| 1 |
#!/usr/bin/perl -w
| 2 |
# RCSid $Id: rtpict.pl,v 2.25 2022/04/12 00:30:58 greg Exp $
| 3 |
| 4 |
# Run rtrace in parallel mode to simulate rpict -n option
| 5 |
# May also be used to render layered images with -o* option
| 6 |
| 7 |
# G. Ward
| 8 |
| 9 |
use strict;
| 10 |
# we'll run rpict if no -n or -o* option
| 11 |
my $nprocs = 1;
| 12 |
# rtrace options and the associated number of arguments
| 13 |
my %rtraceC = ('-dt',1, '-dc',1, '-dj',1, '-ds',1, '-dr',1, '-dp',1,
| 14 |
'-ss',1, '-st',1, '-e',1, '-am',1, '-P',1, '-PP',1,
| 15 |
'-ab',1, '-af',1, '-ai',1, '-aI',1, '-ae',1, '-aE',1,
| 16 |
'-av',3, '-aw',1, '-aa',1, '-ar',1, '-ad',1, '-as',1,
| 17 |
'-me',3, '-ma',3, '-mg',1, '-ms',1, '-lr',1, '-lw',1,
| 18 |
'-ap',2, '-am',1, '-ac',1, '-aC',1);
| 19 |
# boolean rtrace options
| 20 |
my @boolO = ('-w', '-bv', '-dv', '-i', '-u');
| 21 |
# view options and the associated number of arguments
| 22 |
my %vwraysC = ('-vf',1, '-vtv',0, '-vtl',0, '-vth',0, '-vta',0, '-vts',0, '-vtc',0,
| 23 |
'-x',1, '-y',1, '-vp',3, '-vd',3, '-vu',3, '-vh',1, '-vv',1,
| 24 |
'-vo',1, '-va',1, '-vs',1, '-vl',1, '-pa',1, '-pj',1, '-pd',1);
| 25 |
# options we need to silently ignore
| 26 |
my %ignoreC = ('-t',1, '-ps',1, '-pt',1, '-pm',1,);
| 27 |
# Starting options for rtrace (rpict values)
| 28 |
my @rtraceA = split(' ', 'rtrace -u- -dt .05 -dc .5 -ds .25 -dr 1 ' .
| 29 |
'-aa .2 -ar 64 -ad 512 -as 128 -lr 7 -lw 1e-04');
| 30 |
my @vwraysA = ('vwrays', '-pj', '.67');
| 31 |
my @vwrightA = ('vwright', '-vtv');
| 32 |
my @rpictA = ('rpict', '-ps', '1');
| 33 |
my $outpatt = '^-o[vrxlLRXnNsmM]+';
| 34 |
my $refDepth = "";
| 35 |
my $irrad = 0;
| 36 |
my $persist = 0;
| 37 |
my $ambounce = 0;
| 38 |
my $ambcache = 1;
| 39 |
my $ambfile;
| 40 |
my $outlyr;
| 41 |
my $outdir;
| 42 |
my $outpic;
| 43 |
my $outzbf;
| 44 |
OPTION: # sort through options
| 45 |
while ($#ARGV >= 0 && "$ARGV[0]" =~ /^[-\@]/) {
| 46 |
# Check for file inclusion
| 47 |
if ("$ARGV[0]" =~ /^\@/) {
| 48 |
open my $handle, '<', substr($ARGV[0], 1) or die "No file for $ARGV[0]\n";
| 49 |
shift @ARGV;
| 50 |
chomp(my @args = <$handle>);
| 51 |
close $handle;
| 52 |
unshift @ARGV, split(/\s+/, "@args");
| 53 |
next OPTION;
| 54 |
| 55 |
# Check booleans
| 56 |
for my $boopt (@boolO) {
| 57 |
if ("$ARGV[0]" =~ ('^' . $boopt . '[-+01tfynTFYN]?$')) {
| 58 |
if ("$ARGV[0]" eq '-i') {
| 59 |
$irrad = ! $irrad;
| 60 |
} elsif ("$ARGV[0]" =~ /^-i[-+01tfynTFYN]/) {
| 61 |
$irrad = ("$ARGV[0]" =~ /^-i[+1tyTY]/);
| 62 |
| 63 |
push @rtraceA, $ARGV[0];
| 64 |
push @rpictA, shift(@ARGV);
| 65 |
next OPTION;
| 66 |
| 67 |
| 68 |
# Check view options
| 69 |
if (defined $vwraysC{$ARGV[0]}) {
| 70 |
push @vwraysA, $ARGV[0];
| 71 |
my $isvopt = ("$ARGV[0]" =~ /^-v/);
| 72 |
push(@vwrightA, $ARGV[0]) if ($isvopt);
| 73 |
| 74 |
for (my $i = $vwraysC{$rpictA[-1]}; $i-- > 0; ) {
| 75 |
| 76 |
| 77 |
| 78 |
| 79 |
next OPTION;
| 80 |
| 81 |
# Check rtrace options
| 82 |
if (defined $rtraceC{$ARGV[0]}) {
| 83 |
if ("$ARGV[0]" =~ /^-PP?$/) {
| 84 |
$persist = 1;
| 85 |
} elsif ("$ARGV[0]" eq '-ab') {
| 86 |
$ambounce = $ARGV[1];
| 87 |
} elsif ("$ARGV[0]" eq '-aa') {
| 88 |
$ambcache = ($ARGV[1] > 0.0);
| 89 |
} elsif ("$ARGV[0]" eq '-af') {
| 90 |
$ambfile = "$ARGV[1]";
| 91 |
| 92 |
| 93 |
| 94 |
for (my $i = $rtraceC{$rpictA[-1]}; $i-- > 0; ) {
| 95 |
| 96 |
| 97 |
| 98 |
next OPTION;
| 99 |
| 100 |
# Check options to ignore
| 101 |
if (defined $ignoreC{$ARGV[0]}) {
| 102 |
| 103 |
for (my $i = $ignoreC{$rpictA[-1]}; $i-- > 0; ) {
| 104 |
| 105 |
| 106 |
next OPTION;
| 107 |
| 108 |
# Check for output file or number of processes
| 109 |
if ("$ARGV[0]" eq '-o') {
| 110 |
shift @ARGV;
| 111 |
$outpic = shift(@ARGV);
| 112 |
} elsif ("$ARGV[0]" eq '-z') {
| 113 |
| 114 |
$outzbf = $ARGV[0];
| 115 |
| 116 |
} elsif ("$ARGV[0]" eq '-n') {
| 117 |
shift @ARGV;
| 118 |
$nprocs = shift(@ARGV);
| 119 |
} elsif ("$ARGV[0]" eq '-d') {
| 120 |
shift @ARGV;
| 121 |
$refDepth = ' -d ' . shift(@ARGV);
| 122 |
} elsif ("$ARGV[0]" =~ "$outpatt") {
| 123 |
| 124 |
$outlyr = substr(shift(@ARGV), 2);
| 125 |
$outdir = shift(@ARGV);
| 126 |
} else {
| 127 |
die "Unsupported option: " . $ARGV[0] . "\n";
| 128 |
| 129 |
| 130 |
die "Number of processes must be positive" if ($nprocs <= 0);
| 131 |
if (defined $outdir) { # check conflicting options
| 132 |
die "Options -o and -o* are mutually exclusive\n" if (defined $outpic);
| 133 |
die "Options -z and -o* are mutually exclusive\n" if (defined $outzbf);
| 134 |
| 135 |
if (defined $outpic) { # redirect output?
| 136 |
die "File '$outpic' already exists\n" if (-e $outpic);
| 137 |
open STDOUT, '>', "$outpic";
| 138 |
| 139 |
| 140 |
##### May as well run rpict?
| 141 |
if ($nprocs == 1 && $persist == 0 && !defined($outdir)) {
| 142 |
push(@rpictA, $ARGV[0]) if ($#ARGV == 0);
| 143 |
exec @rpictA ;
| 144 |
| 145 |
# OK, we're running rtrace in some capacity...
| 146 |
push @rtraceA, ('-n', "$nprocs");
| 147 |
die "Need single octree argument\n" if ($#ARGV != 0);
| 148 |
my $oct = $ARGV[0];
| 149 |
my $view = `@vwrightA 0`;
| 150 |
chomp $view;
| 151 |
my @res = split(/\s/, `@vwraysA -d`);
| 152 |
| 153 |
##### Resort pixels to reduce ambient cache collisions?
| 154 |
if ($nprocs > 1 && $ambounce > 0 && $ambcache && defined($ambfile)) {
| 155 |
if (!defined($outzbf) && !defined($outdir)) {
| 156 |
# Straight picture output, so just shuffle sample order
| 157 |
system "cnt -s $res[1] $res[3] > /tmp/ord$$.txt";
| 158 |
die "cnt error\n" if ( $? );
| 159 |
system "@vwraysA -ff -i < /tmp/ord$$.txt " .
| 160 |
"| @rtraceA -ffa -ov '$oct' > /tmp/pix$$.txt";
| 161 |
die "Error running rtrace\n" if ( $? );
| 162 |
system "( getinfo < /tmp/pix$$.txt | getinfo -a 'VIEW=$view'; " .
| 163 |
"getinfo - < /tmp/pix$$.txt | rlam /tmp/ord$$.txt - " .
| 164 |
"| sort -k2rn -k1n ) | pvalue -r -Y $res[3] +X $res[1]";
| 165 |
die "rlam error\n" if ( $? );
| 166 |
unlink ("/tmp/ord$$.txt", "/tmp/pix$$.txt");
| 167 |
exit 0;
| 168 |
| 169 |
# Else randomize overture calculation to prime ambient cache
| 170 |
my @ores = (int($res[1]/6), int($res[3]/6));
| 171 |
print STDERR "Running $ores[0] by $ores[1] overture calculation " .
| 172 |
"to populate '$ambfile'...\n";
| 173 |
system "cnt -s @ores | @vwraysA -i -ff -x $ores[0] -y $ores[1] -pj 0 " .
| 174 |
"| @rtraceA -ff -ov '$oct' > /dev/null";
| 175 |
die "Failure running overture\n" if ( $? );
| 176 |
print STDERR "Finished overture.\n";
| 177 |
| 178 |
| 179 |
##### Generating picture with depth buffer?
| 180 |
if (defined $outzbf) {
| 181 |
exec "@vwraysA -ff | @rtraceA -fff -olv @res '$oct' | " .
| 182 |
"rsplit -ih -iH -f -of '$outzbf' -oh -oH -of3 - | " .
| 183 |
"pvalue -r -df | getinfo -a 'VIEW=$view'";
| 184 |
| 185 |
| 186 |
##### Base case with output picture only?
| 187 |
if (! defined $outdir) {
| 188 |
exec "@vwraysA -ff | @rtraceA -ffc @res '$oct' | getinfo -a 'VIEW=$view'";
| 189 |
| 190 |
| 191 |
##### Layered image output case
| 192 |
my @rsplitA = ("rsplit", "'-t '", "-ih", "-iH", "-oh", "-oH");
| 193 |
# Supported rtrace -o* options and output file name.typ
| 194 |
my %rtoutC = (
| 195 |
v => 'radiance.hdr',
| 196 |
r => 'r_refl.hdr',
| 197 |
x => 'r_unrefl.hdr',
| 198 |
l => 'd_effective.dpt',
| 199 |
L => 'd_firstsurf.dpt',
| 200 |
R => 'd_refl.dpt',
| 201 |
X => 'd_unrefl.dpt',
| 202 |
n => 'perturbed.nrm',
| 203 |
N => 'unperturbed.nrm',
| 204 |
s => 'surface.idx',
| 205 |
m => 'modifier.idx',
| 206 |
M => 'material.idx'
| 207 |
| 208 |
# Arguments for rsplit based on output file type
| 209 |
my %rcodeC = (
| 210 |
'.hdr', ['-of3', '!pvalue -r -df -u'],
| 211 |
'.dpt', ['-of', "!rcode_depth$refDepth -ff"],
| 212 |
'.nrm', ['-of3', '!rcode_norm -ff'],
| 213 |
'.idx', ['-oa', '!rcode_ident "-t "']
| 214 |
| 215 |
if ($irrad) { # adjust actions for -i+ option
| 216 |
$rtoutC{'v'} = 'irradiance.hdr';
| 217 |
delete $rtoutC{'r'};
| 218 |
delete $rtoutC{'x'};
| 219 |
delete $rtoutC{'R'};
| 220 |
delete $rtoutC{'X'};
| 221 |
| 222 |
if (! -d $outdir) {
| 223 |
mkdir $outdir or die("Cannot create output directory '$outdir'\n");
| 224 |
| 225 |
# construct rsplit command
| 226 |
foreach my $oval (split //, $outlyr) {
| 227 |
die "Duplicate or unsupported type '$oval' in -o$outlyr\n"
| 228 |
if (!defined $rtoutC{$oval});
| 229 |
my $outfile = "$outdir/$rtoutC{$oval}";
| 230 |
die "File '$outfile' already exists\n" if (-e $outfile);
| 231 |
my ($otyp) = ($rtoutC{$oval} =~ /(\.[^.]+)$/);
| 232 |
push @rsplitA, $rcodeC{$otyp}[0];
| 233 |
push @rsplitA, qq{'$rcodeC{$otyp}[1] > "$outfile"'};
| 234 |
delete $rtoutC{$oval};
| 235 |
| 236 |
# call rtrace + rsplit
| 237 |
exec "@vwraysA -ff | @rtraceA -fff @res '$oct' | getinfo -a 'VIEW=$view' | @rsplitA";
