--- ray/src/util/rtpict.pl 2018/03/19 23:40:33 2.1 +++ ray/src/util/rtpict.pl 2018/05/22 15:16:53 2.6 @@ -1,5 +1,5 @@ #!/usr/bin/perl -w -# RCSid $Id: rtpict.pl,v 2.1 2018/03/19 23:40:33 greg Exp $ +# RCSid $Id: rtpict.pl,v 2.6 2018/05/22 15:16:53 greg Exp $ # # Run rtrace in parallel mode to simulate rpict -n option # @@ -17,20 +17,24 @@ my %rtraceC = ("-dt",1, "-dc",1, "-dj",1, "-ds",1, "-d # boolean rtrace options my @boolO = ("-w", "-bv", "-dv", "-i", "-u"); # view options and the associated number of arguments -my %vwraysC = ("-vtv",0, "-vtl",0, "-vth",0, "-vta",0, "-vts",0, "-vtc",0, +my %vwraysC = ("-vf",1, "-vtv",0, "-vtl",0, "-vth",0, "-vta",0, "-vts",0, "-vtc",0, "-x",1, "-y",1, "-vp",3, "-vd",3, "-vu",3, "-vh",1, "-vv",1, - "-vo",1, "-va",1, "-vs",1, "-vl",1, "-pa",1, "-pj",1); + "-vo",1, "-va",1, "-vs",1, "-vl",1, "-pa",1, "-pj",1, "-pd",1); +# options we need to silently ignore +my %ignoreC = ("-t",1, "-ps",1, "-pt",1, "-pm",1); # Starting options for rtrace (rpict values) -my @rtraceA = split(' ', "rtrace -ffc -u- -dt .05 -dc .5 -ds .25 -dr 1 -aa .2 -ar 64 -ad 512 -as 128 -lr 7 -lw 1e-03"); +my @rtraceA = split(' ', "rtrace -u- -dt .05 -dc .5 -ds .25 -dr 1 " . + "-aa .2 -ar 64 -ad 512 -as 128 -lr 7 -lw 1e-03"); my @vwraysA = ("vwrays", "-ff", "-pj", ".67"); my @vwrightA = ("vwright", "-vtv"); my @rpictA = ("rpict"); my $outpic; +my $outzbf; OPTION: # sort through options while ($#ARGV >= 0 && "$ARGV[0]" =~ /^[-\@]/) { # Check for file inclusion if ("$ARGV[0]" =~ /^\@/) { - open my $handle, '<', substr("$ARGV[0]", 1); + open my $handle, '<', substr($ARGV[0], 1); shift @ARGV; chomp(my @args = <$handle>); close $handle; @@ -39,64 +43,81 @@ while ($#ARGV >= 0 && "$ARGV[0]" =~ /^[-\@]/) { } # Check booleans for my $boopt (@boolO) { - if ("$ARGV[0]" =~ /"^" . $boopt . "[-+01tfynTFYN]$"/) { - push @rtraceA, "$ARGV[0]"; + if ("$ARGV[0]" =~ ('^' . $boopt . '[-+01tfynTFYN]?$')) { + push @rtraceA, $ARGV[0]; push @rpictA, shift(@ARGV); next OPTION; } } # Check view options if (defined $vwraysC{$ARGV[0]}) { - push @vwraysA, "$ARGV[0]"; + push @vwraysA, $ARGV[0]; my $isvopt = ("$ARGV[0]" =~ /^-v/); - push(@vwrightA, "$ARGV[0]") if ($isvopt); + push(@vwrightA, $ARGV[0]) if ($isvopt); push @rpictA, shift(@ARGV); - for (my $i = $vwraysC{$vwraysA[-1]}; $i-- > 0; ) { - push @vwraysA, "$ARGV[0]"; - push(@vwrightA, "$ARGV[0]") if ($isvopt); + for (my $i = $vwraysC{$rpictA[-1]}; $i-- > 0; ) { + push @vwraysA, $ARGV[0]; + push(@vwrightA, $ARGV[0]) if ($isvopt); push @rpictA, shift(@ARGV); } next OPTION; } # Check rtrace options if (defined $rtraceC{$ARGV[0]}) { - push @rtraceA, "$ARGV[0]"; + push @rtraceA, $ARGV[0]; push @rpictA, shift(@ARGV); - for (my $i = $rtraceC{$rtraceA[-1]}; $i-- > 0; ) { - push @rtraceA, "$ARGV[0]"; + for (my $i = $rtraceC{$rpictA[-1]}; $i-- > 0; ) { + push @rtraceA, $ARGV[0]; push @rpictA, shift(@ARGV); } next OPTION; } - # Check for pixel sampling option - if ("$ARGV[0]" eq "-ps") { - shift @ARGV; - die "We only support -ps 1\n" if (shift(@ARGV) > 1); + # Check options to ignore + if (defined $ignoreC{$ARGV[0]}) { + push @rpictA, shift(@ARGV); + for (my $i = $ignoreC{$rpictA[-1]}; $i-- > 0; ) { + push @rpictA, shift(@ARGV); + } next OPTION; } # Check for output file or number of processes if ("$ARGV[0]" eq "-o") { shift @ARGV; $outpic = shift(@ARGV); + } elsif ("$ARGV[0]" eq "-z") { + push @rpictA, shift(@ARGV); + $outzbf = $ARGV[0]; + push @rpictA, shift(@ARGV); } elsif ("$ARGV[0]" eq "-n") { shift @ARGV; $nprocs = shift(@ARGV); } else { - die "Unsupported option: " . "$ARGV[0]" . "\n"; + die "Unsupported option: " . $ARGV[0] . "\n"; } } die "Number of processes must be positive" if ($nprocs <= 0); -if ($outpic) { # redirect output? +if (defined $outpic) { # redirect output? + die "File '$outpic' already exists\n" if (-e $outpic); open STDOUT, '>', "$outpic"; } if ($nprocs == 1) { # may as well run rpict? - push(@rpictA, "$ARGV[0]") if ($#ARGV == 0); + push(@rpictA, $ARGV[0]) if ($#ARGV == 0); exec @rpictA ; } -die "Need single octree argument\n" if ($#ARGV != 0); -push @rtraceA, (`@vwraysA -d`); -chomp $rtraceA[-1]; push @rtraceA, ("-n", "$nprocs"); -push @rtraceA, "$ARGV[0]"; -my @view = (`@vwrightA 0`); -exec "@vwraysA | @rtraceA | getinfo -a 'VIEW=@view'"; +die "Need single octree argument\n" if ($#ARGV != 0); +my $oct = $ARGV[0]; +my $view = `@vwrightA 0`; +my @res = split(/\s/, `@vwraysA -d`); +if (defined $outzbf) { # generating depth buffer? + my $tres = "/tmp/rtp$$"; + system "@vwraysA | @rtraceA -fff -ovl $res[4] $oct > $tres" || exit 1; + system( q{getinfo -c rcalc -if4 -of -e '$1=$1;$2=$2;$3=$3' < } . + "$tres | pvalue -r -df -Y $res[3] +X $res[1] | " . + "getinfo -a 'VIEW=$view'" ); + system( "getinfo - < $tres | rcalc -if4 -of > $outzbf" . q{ -e '$1=$4'} ); + unlink $tres; + exit; +} + # no depth buffer, so simpler +exec "@vwraysA | @rtraceA -ffc @res $oct | getinfo -a 'VIEW=$view'";
