root/radiance/ray/src/util/rttree_reduce.c
Tue Jun 30 17:18:22 2020 UTC (3 years, 11 months ago) by greg
Diff to previous 2.19 , to selected 2.4
feat(rttree_reduce): made header conform to more standard practice
Mon May 11 20:26:12 2020 UTC (4 years ago) by greg
Diff to previous 2.18 , to selected 2.4
Fixed integer overflow for very large trees
Sat Mar 2 17:05:45 2019 UTC (5 years, 3 months ago) by greg
Diff to previous 2.17 , to selected 2.4
Changed variance measure to be more sensitive towards bottom end
Wed May 31 03:26:46 2017 UTC (7 years ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.16: +13 -11 lines
Diff to previous 2.16 , to selected 2.4
Fixed incomplete reciprocity calculation
Thu Aug 18 00:52:48 2016 UTC (7 years, 9 months ago) by greg
Diff to previous 2.15 , to selected 2.4
Thu Mar 10 23:18:59 2016 UTC (8 years, 2 months ago) by schorsch
Changes since 2.14: +2 -3 lines
Diff to previous 2.14 , to selected 2.4
make 64 bit MSC happy about shifting
Thu Mar 10 16:25:05 2016 UTC (8 years, 2 months ago) by greg
Changes since 2.13: +2 -3 lines
Diff to previous 2.13 , to selected 2.4
Fixed potential 64-bit bug pointed out by Schorsch
Sun Mar 6 01:13:18 2016 UTC (8 years, 3 months ago) by schorsch
Wed Aug 12 00:10:51 2015 UTC (8 years, 9 months ago) by greg
Slight improvement to last change
Tue Aug 11 23:25:11 2015 UTC (8 years, 9 months ago) by greg
Better accuracy control in output formatting
Tue Mar 18 01:33:07 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.9: +27 -4 lines
Added protection against negative and NaN values on input
Mon Mar 17 01:59:48 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.8: +5 -2 lines
Added call to flockfile() to reduce i/o overhead
Thu Oct 3 03:36:11 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.7: +11 -10 lines
Fixed reciprocity averaging error discovered by Zack Rogers
Sun Mar 25 15:23:55 2012 UTC (12 years, 2 months ago) by greg
Added missing option from usage line
Mon Nov 21 20:07:50 2011 UTC (12 years, 6 months ago) by greg
Changes since 2.5: +35 -1 lines
Added reciprocity averaging
Sat Aug 20 02:46:13 2011 UTC (12 years, 9 months ago) by greg
Changes since 2.4: +4 -4 lines
Fixed bug in data ordering
Fri Jun 3 18:12:58 2011 UTC (13 years ago) by greg
Changes since 2.3: +4 -4 lines
Fixed bugs in variable-resolution isotropic BSDFs
Wed Jun 1 16:51:03 2011 UTC (13 years ago) by greg
Changes since 2.2: +14 -11 lines
Improved percentile thresholding measure
Tue May 31 20:50:26 2011 UTC (13 years ago) by greg
Changes since 2.1: +50 -9 lines
Thu May 26 15:32:02 2011 UTC (13 years ago) by greg
Diff to selected 2.4
Initial rttree_reduce implementation
