( ; ; ) {
185 switch (*arg) {
186 case '\0':
187 case ',':
188 while (start <= finish) {
189 *ang++ = start;
190 start += step;
191 }
192 if (*arg) {
193 arg++;
194 continue;
195 } else {
196 *ang = AEND;
197 return;
198 }
199 case '0':
200 case '1':
201 case '2':
202 case '3':
203 case '4':
204 case '5':
205 case '6':
206 case '7':
207 case '8':
208 case '9':
209 start = atoi(arg);
210 finish = start;
211 step = 1;
212 break;
213 case '-':
214 finish = atoi(++arg);
215 break;
216 case ':':
217 step = atoi(++arg);
218 break;
219 default:
220 fprintf(stderr, "Scan specification error\n");
221 quit(1);
222 }
223 while (isdigit(*arg))
224 arg++;
225 }
226 }
227
228
229 static void
230 doscan(void) /* do scan for target */
231 {
232 FILE *fp;
233 ANGLE *a, *b, *g;
234
235 printf("Alpha\tBeta\tGamma\tDistribution for \"%s\"\n", target);
236 for (g = sgamma; *g != AEND; g++) {
237 fp = scanstart(*g);
238 for (b = beta; *b != AEND; b++) /* read data */
239 for (a = alpha; *a != AEND; a++)
240 printf("%d\t%d\t%d\t%f\n",
241 *a, *b, *g, readsample(fp));
242 scanend(fp);
243 }
244 }
245
246
247 static FILE *
248 scanstart( /* open scanner pipeline */
249 ANGLE g
250 )
251 {
252 int p1[2], p2[2];
253 int pid;
254 FILE *fp;
255 char buf[128];
256
257 makesource(g); /* make source */
258 if (system(otcom)) /* generate new octree */
259 goto err;
260
261 if (pipe(p1) < 0) /* get pipe1 */
262 goto err;
263 if ((pid = fork()) == 0) { /* if child1 */
264 close(p1[0]);
265 if (p1[1] != 1) { /* connect stdout to pipe1 */
266 dup2(p1[1], 1);
267 close(p1[1]);
268 }
269 if (pipe(p2) < 0) /* get pipe2 */
270 goto err;
271 if ((pid = fork()) == 0) { /* if child2 */
272 close(p2[0]);
273 if ((fp = fdopen(p2[1], "w")) == NULL)
274 goto err;
275 sendsamples(fp); /* send our samples to pipe2 */
276 fclose(fp);
277 _exit(0);
278 }
279 if (pid == -1)
280 goto err;
281 close(p2[1]);
282
283 if (p2[0] != 0) { /* for child1 pipe2 to stdin */
284 dup2(p2[0], 0);
285 close(p2[0]);
286 }
287 execl("/bin/sh", "sh", "-c", rtcom, 0); /* run ray tracer */
288 goto err;
289 }
290 if (pid == -1)
291 goto err;
292 close(p1[1]);
293 if ((fp = fdopen(p1[0], "r")) == NULL) /* parent reads pipe1 */
294 goto err;
295 while (fgets(buf, sizeof(buf), fp) != NULL && buf[0] != '\n')
296 /* discard header */;
297 return(fp);
298 err:
299 fprintf(stderr, "System error in scanstart\n");
300 quit(1);
301 return NULL; /* pro forma return */
302 }
303
304
305 static void
306 scanend( /* done with scanner input */
307 FILE *fp
308 )
309 {
310 fclose(fp);
311 }
312
313
314 static void
315 makesource( /* make a source (output normalized) */
316 ANGLE g
317 )
318 {
319 FILE *fp;
320 double srcdir[3];
321
322 srcdir[0] = sin(atorad(g));
323 srcdir[1] = 0.0;
324 srcdir[2] = -cos(atorad(g));
325 if ((fp = fopen(sourcetemp, "w")) == NULL) {
326 fprintf(stderr, "%s: cannot create\n", sourcetemp);
327 quit(1);
328 }
329 fprintf(fp, "0 0 0 1\n");
330 fprintf(fp, "\nvoid light scanner_light\n");
331 fprintf(fp, "0\n0\n3 3283 3283 3283\n");
332 fprintf(fp, "\nscanner_light source scanner_source\n");
333 fprintf(fp, "0\n0\n4 %f %f %f 2\n", srcdir[0], srcdir[1], srcdir[2]);
334 fclose(fp);
335 }
336
337
338 static void
339 sendsamples( /* send our samples to fp */
340 FILE *fp
341 )
342 {
343 ANGLE *a, *b;
344
345 for (b = beta; *b != AEND; b++)
346 for (a = alpha; *a != AEND; a++)
347 writesample(fp, *a, *b);
348 }
349
350
351 static void
352 writesample( /* write out sample ray grid */
353 FILE *fp,
354 ANGLE a,
355 ANGLE b
356 )
357 {
358 float sp[6];
359 int i, j;
360
361 sp[3] = -sin(atorad(b)-(PI/2.0)) * sin(atorad(a));
362 sp[4] = -cos(atorad(a));
363 sp[5] = -sin(atorad(b)) * sin(atorad(a));
364
365 for (j = 0; j < yres; j++)
366 for (i = 0; i < xres; i++) {
367 sp[0] = -100.0*sp[3] +
368 (i - xres/2.0 + frandom())*targetw/xres;
369 sp[1] = -100.0*sp[4] +
370 (j - yres/2.0 + frandom())*targeth/yres;
371 sp[2] = -100.0*sp[5];
372 fwrite(sp, sizeof(*sp), 6, fp);
373 if (ferror(fp)) {
374 fprintf(stderr, "Data write error\n");
375 quit(1);
376 }
377 }
378 }
379
380
381 static double
382 readsample( /* read in sample ray grid */
383 FILE *fp
384 )
385 {
386 double sum;
387 float col[3];
388 int i;
389
390 sum = 0.0;
391 i = xres*yres;
392 while (i--) {
393 if (fread(col, sizeof(*col), 3, fp) != 3) {
394 fprintf(stderr, "Data read error\n");
395 quit(1);
396 }
397 sum += col[1];
398 }
399 return(sum / (xres*yres));
400 }
