root/radiance/ray/src/util/rtpict.pl
Wed Apr 8 16:20:00 2020 UTC (4 years, 1 month ago) by greg
Added support for photon-mapping (thanks to Roland)
Wed Apr 8 02:39:30 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.16: +5 -3 lines
Added check for -P* persist option to preclude running rpict
Wed Apr 8 00:58:32 2020 UTC (4 years, 1 month ago) by greg
Added support for persist mode, which rtrace will complain about if -n > 1
Sun Mar 15 16:54:19 2020 UTC (4 years, 2 months ago) by greg
Changes since 2.14: +4 -2 lines
Added check so we don't overwrite output files created in earlier run with -o*
Sat Mar 14 20:09:55 2020 UTC (4 years, 2 months ago) by greg
Added check for missing @file
Fri Dec 13 21:43:47 2019 UTC (4 years, 5 months ago) by greg
Changes since 2.12: +5 -5 lines
Additional quoting to protect spaces in octree and z-buffer file names
Fri Aug 16 04:32:46 2019 UTC (4 years, 8 months ago) by greg
Moved -pd to ignored options where it belongs
Wed Aug 14 22:57:24 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.10: +3 -5 lines
Simplified -o with -z slightly
Wed Aug 14 22:18:03 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.9: +7 -7 lines
Made it so output names don't collide when rcode2bmp run on all
Tue Jul 23 18:17:55 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.8: +86 -100 lines
Added -o* option to rtpict
Tue Jul 23 01:03:30 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.7: +95 -4 lines
Add -o* option (and -d) to support layered image folders
Fri Jul 5 00:20:57 2019 UTC (4 years, 10 months ago) by greg
Changes since 2.6: +6 -9 lines
Tue May 22 15:16:53 2018 UTC (5 years, 11 months ago) by greg
Fixed issue with boolean option toggling (thanks to Axel Jacobs)
Wed Mar 21 17:56:08 2018 UTC (6 years, 1 month ago) by greg
Changes since 2.4: +24 -8 lines
Added support for -z option (depth buffer output)
Tue Mar 20 23:05:48 2018 UTC (6 years, 1 month ago) by greg
Added check if output picture exists with -o option to match rpict behavior
Tue Mar 20 22:48:10 2018 UTC (6 years, 1 month ago) by greg
Removed rtpict from Windows build, while fixing quoting so it *could* run
Tue Mar 20 01:38:27 2018 UTC (6 years, 1 month ago) by greg
Changes since 2.1: +25 -21 lines
Fixed issues with boolean arguments and miscellaneous
Mon Mar 19 23:40:33 2018 UTC (6 years, 1 month ago) by greg
Diff to selected 2.2
