--- ray/src/util/rtpict.pl 2022/04/11 18:08:19 2.24 +++ ray/src/util/rtpict.pl 2022/04/12 00:30:58 2.25 @@ -1,5 +1,5 @@ #!/usr/bin/perl -w -# RCSid $Id: rtpict.pl,v 2.24 2022/04/11 18:08:19 greg Exp $ +# RCSid $Id: rtpict.pl,v 2.25 2022/04/12 00:30:58 greg Exp $ # # Run rtrace in parallel mode to simulate rpict -n option # May also be used to render layered images with -o* option @@ -153,7 +153,7 @@ my @res = split(/\s/, `@vwraysA -d`); ##### Resort pixels to reduce ambient cache collisions? if ($nprocs > 1 && $ambounce > 0 && $ambcache && defined($ambfile)) { if (!defined($outzbf) && !defined($outdir)) { - # Straight picture output, so just randomize sample order + # Straight picture output, so just shuffle sample order system "cnt -s $res[1] $res[3] > /tmp/ord$$.txt"; die "cnt error\n" if ( $? ); system "@vwraysA -ff -i < /tmp/ord$$.txt " . @@ -167,12 +167,11 @@ if ($nprocs > 1 && $ambounce > 0 && $ambcache && defin exit 0; } # Else randomize overture calculation to prime ambient cache - my $oxres = int($res[1]/6); - my $oyres = int($res[3]/6); - print STDERR "Running $oxres by $oyres overture calculation " . + my @ores = (int($res[1]/6), int($res[3]/6)); + print STDERR "Running $ores[0] by $ores[1] overture calculation " . "to populate '$ambfile'...\n"; - system "@vwraysA -x $oxres -y $oyres -pj 0 " . - "| sort -R | @rtraceA -faf -ov '$oct' > /dev/null"; + system "cnt -s @ores | @vwraysA -i -ff -x $ores[0] -y $ores[1] -pj 0 " . + "| @rtraceA -ff -ov '$oct' > /dev/null"; die "Failure running overture\n" if ( $? ); print STDERR "Finished overture.\n"; }
