perf(rtpict): Swapped sort -R command for cnt -s
feat(cnt): Added -s option to shuffle output
perf(rtpict): Minor optimization to last addition
perf(rtpict): Improved random sampling to avoid ambient cache collisions
perf(rtpict): Minor simplification of overture command
perf(rtpict): Added overture calculation with ambient cache and -n > 1
feat(vwrays,rtpict): Added support for -pd option to sample depth-of-field
Added support for photon-mapping (thanks to Roland)
Added check for -P* persist option to preclude running rpict
Added support for persist mode, which rtrace will complain about if -n > 1
Added check so we don't overwrite output files created in earlier run with -o*
Added check for missing @file
Additional quoting to protect spaces in octree and z-buffer file names
Moved -pd to ignored options where it belongs
Simplified -o with -z slightly
Made it so output names don't collide when rcode2bmp run on all
Added -o* option to rtpict
Add -o* option (and -d) to support layered image folders
Fixed issue with boolean option toggling (thanks to Axel Jacobs)
Added support for -z option (depth buffer output)
Added check if output picture exists with -o option to match rpict behavior
Removed rtpict from Windows build, while fixing quoting so it *could* run
Fixed issues with boolean arguments and miscellaneous
