root/radiance/ray/src/util/rttree_reduce.c
Tue Jun 30 17:18:22 2020 UTC (4 years, 10 months ago) by greg
Diff to previous 2.19
feat(rttree_reduce): made header conform to more standard practice
Revision 2.19 - (view) (download) (annotate) - [selected]
Mon May 11 20:26:12 2020 UTC (4 years, 11 months ago) by greg
Diff to previous 2.18
Fixed integer overflow for very large trees
Sat Mar 2 17:05:45 2019 UTC (6 years, 2 months ago) by greg
Diff to previous 2.17 , to selected 2.19
Changed variance measure to be more sensitive towards bottom end
Wed May 31 03:26:46 2017 UTC (7 years, 11 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.16: +13 -11 lines
Diff to previous 2.16 , to selected 2.19
Fixed incomplete reciprocity calculation
Thu Aug 18 00:52:48 2016 UTC (8 years, 8 months ago) by greg
Diff to previous 2.15 , to selected 2.19
Thu Mar 10 23:18:59 2016 UTC (9 years, 1 month ago) by schorsch
Changes since 2.14: +2 -3 lines
Diff to previous 2.14 , to selected 2.19
make 64 bit MSC happy about shifting
Thu Mar 10 16:25:05 2016 UTC (9 years, 1 month ago) by greg
Changes since 2.13: +2 -3 lines
Diff to previous 2.13 , to selected 2.19
Fixed potential 64-bit bug pointed out by Schorsch
Sun Mar 6 01:13:18 2016 UTC (9 years, 2 months ago) by schorsch
Diff to previous 2.12 , to selected 2.19
Wed Aug 12 00:10:51 2015 UTC (9 years, 8 months ago) by greg
Diff to previous 2.11 , to selected 2.19
Slight improvement to last change
Tue Aug 11 23:25:11 2015 UTC (9 years, 8 months ago) by greg
Diff to previous 2.10 , to selected 2.19
Better accuracy control in output formatting
Tue Mar 18 01:33:07 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.9: +27 -4 lines
Diff to previous 2.9 , to selected 2.19
Added protection against negative and NaN values on input
Mon Mar 17 01:59:48 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.8: +5 -2 lines
Diff to previous 2.8 , to selected 2.19
Added call to flockfile() to reduce i/o overhead
Thu Oct 3 03:36:11 2013 UTC (11 years, 7 months ago) by greg
Changes since 2.7: +11 -10 lines
Diff to previous 2.7 , to selected 2.19
Fixed reciprocity averaging error discovered by Zack Rogers
Sun Mar 25 15:23:55 2012 UTC (13 years, 1 month ago) by greg
Diff to previous 2.6 , to selected 2.19
Added missing option from usage line
Mon Nov 21 20:07:50 2011 UTC (13 years, 5 months ago) by greg
Changes since 2.5: +35 -1 lines
Diff to previous 2.5 , to selected 2.19
Added reciprocity averaging
Sat Aug 20 02:46:13 2011 UTC (13 years, 8 months ago) by greg
Changes since 2.4: +4 -4 lines
Diff to previous 2.4 , to selected 2.19
Fixed bug in data ordering
Fri Jun 3 18:12:58 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.3: +4 -4 lines
Diff to previous 2.3 , to selected 2.19
Fixed bugs in variable-resolution isotropic BSDFs
Wed Jun 1 16:51:03 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.2: +14 -11 lines
Diff to previous 2.2 , to selected 2.19
Improved percentile thresholding measure
Tue May 31 20:50:26 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.1: +50 -9 lines
Diff to previous 2.1 , to selected 2.19
Thu May 26 15:32:02 2011 UTC (13 years, 11 months ago) by greg
Diff to selected 2.19
Initial rttree_reduce implementation
