--- ray/src/util/rtpict.pl 2022/04/11 14:59:54 2.23 +++ ray/src/util/rtpict.pl 2022/04/11 18:08:19 2.24 @@ -1,5 +1,5 @@ #!/usr/bin/perl -w -# RCSid $Id: rtpict.pl,v 2.23 2022/04/11 14:59:54 greg Exp $ +# RCSid $Id: rtpict.pl,v 2.24 2022/04/11 18:08:19 greg Exp $ # # Run rtrace in parallel mode to simulate rpict -n option # May also be used to render layered images with -o* option @@ -154,8 +154,8 @@ my @res = split(/\s/, `@vwraysA -d`); if ($nprocs > 1 && $ambounce > 0 && $ambcache && defined($ambfile)) { if (!defined($outzbf) && !defined($outdir)) { # Straight picture output, so just randomize sample order - system "cnt $res[1] $res[3] | sort -R > /tmp/ord$$.txt"; - die "sort error\n" if ( $? ); + system "cnt -s $res[1] $res[3] > /tmp/ord$$.txt"; + die "cnt error\n" if ( $? ); system "@vwraysA -ff -i < /tmp/ord$$.txt " . "| @rtraceA -ffa -ov '$oct' > /tmp/pix$$.txt"; die "Error running rtrace\n" if ( $? );
