root/radiance/ray/src/util/rtpict.pl
Revision: 2.2
Committed: Tue Mar 20 01:38:27 2018 UTC (7 years, 1 month ago) by greg
Changes since 2.1: +25 -21 lines
Fixed issues with boolean arguments and miscellaneous
1 #!/usr/bin/perl -w
2 # RCSid $Id: rtpict.pl,v 2.1 2018/03/19 23:40:33 greg Exp $
3 #
4 # Run rtrace in parallel mode to simulate rpict -n option
5 #
6 # G. Ward
7 #
8 use strict;
9 # we'll call rpict if this is not overridden
10 my $nprocs = 1;
11 # rtrace options and the associated number of arguments
12 my %rtraceC = ("-dt",1, "-dc",1, "-dj",1, "-ds",1, "-dr",1, "-dp",1,
13 "-ss",1, "-st",1, "-e",1, "-am",1,
14 "-ab",1, "-af",1, "-ai",1, "-aI",1, "-ae",1, "-aE",1,
15 "-av",3, "-aw",1, "-aa",1, "-ar",1, "-ad",1, "-as",1,
16 "-me",3, "-ma",3, "-mg",1, "-ms",1, "-lr",1, "-lw",1);
17 # boolean rtrace options
18 my @boolO = ("-w", "-bv", "-dv", "-i", "-u");
19 # view options and the associated number of arguments
20 my %vwraysC = ("-vf",1, "-vtv",0, "-vtl",0, "-vth",0, "-vta",0, "-vts",0, "-vtc",0,
21 "-x",1, "-y",1, "-vp",3, "-vd",3, "-vu",3, "-vh",1, "-vv",1,
22 "-vo",1, "-va",1, "-vs",1, "-vl",1, "-pa",1, "-pj",1, "-pd",1);
23 # options we need to silently ignore
24 my %ignoreC = ("-t",1, "-ps",1, "-pt",1, "-pm",1);
25 # Starting options for rtrace (rpict values)
26 my @rtraceA = split(' ', "rtrace -ffc -u- -dt .05 -dc .5 -ds .25 -dr 1 -aa .2 -ar 64 -ad 512 -as 128 -lr 7 -lw 1e-03");
27 my @vwraysA = ("vwrays", "-ff", "-pj", ".67");
28 my @vwrightA = ("vwright", "-vtv");
29 my @rpictA = ("rpict");
30 my $outpic;
31 OPTION: # sort through options
32 while ($#ARGV >= 0 && "$ARGV[0]" =~ /^[-\@]/) {
33 # Check for file inclusion
34 if ("$ARGV[0]" =~ /^\@/) {
35 open my $handle, '<', substr($ARGV[0], 1);
36 shift @ARGV;
37 chomp(my @args = <$handle>);
38 close $handle;
39 unshift @ARGV, split(/\s+/, "@args");
40 next OPTION;
41 }
42 # Check booleans
43 for my $boopt (@boolO) {
44 if ("$ARGV[0]" =~ ('^' . $boopt . '[-+01tfynTFYN]$')) {
45 push @rtraceA, $ARGV[0];
46 push @rpictA, shift(@ARGV);
47 next OPTION;
48 }
49 }
50 # Check view options
51 if (defined $vwraysC{$ARGV[0]}) {
52 push @vwraysA, $ARGV[0];
53 my $isvopt = ("$ARGV[0]" =~ /^-v/);
54 push(@vwrightA, $ARGV[0]) if ($isvopt);
55 push @rpictA, shift(@ARGV);
56 for (my $i = $vwraysC{$rpictA[-1]}; $i-- > 0; ) {
57 push @vwraysA, $ARGV[0];
58 push(@vwrightA, $ARGV[0]) if ($isvopt);
59 push @rpictA, shift(@ARGV);
60 }
61 next OPTION;
62 }
63 # Check rtrace options
64 if (defined $rtraceC{$ARGV[0]}) {
65 push @rtraceA, $ARGV[0];
66 push @rpictA, shift(@ARGV);
67 for (my $i = $rtraceC{$rpictA[-1]}; $i-- > 0; ) {
68 push @rtraceA, $ARGV[0];
69 push @rpictA, shift(@ARGV);
70 }
71 next OPTION;
72 }
73 # Check options to ignore
74 if (defined $ignoreC{$ARGV[0]}) {
75 push @rpictA, shift(@ARGV);
76 for (my $i = $ignoreC{$rpictA[-1]}; $i-- > 0; ) {
77 push @rpictA, shift(@ARGV);
78 }
79 next OPTION;
80 }
81 # Check for output file or number of processes
82 if ("$ARGV[0]" eq "-o") {
83 shift @ARGV;
84 $outpic = shift(@ARGV);
85 } elsif ("$ARGV[0]" eq "-n") {
86 shift @ARGV;
87 $nprocs = shift(@ARGV);
88 } else {
89 die "Unsupported option: " . $ARGV[0] . "\n";
90 }
91 }
92 die "Number of processes must be positive" if ($nprocs <= 0);
93 if ($outpic) { # redirect output?
94 open STDOUT, '>', "$outpic";
95 }
96 if ($nprocs == 1) { # may as well run rpict?
97 push(@rpictA, $ARGV[0]) if ($#ARGV == 0);
98 exec @rpictA ;
99 }
100 die "Need single octree argument\n" if ($#ARGV != 0);
101 push @rtraceA, (`@vwraysA -d`);
102 chomp $rtraceA[-1];
103 push @rtraceA, ("-n", "$nprocs");
104 push @rtraceA, $ARGV[0];
105 my @view = (`@vwrightA 0`);
106 exec "@vwraysA | @rtraceA | getinfo -a 'VIEW=@view'";
