--- ray/src/util/rttree_reduce.c 2011/05/26 15:32:02 2.1 +++ ray/src/util/rttree_reduce.c 2011/08/20 02:46:13 2.5 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rttree_reduce.c,v 2.1 2011/05/26 15:32:02 greg Exp $"; +static const char RCSid[] = "$Id: rttree_reduce.c,v 2.5 2011/08/20 02:46:13 greg Exp $"; #endif /* * A utility called by genBSDF.pl to reduce tensor tree samples and output @@ -11,18 +11,17 @@ static const char RCSid[] = "$Id: rttree_reduce.c,v 2. #include "rterror.h" #include "platform.h" #include +#include float *datarr; /* our loaded BSDF data array */ int ttrank = 4; /* tensor tree rank */ int log2g = 4; /* log2 of grid resolution */ int infmt = 'a'; /* input format ('a','f','d') */ -double tthresh = .05; /* relative acceptance threshold */ +double pctcull = 95.; /* target culling percentile */ #define dval3(ix,ox,oy) datarr[((((ix)<vmax - (tp)->vmin > 2.*tthresh*(tp)->vavg) - /* Tensor tree node */ typedef struct ttree_s { float vmin, vmax; /* value extrema */ @@ -30,6 +29,17 @@ typedef struct ttree_s { struct ttree_s *kid; /* 2^ttrank children */ } TNODE; +#define HISTLEN 300 /* histogram resolution */ +#define HISTMAX 10. /* maximum recorded measure in histogram */ + +int histo[HISTLEN]; /* histogram freq. of variance measure */ + +double tthresh; /* acceptance threshold (TBD) */ + +#define var_measure(tp) ( ((tp)->vmax - (tp)->vmin) / \ + (sqrt((tp)->vavg) + .03) ) +#define above_threshold(tp) (var_measure(tp) > tthresh) + /* Allocate a new set of children for the given node (no checks) */ static void new_kids(TNODE *pn) @@ -77,6 +87,10 @@ build_tree(TNODE *tp, const int bmin[], int l2s) tp->vavg += val; } tp->vavg /= (float)(1<= HISTLEN) i = HISTLEN-1; + ++histo[i]; return; } --l2s; /* else still branching */ @@ -92,11 +106,38 @@ build_tree(TNODE *tp, const int bmin[], int l2s) tp->vavg += tp->kid[i].vavg; } tp->vavg /= (float)(1< 0; i++) + hsum -= histo[i]; + tthresh = (HISTMAX/HISTLEN) * i; +} + +/* Trim our tree according to the current threshold */ +static void +trim_tree(TNODE *tp) +{ + if (tp->kid == NULL) + return; + if (above_threshold(tp)) { /* keeping branches? */ + int i = 1<kid+i); + return; + } + free_kids(tp); /* else trim at this point */ +} + /* Print a tensor tree from the given hypercube */ static void print_tree(const TNODE *tp, const int bmin[], int l2s) @@ -111,7 +152,7 @@ print_tree(const TNODE *tp, const int bmin[], int l2s) for (i = 0; i < 1<>j & 1); + bkmin[j] = bmin[j] + (i>>(ttrank-1-j) & 1); val = (ttrank == 3) ? dval3(bkmin[0],bkmin[1],bkmin[2]) : dval4(bkmin[0],bkmin[1],bkmin[2],bkmin[3]); printf(" %.4e", val); @@ -219,17 +260,17 @@ load_data() error(SYSTEM, "out of memory in load_data"); if (ttrank == 3) { int ix, ox; - for (ix = 0; ix < 1<= 100.)) goto userr; break; case 'f': @@ -307,6 +348,9 @@ main(int argc, char *argv[]) gtree.kid = NULL; /* create our tree */ bmin[0] = bmin[1] = bmin[2] = bmin[3] = 0; build_tree(>ree, bmin, log2g); + /* compute threshold & trim tree */ + set_threshold(); + trim_tree(>ree); /* format to stdout */ print_tree(>ree, bmin, log2g); /* Clean up isn't necessary for main()... @@ -315,7 +359,7 @@ main(int argc, char *argv[]) */ return(0); userr: - fprintf(stderr, "Usage: %s [-h][-f{a|f|d}][-r {3|4}][-g log2grid][-t thresh] [input]\n", + fprintf(stderr, "Usage: %s [-h][-f{a|f|d}][-r {3|4}][-g log2grid][-t trim%%] [input]\n", argv[0]); return(1); }
