root/Development/ray/src/util/rtpict.pl
Revision: 2.26
Committed: Tue Jan 24 21:54:49 2023 UTC (2 years, 9 months ago) by greg
# User Rev Content
1 greg 2.1 #!/usr/bin/perl -w
2 greg 2.26 # RCSid $Id: rtpict.pl,v 2.25 2022/04/12 00:30:58 greg Exp $
3 greg 2.1 #
4     # Run rtrace in parallel mode to simulate rpict -n option
5 greg 2.8 # May also be used to render layered images with -o* option
6 greg 2.1 #
7     # G. Ward
8     #
9     use strict;
10 greg 2.8 # we'll run rpict if no -n or -o* option
11 greg 2.1 my $nprocs = 1;
12     # rtrace options and the associated number of arguments
13 greg 2.9 my %rtraceC = ('-dt',1, '-dc',1, '-dj',1, '-ds',1, '-dr',1, '-dp',1,
14 greg 2.16 '-ss',1, '-st',1, '-e',1, '-am',1, '-P',1, '-PP',1,
15 greg 2.9 '-ab',1, '-af',1, '-ai',1, '-aI',1, '-ae',1, '-aE',1,
16     '-av',3, '-aw',1, '-aa',1, '-ar',1, '-ad',1, '-as',1,
17 greg 2.18 '-me',3, '-ma',3, '-mg',1, '-ms',1, '-lr',1, '-lw',1,
18     '-ap',2, '-am',1, '-ac',1, '-aC',1);
19 greg 2.1 # boolean rtrace options
20 greg 2.9 my @boolO = ('-w', '-bv', '-dv', '-i', '-u');
21 greg 2.1 # view options and the associated number of arguments
22 greg 2.9 my %vwraysC = ('-vf',1, '-vtv',0, '-vtl',0, '-vth',0, '-vta',0, '-vts',0, '-vtc',0,
23     '-x',1, '-y',1, '-vp',3, '-vd',3, '-vu',3, '-vh',1, '-vv',1,
24 greg 2.19 '-vo',1, '-va',1, '-vs',1, '-vl',1, '-pa',1, '-pj',1, '-pd',1);
25 greg 2.2 # options we need to silently ignore
26 greg 2.19 my %ignoreC = ('-t',1, '-ps',1, '-pt',1, '-pm',1,);
27 greg 2.1 # Starting options for rtrace (rpict values)
28 greg 2.9 my @rtraceA = split(' ', 'rtrace -u- -dt .05 -dc .5 -ds .25 -dr 1 ' .
29 greg 2.26 '-aa .2 -ar 64 -ad 512 -as 128 -lr 7 -lw 1e-04');
30 greg 2.22 my @vwraysA = ('vwrays', '-pj', '.67');
31 greg 2.9 my @vwrightA = ('vwright', '-vtv');
32 greg 2.17 my @rpictA = ('rpict', '-ps', '1');
33 greg 2.9 my $outpatt = '^-o[vrxlLRXnNsmM]+';
34     my $refDepth = "";
35     my $irrad = 0;
36 greg 2.17 my $persist = 0;
37 greg 2.20 my $ambounce = 0;
38     my $ambcache = 1;
39     my $ambfile;
40 greg 2.8 my $outlyr;
41     my $outdir;
42 greg 2.1 my $outpic;
43 greg 2.5 my $outzbf;
44 greg 2.1 OPTION: # sort through options
45     while ($#ARGV >= 0 && "$ARGV[0]" =~ /^[-\@]/) {
46     # Check for file inclusion
47     if ("$ARGV[0]" =~ /^\@/) {
48 greg 2.14 open my $handle, '<', substr($ARGV[0], 1) or die "No file for $ARGV[0]\n";
49 greg 2.1 shift @ARGV;
50     chomp(my @args = <$handle>);
51     close $handle;
52     unshift @ARGV, split(/\s+/, "@args");
53     next OPTION;
54     }
55     # Check booleans
56     for my $boopt (@boolO) {
57 greg 2.6 if ("$ARGV[0]" =~ ('^' . $boopt . '[-+01tfynTFYN]?$')) {
58 greg 2.9 if ("$ARGV[0]" eq '-i') {
59 greg 2.8 $irrad = ! $irrad;
60     } elsif ("$ARGV[0]" =~ /^-i[-+01tfynTFYN]/) {
61     $irrad = ("$ARGV[0]" =~ /^-i[+1tyTY]/);
62     }
63 greg 2.9 push @rtraceA, $ARGV[0];
64     push @rpictA, shift(@ARGV);
65 greg 2.1 next OPTION;
66     }
67     }
68     # Check view options
69     if (defined $vwraysC{$ARGV[0]}) {
70 greg 2.2 push @vwraysA, $ARGV[0];
71 greg 2.1 my $isvopt = ("$ARGV[0]" =~ /^-v/);
72 greg 2.2 push(@vwrightA, $ARGV[0]) if ($isvopt);
73 greg 2.1 push @rpictA, shift(@ARGV);
74 greg 2.2 for (my $i = $vwraysC{$rpictA[-1]}; $i-- > 0; ) {
75     push @vwraysA, $ARGV[0];
76     push(@vwrightA, $ARGV[0]) if ($isvopt);
77 greg 2.1 push @rpictA, shift(@ARGV);
78     }
79     next OPTION;
80     }
81     # Check rtrace options
82     if (defined $rtraceC{$ARGV[0]}) {
83 greg 2.20 if ("$ARGV[0]" =~ /^-PP?$/) {
84     $persist = 1;
85     } elsif ("$ARGV[0]" eq '-ab') {
86     $ambounce = $ARGV[1];
87     } elsif ("$ARGV[0]" eq '-aa') {
88     $ambcache = ($ARGV[1] > 0.0);
89     } elsif ("$ARGV[0]" eq '-af') {
90     $ambfile = "$ARGV[1]";
91     }
92 greg 2.2 push @rtraceA, $ARGV[0];
93 greg 2.1 push @rpictA, shift(@ARGV);
94 greg 2.2 for (my $i = $rtraceC{$rpictA[-1]}; $i-- > 0; ) {
95     push @rtraceA, $ARGV[0];
96 greg 2.1 push @rpictA, shift(@ARGV);
97     }
98     next OPTION;
99     }
100 greg 2.2 # Check options to ignore
101     if (defined $ignoreC{$ARGV[0]}) {
102     push @rpictA, shift(@ARGV);
103     for (my $i = $ignoreC{$rpictA[-1]}; $i-- > 0; ) {
104     push @rpictA, shift(@ARGV);
105     }
106 greg 2.1 next OPTION;
107     }
108     # Check for output file or number of processes
109 greg 2.9 if ("$ARGV[0]" eq '-o') {
110 greg 2.1 shift @ARGV;
111     $outpic = shift(@ARGV);
112 greg 2.9 } elsif ("$ARGV[0]" eq '-z') {
113 greg 2.5 push @rpictA, shift(@ARGV);
114     $outzbf = $ARGV[0];
115     push @rpictA, shift(@ARGV);
116 greg 2.9 } elsif ("$ARGV[0]" eq '-n') {
117 greg 2.1 shift @ARGV;
118     $nprocs = shift(@ARGV);
119 greg 2.9 } elsif ("$ARGV[0]" eq '-d') {
120 greg 2.8 shift @ARGV;
121 greg 2.9 $refDepth = ' -d ' . shift(@ARGV);
122 greg 2.8 } elsif ("$ARGV[0]" =~ "$outpatt") {
123     push @rtraceA, $ARGV[0];
124     $outlyr = substr(shift(@ARGV), 2);
125     $outdir = shift(@ARGV);
126 greg 2.1 } else {
127 greg 2.2 die "Unsupported option: " . $ARGV[0] . "\n";
128 greg 2.1 }
129     }
130     die "Number of processes must be positive" if ($nprocs <= 0);
131 greg 2.8 if (defined $outdir) { # check conflicting options
132     die "Options -o and -o* are mutually exclusive\n" if (defined $outpic);
133     die "Options -z and -o* are mutually exclusive\n" if (defined $outzbf);
134     }
135 greg 2.4 if (defined $outpic) { # redirect output?
136     die "File '$outpic' already exists\n" if (-e $outpic);
137 greg 2.1 open STDOUT, '>', "$outpic";
138     }
139 greg 2.9 #####################################################################
140     ##### May as well run rpict?
141 greg 2.17 if ($nprocs == 1 && $persist == 0 && !defined($outdir)) {
142 greg 2.2 push(@rpictA, $ARGV[0]) if ($#ARGV == 0);
143 greg 2.1 exec @rpictA ;
144     }
145 greg 2.9 # OK, we're running rtrace in some capacity...
146     push @rtraceA, ('-n', "$nprocs");
147 greg 2.1 die "Need single octree argument\n" if ($#ARGV != 0);
148 greg 2.5 my $oct = $ARGV[0];
149     my $view = `@vwrightA 0`;
150 greg 2.9 chomp $view;
151 greg 2.5 my @res = split(/\s/, `@vwraysA -d`);
152 greg 2.9 #####################################################################
153 greg 2.22 ##### Resort pixels to reduce ambient cache collisions?
154 greg 2.20 if ($nprocs > 1 && $ambounce > 0 && $ambcache && defined($ambfile)) {
155 greg 2.22 if (!defined($outzbf) && !defined($outdir)) {
156 greg 2.25 # Straight picture output, so just shuffle sample order
157 greg 2.24 system "cnt -s $res[1] $res[3] > /tmp/ord$$.txt";
158     die "cnt error\n" if ( $? );
159 greg 2.22 system "@vwraysA -ff -i < /tmp/ord$$.txt " .
160     "| @rtraceA -ffa -ov '$oct' > /tmp/pix$$.txt";
161     die "Error running rtrace\n" if ( $? );
162 greg 2.23 system "( getinfo < /tmp/pix$$.txt | getinfo -a 'VIEW=$view'; " .
163     "getinfo - < /tmp/pix$$.txt | rlam /tmp/ord$$.txt - " .
164     "| sort -k2rn -k1n ) | pvalue -r -Y $res[3] +X $res[1]";
165 greg 2.22 die "rlam error\n" if ( $? );
166     unlink ("/tmp/ord$$.txt", "/tmp/pix$$.txt");
167     exit 0;
168     }
169     # Else randomize overture calculation to prime ambient cache
170 greg 2.25 my @ores = (int($res[1]/6), int($res[3]/6));
171     print STDERR "Running $ores[0] by $ores[1] overture calculation " .
172 greg 2.20 "to populate '$ambfile'...\n";
173 greg 2.25 system "cnt -s @ores | @vwraysA -i -ff -x $ores[0] -y $ores[1] -pj 0 " .
174     "| @rtraceA -ff -ov '$oct' > /dev/null";
175 greg 2.20 die "Failure running overture\n" if ( $? );
176     print STDERR "Finished overture.\n";
177     }
178     #####################################################################
179 greg 2.9 ##### Generating picture with depth buffer?
180     if (defined $outzbf) {
181 greg 2.22 exec "@vwraysA -ff | @rtraceA -fff -olv @res '$oct' | " .
182 greg 2.13 "rsplit -ih -iH -f -of '$outzbf' -oh -oH -of3 - | " .
183 greg 2.11 "pvalue -r -df | getinfo -a 'VIEW=$view'";
184 greg 2.5 }
185 greg 2.9 #####################################################################
186     ##### Base case with output picture only?
187     if (! defined $outdir) {
188 greg 2.22 exec "@vwraysA -ff | @rtraceA -ffc @res '$oct' | getinfo -a 'VIEW=$view'";
189 greg 2.9 }
190     #####################################################################
191     ##### Layered image output case
192     my @rsplitA = ("rsplit", "'-t '", "-ih", "-iH", "-oh", "-oH");
193     # Supported rtrace -o* options and output file name.typ
194     my %rtoutC = (
195     v => 'radiance.hdr',
196 greg 2.10 r => 'r_refl.hdr',
197     x => 'r_unrefl.hdr',
198     l => 'd_effective.dpt',
199     L => 'd_firstsurf.dpt',
200     R => 'd_refl.dpt',
201     X => 'd_unrefl.dpt',
202 greg 2.9 n => 'perturbed.nrm',
203     N => 'unperturbed.nrm',
204     s => 'surface.idx',
205     m => 'modifier.idx',
206     M => 'material.idx'
207     );
208     # Arguments for rsplit based on output file type
209     my %rcodeC = (
210     '.hdr', ['-of3', '!pvalue -r -df -u'],
211     '.dpt', ['-of', "!rcode_depth$refDepth -ff"],
212     '.nrm', ['-of3', '!rcode_norm -ff'],
213     '.idx', ['-oa', '!rcode_ident "-t "']
214     );
215     if ($irrad) { # adjust actions for -i+ option
216     $rtoutC{'v'} = 'irradiance.hdr';
217     delete $rtoutC{'r'};
218     delete $rtoutC{'x'};
219     delete $rtoutC{'R'};
220     delete $rtoutC{'X'};
221     }
222     if (! -d $outdir) {
223     mkdir $outdir or die("Cannot create output directory '$outdir'\n");
224     }
225     # construct rsplit command
226     foreach my $oval (split //, $outlyr) {
227     die "Duplicate or unsupported type '$oval' in -o$outlyr\n"
228     if (!defined $rtoutC{$oval});
229 greg 2.15 my $outfile = "$outdir/$rtoutC{$oval}";
230     die "File '$outfile' already exists\n" if (-e $outfile);
231 greg 2.9 my ($otyp) = ($rtoutC{$oval} =~ /(\.[^.]+)$/);
232     push @rsplitA, $rcodeC{$otyp}[0];
233 greg 2.15 push @rsplitA, qq{'$rcodeC{$otyp}[1] > "$outfile"'};
234 greg 2.9 delete $rtoutC{$oval};
235     }
236     # call rtrace + rsplit
237 greg 2.22 exec "@vwraysA -ff | @rtraceA -fff @res '$oct' | getinfo -a 'VIEW=$view' | @rsplitA";
