--- ray/src/util/rttree_reduce.c 2013/10/03 03:36:11 2.8 +++ ray/src/util/rttree_reduce.c 2014/03/18 01:33:07 2.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rttree_reduce.c,v 2.8 2013/10/03 03:36:11 greg Exp $"; +static const char RCSid[] = "$Id: rttree_reduce.c,v 2.10 2014/03/18 01:33:07 greg Exp $"; #endif /* * A utility called by genBSDF.pl to reduce tensor tree samples and output @@ -110,7 +110,7 @@ build_tree(TNODE *tp, const int bmin[], int l2s) /* Set our trimming threshold */ static void -set_threshold() +set_threshold(void) { int hsum = 0; int i; @@ -235,9 +235,30 @@ read_double(float *rowp, int n) return(nread); } +/* Truncate any negative values to zero */ +static void +noneg(float *varr, int n) +{ + int nnan = 0; + + while (n-- > 0) { +#ifdef isnan + if (isnan(*varr)) { + *varr = 0; + ++nnan; + } else +#endif + if (*varr < 0) *varr = 0; + ++varr; + } + if (nnan) + fprintf(stderr, "Warning: BSDF data contains %d NaN values\n", + nnan); +} + /* Load data array, filling zeroes for rank 3 demi-tensor */ static void -load_data() +load_data(void) { int (*readf)(float *, int) = NULL; @@ -289,11 +310,13 @@ load_data() } } else if (getc(stdin) != EOF) error(WARNING, "binary data past end of expected input"); + + noneg(datarr, 1<<(log2g*ttrank)); /* take precautions */ } /* Enforce reciprocity by averaging data values */ static void -do_reciprocity() +do_reciprocity(void) { const int siz = 1<
