root/radiance/ray/src/util/scanner.c
Revision: 1.1
Committed: Tue Mar 12 13:05:12 1991 UTC (33 years, 2 months ago) by greg
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * scanner.c - program to simulate bi-directional scanner.
9 *
10 * 6/10/86
11 */
12
13 #include "stdio.h"
14
15 #include "ctype.h"
16
17 #include "signal.h"
18
19 #include "random.h"
20
21
22 #define PI 3.14159265358979324
23
24 #define ANGLE short
25 #define AEND -1
26
27 #define atorad(a) ((PI/180.0) * (a))
28
29 char otcom[128] = "oconv";
30 char rtcom[256] = "rtrace -bf -ar .25 -ad 128";
31
32 char *sourcetemp, /* temp files */
33 *octreetemp;
34
35 ANGLE alpha[181] = {90, AEND};
36 ANGLE beta[181] = {30, 60, 90, 120, 150, AEND};
37 ANGLE gamma[181] = {45, AEND};
38
39 char *target; /* target file name */
40 double targetw = 3.0; /* target width (inches) */
41 double targeth = 3.0; /* target height (inches) */
42 int xres = 16; /* x sample resolution */
43 int yres = 16; /* y sample resolution */
44
45
46 main(argc, argv)
47 int argc;
48 char *argv[];
49 {
50 double atof();
51 char *strcat(), *mktemp();
52 int quit();
53 int i;
54
55 signal(SIGHUP, quit);
56 signal(SIGINT, quit);
57 signal(SIGTERM, quit);
58 signal(SIGXCPU, SIG_IGN);
59 signal(SIGXFSZ, SIG_IGN);
60
61 for (i = 1; i < argc && argv[i][0] == '-'; i++)
62 switch (argv[i][1]) {
63 case 't': /* target */
64 switch (argv[i][2]) {
65 case 'w': /* width */
66 targetw = atof(argv[++i]);
67 break;
68 case 'h': /* height */
69 targeth = atof(argv[++i]);
70 break;
71 default:
72 goto badopt;
73 }
74 break;
75 case 'a':
76 if (!strcmp(argv[i], "-alpha"))
77 setscan(alpha, argv[++i]);
78 else
79 switch (argv[i][2]) {
80 case 'd': /* ambient divisions */
81 strcat(rtcom, " -ad ");
82 strcat(rtcom, argv[++i]);
83 break;
84 case 'r': /* ambient radius */
85 strcat(rtcom, " -ar ");
86 strcat(rtcom, argv[++i]);
87 break;
88 default:
89 goto badopt;
90 }
91 break;
92 case 'b':
93 if (!strcmp(argv[i], "-beta"))
94 setscan(beta, argv[++i]);
95 else
96 goto badopt;
97 break;
98 case 'g':
99 if (!strcmp(argv[i], "-gamma"))
100 setscan(gamma, argv[++i]);
101 else
102 goto badopt;
103 break;
104 case 'x': /* x resolution */
105 xres = atoi(argv[++i]);
106 break;
107 case 'y': /* y resolution */
108 yres = atoi(argv[++i]);
109 break;
110 case 'l':
111 switch (argv[i][2]) {
112 case 'w': /* limit weight */
113 strcat(rtcom, " -lw ");
114 strcat(rtcom, argv[++i]);
115 break;
116 case 'r': /* limit recursion */
117 strcat(rtcom, " -lr ");
118 strcat(rtcom, argv[++i]);
119 break;
120 default:
121 goto badopt;
122 }
123 break;
124 default:;
125 badopt:
126 fprintf(stderr, "%s: bad option: %s\n",
127 argv[0], argv[i]);
128 quit(1);
129 }
130
131 if (i >= argc) {
132 fprintf(stderr, "%s: missing target file\n", argv[0]);
133 quit(1);
134 } else if (i < argc-1) {
135 fprintf(stderr, "%s: too many target files\n", argv[0]);
136 quit(1);
137 }
138
139 target = argv[i];
140 sourcetemp = mktemp("/usr/tmp/soXXXXXX");
141 octreetemp = mktemp("/usr/tmp/ocXXXXXX");
142 strcat(strcat(otcom, " "), target);
143 strcat(strcat(otcom, " "), sourcetemp);
144 strcat(strcat(otcom, " > "), octreetemp);
145 strcat(strcat(rtcom, " "), octreetemp);
146
147 doscan();
148
149 quit(0);
150 }
151
152
153 quit(code) /* unlink temp files and exit */
154 int code;
155 {
156 int i;
157
158 unlink(sourcetemp);
159 unlink(octreetemp);
160 exit(code);
161 }
162
163
164 setscan(ang, arg) /* set up scan according to arg */
165 register ANGLE *ang;
166 register char *arg;
167 {
168 int start = 0, finish = -1, step = 1;
169
170 for ( ; ; ) {
171 switch (*arg) {
172 case '\0':
173 case ',':
174 while (start <= finish) {
175 *ang++ = start;
176 start += step;
177 }
178 if (*arg) {
179 arg++;
180 continue;
181 } else {
182 *ang = AEND;
183 return;
184 }
185 case '0':
186 case '1':
187 case '2':
188 case '3':
189 case '4':
190 case '5':
191 case '6':
192 case '7':
193 case '8':
194 case '9':
195 start = atoi(arg);
196 finish = start;
197 step = 1;
198 break;
199 case '-':
200 finish = atoi(++arg);
201 break;
202 case ':':
203 step = atoi(++arg);
204 break;
205 default:
206 fprintf(stderr, "Scan specification error\n");
207 quit(1);
208 }
209 while (isdigit(*arg))
210 arg++;
211 }
212 }
213
214
215 doscan() /* do scan for target */
216 {
217 FILE *fopen(), *scanstart();
218 double readsample();
219 FILE *fp;
220 ANGLE *a, *b, *g;
221
222 printf("Alpha\tBeta\tGamma\tDistribution for \"%s\"\n", target);
223 for (g = gamma; *g != AEND; g++) {
224 fp = scanstart(*g);
225 for (b = beta; *b != AEND; b++) /* read data */
226 for (a = alpha; *a != AEND; a++)
227 printf("%d\t%d\t%d\t%f\n",
228 *a, *b, *g, readsample(fp));
229 scanend(fp);
230 }
231 }
232
233
234 FILE *
235 scanstart(g) /* open scanner pipeline */
236 ANGLE g;
237 {
238 char *fgets();
239 int p1[2], p2[2];
240 int pid;
241 FILE *fp;
242 char buf[128];
243
244 makesource(g); /* make source */
245 if (system(otcom)) /* generate new octree */
246 goto err;
247
248 if (pipe(p1) < 0) /* get pipe1 */
249 goto err;
250 if ((pid = fork()) == 0) { /* if child1 */
251 close(p1[0]);
252 if (p1[1] != 1) { /* connect stdout to pipe1 */
253 dup2(p1[1], 1);
254 close(p1[1]);
255 }
256 if (pipe(p2) < 0) /* get pipe2 */
257 goto err;
258 if ((pid = fork()) == 0) { /* if child2 */
259 close(p2[0]);
260 if ((fp = fdopen(p2[1], "w")) == NULL)
261 goto err;
262 sendsamples(fp); /* send our samples to pipe2 */
263 fclose(fp);
264 _exit(0);
265 }
266 if (pid == -1)
267 goto err;
268 close(p2[1]);
269
270 if (p2[0] != 0) { /* for child1 pipe2 to stdin */
271 dup2(p2[0], 0);
272 close(p2[0]);
273 }
274 execl("/bin/sh", "sh", "-c", rtcom, 0); /* run ray tracer */
275 goto err;
276 }
277 if (pid == -1)
278 goto err;
279 close(p1[1]);
280 if ((fp = fdopen(p1[0], "r")) == NULL) /* parent reads pipe1 */
281 goto err;
282 while (fgets(buf, sizeof(buf), fp) != NULL && buf[0] != '\n')
283 /* discard header */;
284 return(fp);
285 err:
286 fprintf(stderr, "System error in scanstart\n");
287 quit(1);
288 }
289
290
291 scanend(fp) /* done with scanner input */
292 FILE *fp;
293 {
294 fclose(fp);
295 }
296
297
298 makesource(g) /* make a source (output normalized) */
299 ANGLE g;
300 {
301 FILE *fp, *fopen();
302 double srcdir[3], sin(), cos();
303
304 srcdir[0] = sin(atorad(g));
305 srcdir[1] = 0.0;
306 srcdir[2] = -cos(atorad(g));
307 if ((fp = fopen(sourcetemp, "w")) == NULL) {
308 fprintf(stderr, "%s: cannot create\n", sourcetemp);
309 quit(1);
310 }
311 fprintf(fp, "0 0 0 1\n");
312 fprintf(fp, "\nvoid light scanner_light\n");
313 fprintf(fp, "0\n0\n3 3283 3283 3283\n");
314 fprintf(fp, "\nscanner_light source scanner_source\n");
315 fprintf(fp, "0\n0\n4 %f %f %f 2\n", srcdir[0], srcdir[1], srcdir[2]);
316 fclose(fp);
317 }
318
319
320 sendsamples(fp) /* send our samples to fp */
321 FILE *fp;
322 {
323 ANGLE *a, *b;
324
325 for (b = beta; *b != AEND; b++)
326 for (a = alpha; *a != AEND; a++)
327 writesample(fp, *a, *b);
328 }
329
330
331 writesample(fp, a, b) /* write out sample ray grid */
332 FILE *fp;
333 ANGLE a, b;
334 {
335 double sin(), cos();
336 float sp[6];
337 int i, j;
338
339 sp[3] = -sin(atorad(b)-(PI/2.0)) * sin(atorad(a));
340 sp[4] = -cos(atorad(a));
341 sp[5] = -sin(atorad(b)) * sin(atorad(a));
342
343 for (j = 0; j < yres; j++)
344 for (i = 0; i < xres; i++) {
345 sp[0] = -100.0*sp[3] +
346 (i - xres/2.0 + frandom())*targetw/xres;
347 sp[1] = -100.0*sp[4] +
348 (j - yres/2.0 + frandom())*targeth/yres;
349 sp[2] = -100.0*sp[5];
350 fwrite(sp, sizeof(*sp), 6, fp);
351 if (ferror(fp)) {
352 fprintf(stderr, "Data write error\n");
353 quit(1);
354 }
355 }
356 }
357
358
359 double
360 readsample(fp) /* read in sample ray grid */
361 FILE *fp;
362 {
363 double sum;
364 float col[3];
365 int i;
366
367 sum = 0.0;
368 i = xres*yres;
369 while (i--) {
370 if (fread(col, sizeof(*col), 3, fp) != 3) {
371 fprintf(stderr, "Data read error\n");
372 quit(1);
373 }
374 sum += col[1];
375 }
376 return(sum / (xres*yres));
377 }
