--- ray/src/util/rtpict.pl 2022/04/11 04:03:36 2.22 +++ ray/src/util/rtpict.pl 2022/04/11 14:59:54 2.23 @@ -1,5 +1,5 @@ #!/usr/bin/perl -w -# RCSid $Id: rtpict.pl,v 2.22 2022/04/11 04:03:36 greg Exp $ +# RCSid $Id: rtpict.pl,v 2.23 2022/04/11 14:59:54 greg Exp $ # # Run rtrace in parallel mode to simulate rpict -n option # May also be used to render layered images with -o* option @@ -159,9 +159,9 @@ if ($nprocs > 1 && $ambounce > 0 && $ambcache && defin system "@vwraysA -ff -i < /tmp/ord$$.txt " . "| @rtraceA -ffa -ov '$oct' > /tmp/pix$$.txt"; die "Error running rtrace\n" if ( $? ); - system "( getinfo < /tmp/pix$$.txt ; getinfo - < /tmp/pix$$.txt " . - "| rlam /tmp/ord$$.txt - | sort -k2rn -k1n ) " . - "| pvalue -r -Y $res[3] +X $res[1] | getinfo -a 'VIEW=$view'"; + system "( getinfo < /tmp/pix$$.txt | getinfo -a 'VIEW=$view'; " . + "getinfo - < /tmp/pix$$.txt | rlam /tmp/ord$$.txt - " . + "| sort -k2rn -k1n ) | pvalue -r -Y $res[3] +X $res[1]"; die "rlam error\n" if ( $? ); unlink ("/tmp/ord$$.txt", "/tmp/pix$$.txt"); exit 0;
