--- ray/src/util/rtpict.pl 2018/03/21 17:56:08 2.5 +++ ray/src/util/rtpict.pl 2019/07/23 01:03:30 2.8 @@ -1,12 +1,13 @@ #!/usr/bin/perl -w -# RCSid $Id: rtpict.pl,v 2.5 2018/03/21 17:56:08 greg Exp $ +# RCSid $Id: rtpict.pl,v 2.8 2019/07/23 01:03:30 greg Exp $ # # Run rtrace in parallel mode to simulate rpict -n option +# May also be used to render layered images with -o* option # # G. Ward # use strict; -# we'll call rpict if this is not overridden +# we'll run rpict if no -n or -o* option my $nprocs = 1; # rtrace options and the associated number of arguments my %rtraceC = ("-dt",1, "-dc",1, "-dj",1, "-ds",1, "-dr",1, "-dp",1, @@ -16,6 +17,7 @@ my %rtraceC = ("-dt",1, "-dc",1, "-dj",1, "-ds",1, "-d "-me",3, "-ma",3, "-mg",1, "-ms",1, "-lr",1, "-lw",1); # boolean rtrace options my @boolO = ("-w", "-bv", "-dv", "-i", "-u"); +my $irrad = 0; # view options and the associated number of arguments my %vwraysC = ("-vf",1, "-vtv",0, "-vtl",0, "-vth",0, "-vta",0, "-vts",0, "-vtc",0, "-x",1, "-y",1, "-vp",3, "-vd",3, "-vu",3, "-vh",1, "-vv",1, @@ -28,6 +30,32 @@ my @rtraceA = split(' ', "rtrace -u- -dt .05 -dc .5 -d my @vwraysA = ("vwrays", "-ff", "-pj", ".67"); my @vwrightA = ("vwright", "-vtv"); my @rpictA = ("rpict"); +my @rsplitA = ("rsplit", "'-t '", "-ih", "-iH", "-oh", "-oH"); +my $refDepth=""; +# Supported rtrace -o* options and data type encoders +my %rtoutC = ( + v => "radiance.hdr", + r => "mirrored.hdr", + x => "unmirrored.hdr", + i => "irradiance.hdr", + l => "effective.dpt", + L => "firstsurface.dpt", + R => "mirrored.dpt", + X => "unmirrored.dpt", + n => "perturbed.nrm", + N => "unperturbed.nrm", + s => "surface.idx", + m => "modifier.idx", + M => "material.idx" +); +my $outpatt = "^-o[vrxlLRXnNsmM]+"; +# Supported compressed format suffixes and compressors, decompressors +my %comprC = ( + ".tgz", ["tar czf ", "tar xzf "], + ".zip", ["zip -q -r ", "unzip -q "] +); +my $outlyr; +my $outdir; my $outpic; my $outzbf; OPTION: # sort through options @@ -43,9 +71,14 @@ while ($#ARGV >= 0 && "$ARGV[0]" =~ /^[-\@]/) { } # Check booleans for my $boopt (@boolO) { - if ("$ARGV[0]" =~ ('^' . $boopt . '[-+01tfynTFYN]$')) { + if ("$ARGV[0]" =~ ('^' . $boopt . '[-+01tfynTFYN]?$')) { push @rtraceA, $ARGV[0]; push @rpictA, shift(@ARGV); + if ("$ARGV[0]" eq "-i") { + $irrad = ! $irrad; + } elsif ("$ARGV[0]" =~ /^-i[-+01tfynTFYN]/) { + $irrad = ("$ARGV[0]" =~ /^-i[+1tyTY]/); + } next OPTION; } } @@ -91,16 +124,34 @@ while ($#ARGV >= 0 && "$ARGV[0]" =~ /^[-\@]/) { } elsif ("$ARGV[0]" eq "-n") { shift @ARGV; $nprocs = shift(@ARGV); + } elsif ("$ARGV[0]" eq "-d") { + shift @ARGV; + $refDepth = " -d " . shift(@ARGV); + } elsif ("$ARGV[0]" =~ "$outpatt") { + push @rtraceA, $ARGV[0]; + $outlyr = substr(shift(@ARGV), 2); + $outdir = shift(@ARGV); } else { die "Unsupported option: " . $ARGV[0] . "\n"; } } +my %rcodeC = ( + ".hdr", ["-of3", "!pvalue -r -df -u"], + ".dpt", ["-of", "!rcode_depth$refDepth -ff"], + ".nrm", ["-of3", "!rcode_norm -ff"], + ".idx", ["-oa", '!rcode_ident "-t "'] +); die "Number of processes must be positive" if ($nprocs <= 0); +if (defined $outdir) { # check conflicting options + die "Options -o and -o* are mutually exclusive\n" if (defined $outpic); + die "Options -z and -o* are mutually exclusive\n" if (defined $outzbf); +} if (defined $outpic) { # redirect output? die "File '$outpic' already exists\n" if (-e $outpic); open STDOUT, '>', "$outpic"; } -if ($nprocs == 1) { # may as well run rpict? + # may as well run rpict? +if ($nprocs == 1 && !defined($outdir)) { push(@rpictA, $ARGV[0]) if ($#ARGV == 0); exec @rpictA ; } @@ -109,15 +160,52 @@ die "Need single octree argument\n" if ($#ARGV != 0); my $oct = $ARGV[0]; my $view = `@vwrightA 0`; my @res = split(/\s/, `@vwraysA -d`); +if (defined $outdir) { # layered output directory? + my $pkg; + my ($pkgext) = ($outdir =~ /(\.[^.]+)$/); + + if ($pkgext) { + die "Unknown compressor for '$pkgext'\n" if (!defined $comprC{$pkgext}); + $pkg = $outdir; + die "Output '$pkg' exists as directory!\n" if (-d $pkg); + $outdir = substr($pkg, 0, length($pkg)-length($pkgext)); + if (-e $outdir) { + die "Both '$outdir' and '$pkg' exist!\n" if (-e $pkg); + } elsif (-e $pkg) { + system "$comprC{$pkgext}[1] '$pkg'"; + die "Cannot decompress '$pkg'\n" if ( $? ); + } + } + if (! -d $outdir) { + mkdir $outdir or die("Cannot create output directory '$outdir'\n"); + } + # construct rsplit command + foreach (0..(length($outlyr) - 1)) { + my $oval=substr($outlyr, $_, 1); + $oval = "i" if ($oval eq "v" && $irrad); + die "Duplicate letter in -o$outlyr\n" if (!defined $rtoutC{$oval}); + my ($otyp) = ($rtoutC{$oval} =~ /(\.[^.]+)$/); + push @rsplitA, $rcodeC{$otyp}[0]; + push @rsplitA, qq{'$rcodeC{$otyp}[1] > "$outdir/$rtoutC{$oval}"'}; + delete $rtoutC{$oval}; + } + system "@vwraysA | @rtraceA -fff @res $oct | " . + "getinfo -a 'VIEW=$view' | @rsplitA"; + die "Error running rtrace\n" if ( $? ); + if (defined $pkg) { # compress folder if requested + unlink $pkg; + system "$comprC{$pkgext}[0] '$pkg' '$outdir'"; + die "Cannot compress folder '$outdir'\n" if ( $? ); + system "rm -r '$outdir'"; + } + exit; # all done with layered output +} if (defined $outzbf) { # generating depth buffer? - my $tres = "/tmp/rtp$$"; - system "@vwraysA | @rtraceA -fff -ovl $res[4] $oct > $tres" || exit 1; - system( q{getinfo -c rcalc -if4 -of -e '$1=$1;$2=$2;$3=$3' < } . - "$tres | pvalue -r -df -Y $res[3] +X $res[1] | " . - "getinfo -a 'VIEW=$view'" ); - system( "getinfo - < $tres | rcalc -if4 -of > $outzbf" . q{ -e '$1=$4'} ); - unlink $tres; - exit; + exec "@vwraysA | @rtraceA -fff -olv @res $oct | " . + "rsplit -ih -iH -f " . + "-of $outzbf " . + "-oh -oH -of3 '!pvalue -r -df' | " . + "getinfo -a 'VIEW=$view'"; } - # no depth buffer, so simpler + # no depth buffer, simplest case exec "@vwraysA | @rtraceA -ffc @res $oct | getinfo -a 'VIEW=$view'";
