--- ray/src/util/rtpict.pl 2022/04/10 16:00:14 2.21 +++ ray/src/util/rtpict.pl 2022/04/11 04:03:36 2.22 @@ -1,5 +1,5 @@ #!/usr/bin/perl -w -# RCSid $Id: rtpict.pl,v 2.21 2022/04/10 16:00:14 greg Exp $ +# RCSid $Id: rtpict.pl,v 2.22 2022/04/11 04:03:36 greg Exp $ # # Run rtrace in parallel mode to simulate rpict -n option # May also be used to render layered images with -o* option @@ -27,7 +27,7 @@ my %ignoreC = ('-t',1, '-ps',1, '-pt',1, '-pm',1,); # Starting options for rtrace (rpict values) my @rtraceA = split(' ', 'rtrace -u- -dt .05 -dc .5 -ds .25 -dr 1 ' . '-aa .2 -ar 64 -ad 512 -as 128 -lr 7 -lw 1e-03'); -my @vwraysA = ('vwrays', '-ff', '-pj', '.67'); +my @vwraysA = ('vwrays', '-pj', '.67'); my @vwrightA = ('vwright', '-vtv'); my @rpictA = ('rpict', '-ps', '1'); my $outpatt = '^-o[vrxlLRXnNsmM]+'; @@ -150,13 +150,28 @@ my $view = `@vwrightA 0`; chomp $view; my @res = split(/\s/, `@vwraysA -d`); ##################################################################### -##### Run overture calculation? +##### Resort pixels to reduce ambient cache collisions? if ($nprocs > 1 && $ambounce > 0 && $ambcache && defined($ambfile)) { + if (!defined($outzbf) && !defined($outdir)) { + # Straight picture output, so just randomize sample order + system "cnt $res[1] $res[3] | sort -R > /tmp/ord$$.txt"; + die "sort error\n" if ( $? ); + system "@vwraysA -ff -i < /tmp/ord$$.txt " . + "| @rtraceA -ffa -ov '$oct' > /tmp/pix$$.txt"; + die "Error running rtrace\n" if ( $? ); + system "( getinfo < /tmp/pix$$.txt ; getinfo - < /tmp/pix$$.txt " . + "| rlam /tmp/ord$$.txt - | sort -k2rn -k1n ) " . + "| pvalue -r -Y $res[3] +X $res[1] | getinfo -a 'VIEW=$view'"; + die "rlam error\n" if ( $? ); + unlink ("/tmp/ord$$.txt", "/tmp/pix$$.txt"); + exit 0; + } + # Else randomize overture calculation to prime ambient cache my $oxres = int($res[1]/6); my $oyres = int($res[3]/6); print STDERR "Running $oxres by $oyres overture calculation " . "to populate '$ambfile'...\n"; - system "@vwraysA -x $oxres -y $oyres -pj 0 -fa " . + system "@vwraysA -x $oxres -y $oyres -pj 0 " . "| sort -R | @rtraceA -faf -ov '$oct' > /dev/null"; die "Failure running overture\n" if ( $? ); print STDERR "Finished overture.\n"; @@ -164,14 +179,14 @@ if ($nprocs > 1 && $ambounce > 0 && $ambcache && defin ##################################################################### ##### Generating picture with depth buffer? if (defined $outzbf) { - exec "@vwraysA | @rtraceA -fff -olv @res '$oct' | " . + exec "@vwraysA -ff | @rtraceA -fff -olv @res '$oct' | " . "rsplit -ih -iH -f -of '$outzbf' -oh -oH -of3 - | " . "pvalue -r -df | getinfo -a 'VIEW=$view'"; } ##################################################################### ##### Base case with output picture only? if (! defined $outdir) { - exec "@vwraysA | @rtraceA -ffc @res '$oct' | getinfo -a 'VIEW=$view'"; + exec "@vwraysA -ff | @rtraceA -ffc @res '$oct' | getinfo -a 'VIEW=$view'"; } ##################################################################### ##### Layered image output case @@ -220,4 +235,4 @@ foreach my $oval (split //, $outlyr) { delete $rtoutC{$oval}; } # call rtrace + rsplit -exec "@vwraysA | @rtraceA -fff @res '$oct' | getinfo -a 'VIEW=$view' | @rsplitA"; +exec "@vwraysA -ff | @rtraceA -fff @res '$oct' | getinfo -a 'VIEW=$view' | @rsplitA";
